POV-Ray : Newsgroups : povray.beta-test : Texture testing needed Server Time
14 May 2024 02:29:48 EDT (-0400)
  Texture testing needed (Message 31 to 40 of 43)
<<< Previous 10 Messages Goto Latest 10 Messages Next 3 Messages >>>
Subject: Re: Texture testing needed
Date: 1 Sep 2016 09:51:21
Message: <57c83259$1@news.povray.org>
Am 01.09.2016 um 14:53 schrieb William F Pokorny:
> Any idea yet why we are getting the new shadow cache message in the
> re-factored code and the largish differences in shadow ray counts?
Not yet; but maybe they are somehow related.
Date: 1 Sep 2016 10:46:53
Message: <57c83f5d$1@news.povray.org>
On 09/01/2016 09:34 AM, William F Pokorny wrote:
> On 09/01/2016 08:53 AM, William F Pokorny wrote:
>> On 08/31/2016 11:03 PM, clipka wrote:
>> I've moved to 3.7.1-alpha.8737949 for the 3.7.1 baseline.
>> Let me see if I can run down the finish difference today.
> The finish difference seen between 3.7.1-alpha.8737949 and
> (refactor/texture) seems to be related to having a brilliance value > 1.0.
> I think this probably the cause for a great many of the other
> differences I have seen. I'm going to hold off further testing until
> there is a fix for this in the (refactor/texture) branch.
> Scene file is attached.
> Bill P.
FYI - I was able to track the change in brilliance > 1 behavior all the
way back to commit :
54b283a - Improved finish features for more realism:
of July 23, 2014!
Good news is I believe refactor/texture has it right.
Bill P.
Date: 1 Sep 2016 11:52:42
Message: <57c84eca$1@news.povray.org>
Am 01.09.2016 um 16:46 schrieb William F Pokorny:
> of July 23, 2014!
That commit shouldn't have changed a thing for existing scenes; all the
added features should require extra keywords to enable: Radiosity
support for brilliance, for instance, should require `brilliance on` in
the radiosity block.
BTW, with all the updates you have sent, I notice that I'm losing track
of which differences in output you've noticed between our "cornerstone"
versions (official 3.7.0, feature/texture branch, and recent master
branch), what features you have found to be involved in those
differences, and what you have already managed to dig up about the exact
commit that changed the behaviour. If you could give me a summary, that
would be highly welcome.
(Sorry if I'm pestering you with this; I want you to know that your
research into this matter is very much appreciated.)
Date: 1 Sep 2016 12:28:19
Message: <57c85723$1@news.povray.org>
>> of July 23, 2014!
In summary:
With radiosity on, there are smallish radiosity differences between
3.7.0-stable and any 3.7.1 version on or after commit c891131. At the
moment I think these are ignorable as the cost of that fix.
With radiosity off, finish statements with brilliance>1.0 are
different/dimmer in 3.7.1 versions other than your latest
3.7.1-alpha.8738139 (refactor/texture). This change in behavior happened
with commit 54b283a as the commit prior (9b10411) matches 3.7.0-stable.
The scene file elsewhere attached to this thread can be used to
reproduce this result - though note you'll have to set the version to
3.7 as both commits came before the change to 3.7.1.
I am running on on Ubuntu 16.04.
Bill
Date: 1 Sep 2016 12:43:06
Message: <57c85a9a@news.povray.org>
Am 01.09.2016 um 18:28 schrieb William F Pokorny:
> In summary:
Hm... they might be due to the fix affecting the positions of the
radiosity samples gathered during pretrace. But I'm not entirely
satisfied about this yet.
If that is so, then the conclusion I'd draw is that I probably messed up
something in 54b283a when introducing the advanced finish features, and
fixed it during texture refactoring without realizing and/or remembering it.
Date: 2 Sep 2016 07:33:35
Message: <57c9638f$1@news.povray.org>
>> In summary:
I am not myself sure it explains all of what I see with radiosity, but I
believe that commit at least a partly the cause.
FYI. I've done some additional spot checking of cases where results were
changing. With these, I turned off radiosity and edited materials so
brillance was never more than 1.0. At least in the handful checked this
way, 3.7.0 -> 3.7.1 -> refactor/texture results compare well.
Bill P.
Date: 5 Sep 2016 08:33:42
Message: <57cd6626$1@news.povray.org>
The texture refactoring has progressed some more; in addition to the
features mentioned earlier, testing would be welcome for:
- Finish properties: Nothing should have changed here.
