POV-Ray : Newsgroups : povray.beta-test : Beta 31: Crackle problem Server Time
27 Mar 2026 17:15:18 EDT (-0400)
  Beta 31: Crackle problem (Message 10 to 19 of 29)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Beta 31: Crackle problem
Date: 5 Mar 2009 03:45:17
Message: <49af911d@news.povray.org>
stbenge <^@hotmail.com> wrote:
> >> I suppose I should have written a bug report. Thanks Carlos ;)
> >> Sam
> > When I was little someone called me "Don Carlos", but unfortunately the "Don"
> > and the "s" does not suit me, because unfortunately I am Italian.
> > :-D
> Oops, I feel pretty embarrassed. Sorry Carlo (:-]
  A "compromise", Don Carlo, actually sounds cool. And with "Don" I don't
mean the Spanish "sir" title, but the English name (as in Don Johnson).
Date: 5 Mar 2009 04:15:00
Message: <web.49af97bd54d6e3093ca3a0b90@news.povray.org>
In fact, at primary schools, my professor called me "Don Carlo",
in honor of the priest *Don Abbondio*, a character of the novel "I Promessi
Sposi" ("The Betrothed" - "Kihlautuneet", for Warp!):
http://en.wikipedia.org/wiki/The_Betrothed_(Manzoni_novel)
In this case, "Don" is a synonym for "priest". :-)
</Off-Topic> (sorry!)
Carlo
Date: 8 Mar 2009 11:45:28
Message: <49b3e818$1@news.povray.org>
Bob wrote:
> It *looks* fixed, for me anyhow in the few ways I tried it.
> Render speed is another matter. Without AA the two seem similar enough until
The problem is basically the crackle cache. The bug before was due to the
cache not working properly. The slowdown now is due to the performance of
the cache now that it is working (a different caching method is used).
The problem is basically that the cache is memory-intensive, and allocating
memory during render is something we really like to avoid, as it requires
locking; the more threads, the more contention for the lock.
I've just spent some time playing with this and have improved the
performance somewhat by using memory pools, but it's still not as fast as
just not using the cache at all. (By that, I mean in wall clock time; using
no cache at all renders faster in terms of waiting for a render if you have
several cores, but burns more CPU time because of the lack of a cache).
It's a difficult problem to solve cleanly. I'll have another stab at it in
a few days.
-- Chris
Date: 8 Mar 2009 12:32:36
Message: <49b3f324@news.povray.org>
> a few days.
  I have no idea how the crackle cache works or what it does, but I was
thinking: Could the crackle cache contents be somehow precalculated prior
to rendering, similarly to how eg. photon maps are?
Date: 8 Mar 2009 14:19:15
Message: <49b40c23@news.povray.org>
If synchronization between threads costs more wall clock time
than the benefit of reusing cache data across threads, it might
be a solution to give each thread its own cache. But I don't
know how the crackle cache works in detail so this might
not be feasible after all.
Date: 8 Mar 2009 15:30:01
Message: <49b41cb9$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:49b3e818$1@news.povray.org...
> allocating
Anything would be an improvement... this was causing a drastic slowing! But
what I wouldn't have expected was the AA seemingly triggering it.
I was looking for signs of something in the render stats and at first
thought it was showing up in the doubling, tripling or more, of numbers
(rays tested, crackle cache, etc.) when using AA versus without. That is,
until I realized it's the same way regardless of thread count. Just hadn't
occurred to me AA alone makes the stat numbers jump.
This thing about memory usage you tell of makes sense to me, even if I don't
understand the real workings, so I'm just glad to hear there's a reason
behind this particular slowdown instead of something wrong elsewhere. Yet
the other slowdowns concerning thread count act like memory trouble, to me
anyhow, so I'm thinking that would be great if somehow a revelation occurs
from your work on the crackle fix (wishful thinking or not).
Reading a little about threads and memory pools just now (google searched)
is interesting, and confusing. Maybe not as problematic as it sounds, eh?
Date: 8 Mar 2009 21:58:49
Message: <49b477d9@news.povray.org>
The problem is the we don't know in advance how large it will be or what
blocks to calculate.
-- Chris
Date: 8 Mar 2009 22:02:38
Message: <49b478be$1@news.povray.org>
This is not the issue; in fact, each thread does have its own cache. The
problem is that the old code caused memory allocation to happen at run-
time, and this memory came from the global heap. This requires locking.
I made some improvements by using a memory pool for the local storage (==
less calls to new/malloc), but this needs further work. Basically we need
to drastically reduce the number of times we get memory from the global
heap, while at the same time trying to avoid getting too much memory at any
given time (which may not be needed).
-- Chris
Date: 8 Mar 2009 23:16:46
Message: <49b48a1e@news.povray.org>
On 3/8/2009 7:02 PM, Chris Cason wrote:
> Basically we need
> -- Chris
How much memory are we talking about here?
If memory is allocated in chunks, then maybe a command-line parameter to
set the chunk size would be useful for testing until an optimum solution
is found.  Also, this would allow people with more RAM to use larger
cache sizes as a default, avoiding the penalty completely.
...Chambers
www.pacificwebguy.com
Date: 9 Mar 2009 01:25:01
Message: <web.49b4a78554d6e309e7ac5bf00@news.povray.org>
Chambers <ben### [at] pacificwebguycom> wrote:
> > Basically we need
Another option: Allocate chunks of increasing size. Allocated N bytes in total
and they didn't suffice? Then allocate another N bytes next time for a total of
2*N. Still not enough? Go for another 2*N bytes.
This way you can start out small to save memory in case it's not used much
(waste is guaranteed to never be more than 50%), but get out of the "cost zone"
quickly if you really need a lot of it.
Add some "hard deck" if desired to make sure you don't waste 0.9 GB if you
happen to need 1.1GB.
Don't use dedicated pools for particular data structures, but allocate blocks
for generic use, rolling your own (thread local) heap management.
Just a few ideas "out of the blue".
