POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
26 Mar 2026 00:33:42 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 61 to 70 of 104)
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 1 Sep 2009 12:18:44
Message: <4a9d4964@news.povray.org>
Warp schrieb:
>> That's not POV-Ray, it's the display software.
>   What are you talking about? Are you mad?
*Sigh*
Maybe I'm perfectly hopeless at explaining things. It has always seemed
the contrary to me, but I can't seem to get this through to you.
>   How is it "the display software" if I want POV-Ray to output a pixel
> value of (127,127,127) for rgb .5, without any correction of any kind?
Then you just pick File_Gamma=1.0, and you /will/ get that pixel value
of 127,127,127 in the file.
But POV-Ray will also (correctly) write into the PNG file that no gamma
correction was applied whatsoever (or, probably, that a gamma of 1.0 was
applied), because that's just how the PNG file format gamma handling is
supposed to work. Not an invention of the POV-Ray developers, but part
of the PNG specification.
Which most modern image viewing software will take to imply that /it/
should do the gamma correction, because it will assume your display
hardware to have a gamma of around 2.2, and therefore require a gamma of
1/2.2 to be applied to the image data first.
Let me repeat it: *This is proper behaviour!* Not because I say so, but
because the PNG specs say so.
If you do not want this, pick a file format that allows you to screw up
gamma - or find a software that lets you mess with an image's gamma.
POV-Ray is a raytracing software, not an image post-processing tool.
I know you don't like the results and think they're wrong, and that is
actually the case - but as I have been repeating over and over again,
this is *not* a problem of the *output* file gamma, but a problem of the
*input* file gamma. And it doesn't make any sense to modify output gamma
file handling to fix problems with input file gamma, does it??!
>   If I want the exact values (127,127,127) to be written to the file,
> what exactly is the reason why POV-Ray would refuse to do so?
 From here on I'm taking your question to actually be "If I want the
voltage levels of (50%,50%,50%) to be sent to the monitor...", although
that's a totally different thing.
The reason for POV-Ray to refuse to do so in PNG files is simple:
Because the aim is to get /correct/ file output, i.e. if a brightness
level of 50% is computed, the aim is to generate an output file that,
when displayed, will cause a brightness level of 50% on the output hardware.
Consider this a "what you see is what POV-Ray computed" policy. It makes
the best effort to ensure that others will see just the same thing; that
the output is realistic; and that you know sure as hell that if it looks
crappy on your display, it is your scene illumination or texturing that
needs work [*], not your output gamma settings.
[* Thus the theory; at present, it can also mean that input file gamma
handling issues need woring around.]
With file formats that do not define gamma handling, this can only be
achieved by making known to POV-Ray what gamma pre-correction the
software "downstream" in your image processing pipeline expects, and
this what File_Gamma is designed to do. POV-Ray will then encode the
image to match that software's expectations.
With file formats that are designed to unambiguously address gamma
handling, this task is much simpler: Just comply to the file format. No
need for File_Gamma at all. Some file formats may demand colors to be
encoded fully linearly (I guess OpenEXR is such a case), while others
will allow a gamma transformation to be applied before encoding pixel
values, but require that the gamma parameter is stored in the metadata,
and that software reading such files must apply the inverse
transformation after decodig the pixel values before processing or
displaying them. In any case, such file formats by design make it the
viewing software's responsibility to perform any necessary gamma
pre-correction to compensate for the display hardware's gamma.
PNG does unambiguously address gamma handling with the gAMA chunk, and
is therefore designed to preserve the actual brightness information in
the image - although in this case the File_Gamma may also still be
required for interoperation with older software down the pipeline that
happens to be ignorant about gAMA chunks.
Now if I understand you right, you want to apply an additional gamma
transformation to the final image, because
(A) you want to make your "rgb <127,127,127>/255" look like HTML color
#7F7F7F, and
(B) you want to make gamma pre-corrected JPG input files pass through
the whole rendering process "unharmed".
Aside from these, you didn't bring up any complaints about POV-Ray's
gamma handling, so I assume these are the only purposes why you would
want such a post-render gamma transformation step (except maybe for
nostalgic reasons).
Note however that in both cases, applying a gamma transformation /after/
the rendering is the wrong solution to this problem: The proper solution
is to apply this very same transformation /before/ the rendering.
Look at this simple example:
Let's say you have a white plane illuminated by two spotlights of 50%
intensity. Areas hit only by one light should obviously give you a
brightness of 50%, while the region illuminated by both spotligts should
obviously give a brightness of 100%. In the linear domain this is no big
deal: 0.5 + 0.5 = 1.0.
