POV-Ray : Newsgroups : povray.beta-test : SSLT hanging for me on the Mac Server Time
27 Jan 2026 18:48:18 EST (-0500)
  SSLT hanging for me on the Mac (Message 1 to 9 of 9)
Subject: SSLT hanging for me on the Mac
Date: 30 Apr 2010 08:10:01
Message: <web.4bdac7ccc2f5ffb121619a220@news.povray.org>
I've tried doing some renders of an SSLT object (in my buddha scene), and I'm
getting hangs all the time. If I run one thread the render just stops, if I run
two threads, one stops and then later the second thread stops at another point.
If I change the camera angle, I can sometime get a render to complete. It looks
kinda like the bad block the renderer gets stuck on it at the extreme edge of an
object if that helps at all.
The same thing happens with the 64 bit beta 36 and 37 on the Mac.
A sample of the applications stack when two threads have hung the renderer
includes the following:
    2154 Thread_1032143
      2154 thread_start
        2154 _pthread_start
          2154 thread_proxy
            2154 pov::Task::TaskThread(boost::function0<void> const&)
              2154 pov::TraceTask::Run()
                2154 pov::TraceTask::SimpleSamplingM0()
                  2154 pov::TracePixel::operator()(double, double, double,
double, pov_base::Colour&)
                    2154 pov::Trace::TraceRay(pov::Ray&, pov_base::Colour&,
float, pov::Trace::TraceTicket&, bool)
                      2154 pov::Trace::ComputeTextureColour(pov::Intersection&,
pov_base::Colour&, pov::Ray&, float, bool, pov::Trace::TraceTicket&)
                        2154
pov::Trace::ComputeOneTextureColour(pov_base::Colour&, pov::Texture_Struct*,
std::vector<pov::Texture_Struct*, std::allocator<pov::Texture_Struct*> >&,
pov::Vector3d&, pov::Vector3d&, pov::Ray&, float, pov::Intersection&, bool,
                          2154
pov::Trace::ComputeLightedTexture(pov_base::Colour&, pov::Texture_Struct*,
                            2154
pov::Trace::ComputeSubsurfaceScattering(pov::Finish_Struct const*, pov::Vector3d
const&, pov::Ray&, pov::Vector3d const&, pov_base::RGBColour&, double,
pov::ObjectBase*, pov::Trace::TraceTicket&)
                              1210 log
                              889
pov::Trace::ComputeSingleScatteringContribution(pov::Intersection const&,
pov::Vector3d, pov::Vector3d, double, double, pov_base::RGBColour&, double,
                                454
                                435
pov::RandomDoubleSequence::Generator::operator()()
                              55 dyld_stub_log
    2154 Thread_1032144
      2154 thread_start
        2154 _pthread_start
          2154 thread_proxy
                        2154
                          2154
                            2154
                              1223 log
                              894
                                450
                                444
                              37 dyld_stub_log
which at least looks like it's busy doing something, and not deadlocked
somewhere...
Cheers,
Edouard.
Subject: Re: SSLT hanging for me on the Mac
Date: 30 Apr 2010 08:24:38
Message: <4bdacc06$1@news.povray.org>
Am 30.04.2010 14:06, schrieb Edouard:
 From the stack trace, I'd assume that POV-Ray doesn't really hang, but
is just pretty busy. Maybe lower quality settings will get you forward?
Unfortunately, SSLT is still at a very early stage, and not exactly in
the focus of current development efforts these days.
Date: 30 Apr 2010 15:10:00
Message: <web.4bdb2ad7d64d362621619a220@news.povray.org>
It hangs when my settings are "subsurface { samples 1, 1 }", so I think it's
gotten stuck with something. When I try to quit POV-Ray I get a crash.
Cheers,
Edouard.
Date: 30 Apr 2010 16:11:59
Message: <4bdb398f$1@news.povray.org>
Am 30.04.2010 21:09, schrieb Edouard:
Um... yes, that sounds suspicious indeed.
After having had a closer look at the stack trace, I think I found the
portion of the code where it hangs.
There is a loop at the beginning of
Trace::ComputeSingleScatteringContribution() that is intended to trace
the ray a random distance into the object, using a special random
distribution that may theoretically yield infinite distances; of course
the ray should only be traced up to the next intersection point with the
object's surface, so the algorithm will roll the dice again if that
condition isn't met.
That said, if the ray happens to hit an exceptionally thin part of the
object, the algorithm will roll the dice again and again and again
and... well, I guess you get the point.
The crucial thing here is the ratio between the object "thickness" and
the sum of the two coefficients used to specify the material's SSLT
properties. The smaller the coefficients and/or the "thinner" the
object, the more likely is a lockup to occur.
Note that you can reduce the probability of a lockup without changing
the scene geometry or material properties, by increasing the
"mm_per_unit" global setting (though of course this will reduce the SSLT
effect as if your whole scene was increased in size).
Date: 30 Apr 2010 16:31:15
Message: <4bdb3e13$1@news.povray.org>
I've not used this functionality yet, but thought I'd pass this
change-log excerpt along ... who knows you may see something that might
be helpful in determining what the problem is :-)
http://wiki.povray.org/content/Documentation:ToDo%5CCLReview#Beta_31
Jim
Date: 16 May 2010 21:35:01
Message: <web.4bf09cb3d64d36264af8cec0@news.povray.org>
Is it the loop with the comment "calculate s_prime_out"?
It looks like the random number can simply be scaled so that you don't need the
loop at all...
At the very worst, can you make a change to ensure it doesn't hang - some sort
of bailout condition? Do you want me to add a bug to flyspray for it?
Cheers,
Edouard.
Date: 17 May 2010 06:21:56
Message: <4bf118c4$1@news.povray.org>
Am 17.05.2010 03:32, schrieb Edouard:
Yup.
> loop at all...
No. The proper solution is much simpler: Re-rolling the dice was the
wrong thing to do in the first place; such an event would be equivalent
to a photon happening to pass through unscattered and unabsorbed, so
should be dealt with accordingly.
Never mind. There's already a patch waiting to be released with beta 38.
Date: 17 May 2010 18:25:01
Message: <web.4bf1c169d64d36264af8cec0@news.povray.org>
> > loop at all...
Oh - does that mean we'll get actual transparency if the object is thin enough?
That would be fantastic!
That's great news - thank-you again for all the work!
Cheers,
Edouard.
Date: 18 May 2010 16:02:25
Message: <4bf2f251@news.povray.org>
Am 18.05.2010 00:21, schrieb Edouard:
That's the plan, yes.
I'm afraid though it will take some time until then - there's other
construction sites with higher priority in POV-Ray at present.
