POV-Ray : Newsgroups : povray.beta-test : About no_radiosity and radiosity off Server Time
17 Nov 2025 10:12:46 EST (-0500)
  About no_radiosity and radiosity off (Message 1 to 10 of 34)
Subject: About no_radiosity and radiosity off
Date: 15 Sep 2009 04:55:00
Message: <web.4aaf555ce5e56adf3b29dc8d0@news.povray.org>
To summarize:
Changes between 3.7.beta.13 and 3.7.beta.14
Added radiosity on/off flag for objects.
Changes between 3.7.beta.32 and 3.7.beta.33
Added no_radiosity keyword, as known from MegaPOV:
Specifying "no_radiosity" in an object block makes that object invisible
to radiosity rays, ...
What are the differences?
- A test with no_radiosity:
Insert > Scene templates > Radiosity scene
With:
  sphere {
    <0,1,0>, 1
    no_radiosity
I do not know any difference.
Instead "radiosity off" is ok.
I am wrong?
Subject: Re: About no_radiosity and radiosity off
Date: 15 Sep 2009 05:33:26
Message: <4aaf5f66$1@news.povray.org>
Unless I perfectly goofed it up, "radiosity off" prevents an object from
*receiving* diffuse interreflection (aka radiosity), while
"no_radiosity" prevents an object from *emitting* diffuse interreflection.
Date: 15 Sep 2009 06:00:00
Message: <web.4aaf64fec26aab573b29dc8d0@news.povray.org>
I have a (little) confusion in my mind...
Now I understand.
Thank you, clipka.
Maybe, just maybe, it might be useful to combine these three options in a single
keyword even with alphanumeric values?
Just a small idea, with no pretensions.
Of course, I'm already so happy. :-)
Date: 15 Sep 2009 06:11:00
Message: <4aaf6834$1@news.povray.org>
(I just checked whether it indeed does what I thought it does after
having seen the code - it does do right that :-))
The syntax for "no_radiosity" was chosen to (a) match the megapov
syntax, and (b) fit into the family of no_shadow, no_reflection and
no_image keywords, which all basically say, "for the sake of
[shadow/reflection/image/radiosity] rays, this object does not exist",
to be consistent there (which was also probably the motivation for the
megapov syntax).
The "radiosity off" syntax already existed at that time, so it was just
left unchanged. It's a bit "dangling" I think.
Date: 15 Sep 2009 06:25:01
Message: <web.4aaf6b75c26aab573b29dc8d0@news.povray.org>
Ach komm, das gibt's doch nicht! :-)
> megapov syntax).
I fully understand the reasons.
Date: 15 Sep 2009 16:49:39
Message: <4aaffde3@news.povray.org>
  It feels quite confusing. How about reusing existing keywords for a
clearer syntax:
radiosity { emission on/off }
radiosity { collect on/off }
Date: 15 Sep 2009 17:04:35
Message: <4ab00163$1@news.povray.org>
> clearer syntax:
How about sticking to the established megapov syntax, hm?
Date: 15 Sep 2009 17:11:12
Message: <4ab002f0@news.povray.org>
clipka wrote:
>> clearer syntax:
Compatibility to MegaPOV should be of *no* concern when porting a patch or
feature over to official POV-Ray. Consistency and avoiding new keywords when
reasonable should be the primary conditions for syntax decisions.
	Thorsten, POV-Team
Date: 15 Sep 2009 17:41:13
Message: <4ab009f9$1@news.povray.org>
> or feature over to official POV-Ray. Consistency and avoiding new
> keywords when reasonable should be the primary conditions for syntax
> decisions.
>     Thorsten, POV-Team
Though I generally consider this a reasonable position, in this
particular case there was a reason for the MegaPOV patch to use this
particular syntax and not a different one, touching one of the very
points mentioned: Consistency, in this case with the other
"no_something" keywords.
So using any other syntax as that used in MegaPOV would have meant...:
- breaking consistency among the "no_something" family of keywords
- having to invent a new syntax from scratch
- with not much of a precendence case to orient on
- and with the syntax "radiosity off" already being in use for another
very different feature.
Plus, as already mentioned, sacrificing the opportunity to use a syntax
already familiar to the users of a very famous POV-Ray patch - which of
course would not be sufficient alone, but I think it quite well rounds
off the whole thing.
Date: 15 Sep 2009 18:34:00
Message: <4ab01658@news.povray.org>
  Just because "no_something" is used for some features doesn't mean the
syntax is sound for all possible such features.
  Take, for instance, photon mapping. There's no "no_photons" keyword.
There is "photons { pass_through }" and "photons { collect off }", and
for good reasons.
  I see radiosity being more akin to photon mapping than to things like
no_image and no_reflection.
  Photon mapping already "breaks consistency". Except that it doesn't.
Artificially forcing a feature to the same mold as some other feature
is not always a good idea. With photon mapping the different syntax is
justified, and IMO so it is with radiosity.
  I fail to see how that is a bad thing. If the new syntax is *better*
and easier to understand, it's definitely a *good* thing, not a bad one.
  Wrong. See photon mapping.
  Just because an unofficial patch has made poor choices in syntax doesn't
mean those same poor choices must be replicated in the official version.