Now let's do these computations in the gamma-precorrected domain: There,
50% brightness equals a value of 0.73. In the areas illuminated by only
one spotlight, this gives you a total "illumination value" of 0.73,
which we have just seen to equal 50% brightness. Fine, no harm done
here. But the area where the spotlights intersect will give you an
illumination value of 0.73 + 0.73 = 1.46; in the gamma-precorrected
domain, that would equal a whopping 230% of brightness!
As you may see even from this simple example, for the math it /does/
make a difference whether you transform your input colors to the linear
domain /before/ or /after/ performing the computations. The latter won't
properly remedy the errors introduced by failing to do the former, even
for comparatively simple situations.
Your test-pattern image has clearly shown that output gamma as such is
handled properly (otherwise the black-and-white stripes wouldn't match
the rgb 0.5). So if there's a problem with the images (and do I agree
that this is definitely the case for the image map, and I do agree about
the "#7F7F7F" thing to the extent of calling it an "issue"), then any
proper remedy must tackle them /before/ the computations.
Date: 1 Sep 2009 12:47:34
Message: <4a9d5026$1@news.povray.org>
Warp schrieb:
>   You assume that on a CRT pure white pixels have the exact same size as
> pure black pixels, ie. that there's no color bleending at all happening
> on the fluorescent surface.
No, I just assume that the the phosphors react sufficiently linear with
respect to electron beam intensity vs. emitted light intensity, as well
as interaction with scattered light. If that is given (and as of now I
have not heard of anything to the contrary), it does not matter how much
the beam widens at high intensities, or how much optical scattering
occurs in the phosphors: Both effects then just change the distribution
of the light emission, but preserves the overall brightness.
If you doubt this presumption, you can still try with a coarser pattern
and a diffusor like a sheet of paper.
Also note that if there was a nonlinear effect of color bleeding on the
overall brightness acting in favor of the 3.7 gamma, then the same
effect would have been present in the checkerboard pattern as well,
partially countering the black/white transition nonlinearities in there
that favored the 3.6 settings.
Date: 1 Sep 2009 13:23:03
Message: <4a9d5876@news.povray.org>
  Except that it isn't. If you specify Display_Gamma=1.0 and File_Gamma=1.0,
POV-Ray will display non-gamma-corrected pixels on screen, and write the
exact same non-gamma-corrected pixels into the PNG file, but then it
specifies a gamma metadata of 2.2 in the PNG file (where is it getting
the 2.2 from anyways?) which causes the PNG to show *differently* than
what POV-Ray showed on screen.
  If you then manually remove the gamma metadata from the PNG file, *then*
the PNG and what POV-Ray showed on screen will match, because only then
will no extraneous gamma correction be applied (as was the original intent
when the gamma settings were both set to 1.0).
  Can you explain where the extranous 2.2 gamma setting is coming from,
when both Display_Gamma and File_Gamma are set to 1.0? Is there a third
setting somewhere? Is it hard-coded into the POV-Ray source code?
  I think that it's a bit ridiculous that if I want POV-Ray to produce "raw",
non-gamma-corrected pixels, I have to go through manual post-processing
trickery to achieve that (or, I assume, use an image format which does not
support gamma metadata). If I say that gamma is 1.0, in other words,
completely unmodified pixels, then I mean that.
Date: 2 Sep 2009 01:03:38
Message: <4a9dfcaa$1@news.povray.org>
(1) Note that specifying a Display_Gamma does /not/ change what POV-Ray
/computes/; so if you specify a wrong Display_Gamma (and 1.0 /is/ a
wrong value for your system), what you see during preview is /not/ what
POV-Ray computed either.
(2) Are you /sure/ that what you observe is a gAMA chunk specifying an
encoding gamma of 1/2.2 (i.e. encoded for direct display on a gamma 2.2
display)? I pretty much doubt it:
- If POV-Ray writes linear color values into the PNG file, it must write
a gAMA chunk specifying a gamma of 1.0 to produce a properly encoded PNG
file.
- If the file contained a gAMA chunk specifying a precorrection for a
gamma of 2.2 (i.e. an encoding gamma of 1/2.2), then AFAIK stripping
that gAMA chunk would not change the way most image vewers display the
image, because they will by default assume exactly that encoding gamma.
- If, however, POV-Ray does write linear color values into the PNG file,
accompanied by a gAMA chunk specifying an encoding gamma of 1.0, then
indeed stripping that gAMA chunk will cause image viewers to presume an
encoding gamma of 1/2.2 (which will then be /not/ what POV-Ray used),
and therefore not perform any additional gamma-correction, because it
cancels out with their assumed display hardware gamma of 2.2 - and this
would indeed have the same effect as the wrong Display_Gamma=1.0
settings (which tells POV-Ray to not perform gamma-correction on the
preview, by forcing it into assuming that the display hardware has a
gamma of 1.0).