- Smooth meshes and other objects that "fake" a smooth surface: The
handling of surface normals /has/ changed, and should be more
well-behaved; most notably I should have gotten rid of the
interior_texture-on-outside artifacts!
Again, a source code-only version can be found here:
    https://github.com/c-lipka/povray/tree/refactor/texture
Am 10.08.2016 um 01:55 schrieb clipka:
> Folks,
> I have a special development version that needs exhaustive testing of
> complex textures, so if you have a scene that uses wild combinations of
> the following features (and you happen to be using Unix), it would be
> greatly appreciated if you could give it a shot:
> - patterned textures
> - material_map
> - layered textures
> - overriding the texture of objects
> - non-canonical syntax to define textures (e.g specifying `pigment`
> directly on an object)
> - any other texture-related stuff you can think of
> The version in question can be found here:
> (source code only at this time)
> Also, I expect more follow-up versions to be coming, so I might ask you
> to re-test with the same scenes later.
Date: 6 Sep 2016 06:33:02
Message: <57ce9b5e@news.povray.org>
The latest refactor/texture showing no differences on my non-mesh test
cases in some spot checking to the previous version.
I also wanted to flesh out the brilliance & radiosity differences story.
Where A-F represents the following POV-Ray versions:
A -> povray 3.7.0 stable
B -> 167ed19. Commit prior to c891131 Fixed two mesh camera bugs and
other camera flaws.
C -> 3c07635 Where the AA/shift of c891131 got fixed (but isosurface
offset still there)
D -> 4d52c26 Fixed a bug causing radiosity to ignore refracted
`no_image` objects.
E -> Previous refactor/texture. povray371Txtr_8738139
F -> Current refactor/texture.
So the rows in each attached image are comparing:
1) A to B
2) B to C
3) C to D
4) D to E
5) E to F
6) A to F
Showing the absolute difference mutiplied by 4x in the right most column.
1) A to B - The brilliance change of 54b283a.
2) B to C - The camera fixes of c891131.
3) C to D - Additional change some, not all in compensation of (2).
4) D to E - Mostly that refactor/texture code restored brilliance >1.
5) E to F - No change between last and current refactor/texture.
6) A to F - Surprise! With brilliace>1 quite a bit of radiosity difference.
1) A to B - Minor radiosity driven differences.
4) D to E - No last refactor/texture to base 4d52c26
6) A to F - Believe mostly the result of c891131 & something between C & D.
1) A to B - No difference.
2) B to C - Seeing the isosurface issue fixed with 0889275. (Yes affects
Rad a little)
3) C to D - Seeing the isosurface issue fixed with 0889275.
4) D to E - No difference.
5) E to F - No difference between last and current refactor/text.
6) A to F - No difference.
I think most everything can be ignored except the surprise A-F
radiosity results where the brilliance>1.0 is having a surprising effect
on radiosity compared to 3.7.0 stable.
I'm off to try this latest refactor/texture with additional scenes -
especially some with meshes.
Bill P.
Download 'story_brill_grtr1_wrad.jpg' (167 KB) Download 'story_brill_max1_norad.jpg' (135 KB) Download 'story_brill_max1_wrad.jpg' (141 KB)
Preview of image 'story_brill_grtr1_wrad.jpg'
Preview of image 'story_brill_max1_norad.jpg'
Preview of image 'story_brill_max1_wrad.jpg'
Date: 6 Sep 2016 07:05:08
Message: <57cea2e4$1@news.povray.org>
> Bill P.
Ah, looks like something changed in this last release to better align
the metallic keyword behavior with 3.7.0-stable - good! I'd not before
picked up this difference.
Bill P.
Download 'storynk0226_brill_max1_norad.jpg' (105 KB)
Preview of image 'storynk0226_brill_max1_norad.jpg'
Date: 6 Sep 2016 16:36:14
Message: <57cf28be@news.povray.org>
> Bill P.
Found a case where some shadows changed with the last refactor/texture
and stayed the same with this last version. Experimented quite a bit and
unable to find a normal or finish option which triggers it though able
to change the signature in the shadows some.
Files attached. (Differences at 8x absolute value to better see them)
Maybe this is a case which will let us run down the differences in
shadow rays & shadow cache numbers...
FYI - I'd argue differences small enough to ignore in this material, but
does appear to be a change due the texture refactoring.
Bill P.
Download 'nk0278__e.pov.txt' (5 KB) Download 'storynk0278_brill_max1_norad.jpg' (229 KB)
Preview of image 'storynk0278_brill_max1_norad.jpg'
