POV-Ray : Newsgroups : povray.beta-test : Same scene renders different in v3.7beta34 versus v3.62 Server Time
20 Mar 2026 05:13:17 EDT (-0400)
  Same scene renders different in v3.7beta34 versus v3.62 (Message 15 to 24 of 104)
Subject: Re: Same scene renders different in v3.7beta34 versus v3.62
Date: 23 Aug 2009 06:47:31
Message: <4a911e43@news.povray.org>
> Warp schrieb:
> > clipka <ano### [at] anonymousorg> wrote:
> >> In 3.6, however, the rgb 0.5 object (B) will look way darker: POV-Ray
> >> will have output "127"
> >   You mean that POV-Ray 3.6 didn't gamma-correct the output at all, while
> > POV-Ray 3.7 now does?
> I mean that 3.6 didn't do it /by default/ (which is what you've been
> asking about all the time).
> >   Does that mean there's now a new option to set the gamma correction of
> > the created image (the actual pixels, not just some header data in the
> > image file format)? Is there a way to turn this off, if one so desires
> > (eg. if you really *want* the pixels to be exactly (127,127,127) and
> > nothing else)?
> Yup. "File_Gamma" is the magic ini file option. Set it to 1.0 and you'll
> get linear pixel values, plus (for PNG and HDR) a header saying that the
> data is linear. Set it to 2.2 and you'll get gamma pre-corrected pixel
> values, plus a header saying that the data is pre-corrected for a gamma
> of 2.2. (The latter is highly recommended though, as not all viewers -
> browsers included - support linear image data.)
> Note that this makes it impossible to deliberately mess with gamma for
> artistic effect in POV-Ray when you use PNG output and all your image
> processing software handles gAMA chunks properly: You can only affect
> the encoding of pixels - and thereby the dynamic ranges of highlights
> vs. shadows - but not their interpretation.
> At least that's the theory as known to me. I never tested in detail
> whether it indeed works exactly as intended.
  Well, this clears things up a bit. I'm still not 100% happy that old
scenes will render differently by default, but I suppose it's an acceptable
change.
  I highly recommend writing a concise and clear explanation of this in the
"what's new in POV-Ray 3.7" section when the final version is published.
Else it's only going to cause a lot of confusion.
Date: 23 Aug 2009 13:18:02
Message: <4a9179ca$1@news.povray.org>
> change.
/That/, as I mentioned as well, is only the case if they don't have a
"#version" directive, or when you're rendering to a "gamma-aware" file
format.
Boy, how /I/ long for a concise and clear explanation of gamma! Output
gamma is only the tip of the iceberg.
Try feeding POV-Ray output into POV-Ray again as a texture image -
that's where things appear to get /really/ hairy!
Date: 29 Aug 2009 11:20:12
Message: <4a99472c@news.povray.org>
Btw, if I load a jpeg image as an image_map to an object with diffuse 0
and ambient 1, the image will look way too bright and washed out, completely
different than when I look at the image with any other program.
  If I write an "assumed_gamma 2.2" in the global_settings block, pov3.7
will warn me, but now the image will look correct.
  So what is the *proper* way to tell pov3.7 how it should assume colors
(eg. in image maps) to be gamma-corrected?
Date: 29 Aug 2009 12:49:16
Message: <4a995c0c@news.povray.org>
  Btw, if I put "Display_Gamma=1.0" in povray.ini, then the *display* shows
the proper gamma. However, the generated png file has the wrong gamma.
  I thought that I could fix that by adding "File_Gamma=1.0", but that had
no effect on anything. Neither does "File_Gamma=2.2" or anything else.
Date: 29 Aug 2009 15:05:10
Message: <4a997be6$1@news.povray.org>
Apparently POV-Ray fails to properly read the gamma information from its
own generated PNG files. There has been some discusson about this in thread:
news://news.povray.org:119/web.4a398f2555c7683545339cfa0@news.povray.org
Date: 29 Aug 2009 15:30:09
Message: <4a9981c1@news.povray.org>
  In this case it's not a problem of POV-Ray itself reading its own PNG files.
It's a problem of POV-Ray always creating image files with the same (and to
my understanding wrong) gamma value, regardless of what the File_Gamma ini
setting is.
Date: 29 Aug 2009 18:38:05
Message: <4a99adcd$1@news.povray.org>
I just went back to this post, to find that I misunderstood.
Yes, POV-Ray /definitely/ has a problem with gamma of input files. PNG
files with a gAMA chunk are allegedly safe, and HDR files as well from
my experience (OpenEXR probably too), but just about everything else is
currently bogus, due to POV-Ray not taking into account any color
management metadata.
My suggestion would be to (A) fix the standard handling to respect at
least standard color profiles, and (B) provide a means to override the
assumed gamma pre-correction on a per-file basis.
Date: 30 Aug 2009 02:57:46
Message: <4a9a22ea@news.povray.org>
  Also POV-Ray 3.7 displaying the image on screen with one gamma setting
(with Display_Gamma is set) and writing the file with a completely different
gamma setting is a problem.
  Btw, a Display_Gamma of 1.0 produces (on screen) an image which is
basically identical to what POV-Ray 3.6 produces, all image_maps look
correct, etc. Is there a reason why it cannot be the default?
Date: 30 Aug 2009 08:13:07
Message: <4a9a6cd3$1@news.povray.org>
It only is a problem if you set the Display_Gamma value wrong, or set
the File_Gamma value to a nonstandard value with a file format not
supporting embedded gamma information.
Yes, there is: It's perfectly wrong for most systems.
Did you ever try it out with a scene to test your workflow for gamma issues?
Just set up a scene with a thin-horizontally striped (or, if you have an
LCD display, checkered) black-and-white background and some rgb 0.5
object for comparison, using ambient-only materials.
Such a scene /should/ look perfectly homogenous when you squint you
eyes. If it doesn't, your workflow doesn't handle gamma properly.
(Similarly, the output of such a scene, used as input for another scene
and heavily blurred by focal blur or anti-aliasing, should appear
homogenous as well; this is where POV-Ray currently does a poor job.)
Date: 30 Aug 2009 09:21:08
Message: <4a9a7cc4@news.povray.org>
  It is a problem when POV-Ray ignores the File_Gamma setting, as seems to
be currently the case.
  Anyways, I don't really understand the reason to have a different gamma
setting for displaying the preview image on screen and another for writing
the image data to a file. If you specify different values, you will not get
what you see, but something different.
  Then every single program out there which displays image is wrong, and
POV-Ray is the only program which is right?
  If I take a jpeg image and view it with Firefox, ImageMagick, The Gimp,
Konqueror or basically any software in existence which is able to read and
display jpeg images, they will all show the image in the same way. However,
if I use that same jpeg image as an image_map in POV-Ray 3.7 beta, using
default settings, eliminate all lighting effects and render an image like
that, the gamma setting for that jpeg image will be completely wrong: It
looks way too light and washed out. And not just a little, but quite
significantly. Basically the image is useless that way.
  However, when I tell POV-Ray to use a Display_Gamma of 1.0, then it will
start showing the image in the exact same way as all the other programs.
  If a Display_Gamma (and, I assume, File_Gamma when it's fixed) of 1.0
is not the proper way of fixing this problem, then please tell me what is.
Because as it is now, the default setting makes image_maps completely
unusable.
  If you don't believe me, I can show you examples.