So to sum it up: Specifying Display_Gamma=1.0 does not change what
POV-Ray /computes/, only what it shows in preview; and I expect the
gamma 2.2 gAMA chunk in the File_Gamma=1.0 to be a misinterpretation of
your observations.
Tell me, in all honesty, what do you /want/ those "'raw',
non-gamma-corrected pixels" for in the first place?
I actually find it ridiculous that you /ask/ for it, that being
essentially /messed-up/ gamma in what will ultimately be visible
on-screen; if you do not recognize this fact, then you haven't
understood gamma handling yet (and I'm not talking about POV-Ray in
particular here, but the general concept), and might want to do a bit of
googling on the topic.
Date: 2 Sep 2009 12:46:37
Message: <4a9ea16d$1@news.povray.org>
> Alain <aze### [at] qwertyorg> wrote:
>> On my system, ALL the starfields looks the same.
>   I don't understand how that is physically possible. The starfield image
> as rendered by pov3.6 has completely different pixel values than the one
> rendered by pov3.7. For example, the upper left pixel of the starfield area
> in the pov3.6-rendered image has a pixel value of (0A, 0D, 20), while the
> one in the pov3.7-rendered image has a pixel of (3A, 41, 63).
The first time i visited, the starfields where identical, except for the
surrounding backgrounds.
This time, they are not.
The "original" and the 3.6.1 are identical.
The 3.7 is MUCH brighter. It shows details that are NOT visible in the
other images even with the brightness cranked to the max for the firsts,
with the brightness at it's lowest setting for 3.7.
Whatever my settings, the top and bottom parts of the rendered images
never match.
Notably darker with 3.6.1, much lighter with 3.7.
On the other hand, I get no undesirable effects when I use a POV-Ray
generated image as an input in another one. Brightness, saturation and
colour balance don't change. I normaly use PNG as file format.
Date: 2 Sep 2009 14:26:50
Message: <4a9eb8ea@news.povray.org>
  What does it matter why I want them?
  If I want a program to write the value 12345 to a file, then I expect
the program to write 12345 to the file, not some other value. Why should
the program try to guess what I "really want"?
  One reason can be that I want to match exactly the image pixel values with
HTML colors. If I want the color scheme of an image to match, for example,
the background color of a HTML page, I should be able to do that.
  If POV-Ray outright refuses to do that no matter what you do, then
outputting to PNG is a complete waste of time. Outputting to an image
format where POV-Ray does not force some gamma metadata (for the simple
reason that the image format does not support that) will in this case be
more productive.
  Tell me the reason why Display_Gamma=1.0 and File_Gamma=1.0 must produce
different results. What is shown on screen does not match what is written
to the PNG file. Why not? If I specified the same value for both, I expect
both things to be identical. Now they are not.
Date: 2 Sep 2009 14:59:14
Message: <4a9ec082@news.povray.org>
  Consider, for example, this:
http://warp.povusers.org/pov_imagemap_test/index2.html
  When outputting to PNG, File_Gamma has basically no effect. While the
pixel values written to the file are different, POV-Ray still manages to
make the PNG behave exactly as if a File_Gamma of 2.2 was always defined.
It doesn't matter if File_Gamma is 1.0 or 2.2, the result will always look
the same.
  If the user really wants the output file to look the same as what
POV-Ray displayed on screen when Display_Gamma was set to 1.0, he has
to either use some other image format (eg. TGA) or he has to manually
remove the gamma metadata from the PNG file.
  So I have a few questions:
  1) What exactly is the purpose of File_Gamma, given that it makes no
difference (when creating a PNG file)?
  2) Where is POV-Ray conjuring a gamma setting of 2.2 even though neither
Display_Gamma nor File_Gamma were even close to that value?
  3) Why do Display_Gamma and File_Gamma produce different results even
if they are set to be the same (when creating a PNG file)?
  4) Why does POV-Ray produce different results depending on the output
image format? For example, rendering to a TGA file results in a different
result than rendering to a PNG file when File_Gamma = 1.0 (the pixels are
the same, but the gamma metadata makes the PNG different from the TGA).
  5) How do I make POV-Ray 3.7 to produce a PNG which looks the same as
what it displayed on screen and as it produces when outputting to a TGA
file?
Date: 2 Sep 2009 15:19:35
Message: <4a9ec547@news.povray.org>
Why do you not look for yourself? After all, you are a capable programmer
and you have no problem following the existing code.
	Thorsten
Date: 2 Sep 2009 16:26:39
Message: <4a9ed4ff$1@news.povray.org>
POV-Ray's input file gamma handling appears to be more reliable for PNG
than for JPG.
Date: 2 Sep 2009 16:32:15
Message: <4a9ed64f@news.povray.org>
  With that question I didn't mean "where in the source code"?
  Substitute the word "where" with the word "why" in my original question
to get the more accurate meaning.
