POV-Ray : Newsgroups : povray.beta-test : Isosurface: max_gradient warning? Server Time
17 May 2024 18:01:08 EDT (-0400)
  Isosurface: max_gradient warning? (Message 11 to 20 of 20)
Subject: Re: Isosurface: max_gradient warning?
Date: 23 Jun 2013 12:35:01
Message: <web.51c722c522807ec9540235480@news.povray.org>
"Cousin Ricky" <rickysttATyahooDOTcom> wrote:
> Since I never suspected thread safety until you brought it up, I had not tried
> it with +WT1.  I just tried +WT1 with Mr. Pokorny's scene, and there was no
> warning.
A reason to keep 3.6 hanging around (at least until 3.7.1): to test isosurface
functions?
(There is at least one other reason: the crackle pattern changed in 3.7, with no
provision for backwards compatibility.  Doctor John's coderot scene renders
quite differently, for example.)
Date: 23 Jun 2013 13:13:10
Message: <51c72ca6$1@news.povray.org>
On 06/23/2013 04:27 AM, Le_Forgeron wrote:
> Le 22/06/2013 15:57, Thomas de Groot nous fit lire :
>> On 22-6-2013 10:38, Le_Forgeron wrote:
> So, I cannot duplicate the original issue, at least on the unix port.
>> Whatever value for max_gradient I use (too low or too high) the
>> expected warning never appears in the message window like it used to
>> do. I need it to determine the values for evaluate.
> The only difference is less context.
> Or is it a Windows specific issue ? (I hope not)
It seems to be the case the gradient warnings are only generated if the
isosurface is naked. If it is wrapped in an object as was the case with
my thread safety example, we get no warnings.
Inserting some comments in the IsoSurface::DispatchShutdownMessages code
as follows:
//------------------------ code -------------
mginfo->max_gradient = max((DBL)temp_max_gradient,mginfo->max_gradient);
    cerr << "In DispatchShutdownMessages" << endl;
         if (isCopy == false)
    cerr << "isCopy false" << endl;
                 FunctionCode *fn = vm->GetFunction(*(Function));
                 if (fn != NULL)
    cerr << "fn not NULL" << endl;
                         if (eval == false)
    cerr << "eval == false" << endl;
                                 // Only show the warning if necessary!
it looks like the "if (isCopy == false)" does not test positive when the
isosurface is wrapped in an object, but it does when the isosurface is
naked.
Bill P.
Date: 23 Jun 2013 14:00:11
Message: <51c737ab@news.povray.org>
> as follows:
>                  if (fn != NULL)
>                          if (eval == false)
> naked.
> Bill P.
I'm wondering when it was broken, or if that's the intended behavior ...
perhaps some kind of note in the documentation /might/ be the way to go.
Just a thought.
Date: 23 Jun 2013 14:05:00
Message: <web.51c7385122807ec9fb5cc2da0@news.povray.org>
> as follows:
>                  if (fn != NULL)
>                          if (eval == false)
> naked.
> Bill P.
First I can confirm Thomas issue, but I cannot remember if it was the change
from 3.6 to 3.7 or from a release candidate of 3.7 to the next as the
max_gradient warnings disappeared. My quick work around is simple: if you see
black holes: rise it. If you trace an isosurface (exspecially for camera
position) and you yield a black image you most likely dropped through a black
whole due to this issue: rise it too. This occurs for example using randomized
camera locations within Jaime's project tierra. It would be fine to have a guess
how much to rise it as we had in the past, which would save the one or other
rendering hour of course.
But what is a "naked isosurface"? Isosurfaces must be contained in a container
object. Having Poser, I only can imagine "naked" mesh objects ... ;-)
Best regards,
Michael
Date: 23 Jun 2013 15:24:00
Message: <51c74b50$1@news.povray.org>
Le 23/06/2013 20:00, James Holsenback nous fit lire :
>> naked.
>> Bill P.
> Just a thought.
isCopy seems to be intended to avoid displaying the same warning over
and over for the same isosurface (as duplicated isosurface indeed are
not copied but reference the same sub-structure).
#declare Ob = isosurface{...}; // that's not a copy
object {Ob ... } // that's a copy
Previously (3.6.1) the warning was displayed at the destruction of the
isosurface (when the sub-structure was actually referenced by no one else)
  if((Stage == STAGE_SHUTDOWN) && (mginfo->refcnt == 0))
In 3.7, isCopy was introduced with change 4707, 16th February 2009,
along with the change introducing means for objects to submit message on
shutdown.
It was reported in windows source with change 4714, 21th February 2009.
If the symptom "isosurface embbeded in object (CSG) does not show the
warning" is correct, it might be a "feature/bug". The parser copied the
isosurface object and deleted the original before the render started.
When the render ends, it find only copies and because the refcnt is not
used anymore (for that purpose), it miss the last remaining true data to
display.
Instead of isCopy, what about adding in mginfo a boolean
"printed_warning" (actual name should be more appropriate), set to false
on creation, and turn to true on the first call (instead of last for
3.6.1) of the warning displaying function (test for false, set to true
if false) ? (and dropping isCopy in the process)
For instance, i'm afraid the following sequence would fails with current
code:
#declare Foo = isosurface{ ... };
#declare Bar = object { Foo ... };
#undef Foo;
(or any pop of #local context, such as building the isosurface via macro
or loop, or replacing the value of a previous #declare/#local )
Date: 23 Jun 2013 15:31:17
Message: <51c74d05$1@news.povray.org>
>>> naked.
>>> Bill P.
>> Just a thought.
> shutdown.
> display.
> code:
> #undef Foo;
Ok that explains when it happened (nice detective work btw) ... I'm
starting to think that the isosurface documentation needs to reflect the
change in behavior.
Date: 23 Jun 2013 15:44:15
Message: <51c7500f@news.povray.org>
The problem with that is that all copies of the same isosurface object
would need a shared variable, which has to be separate for all distinct
isosurface objects, unless it's enough to print a warning about one
isosurface object and ignore the rest.
Date: 23 Jun 2013 21:25:08
Message: <web.51c79e9d22807ec9540235480@news.povray.org>
Confirmed.  If only I still had the concentration required to investigate
computer code.
[code]
#version 3.7;
#ifndef (MG) #declare MG = 40/9; #end
#ifndef (Naked) #declare Naked = no; #end
global_settings
{ assumed_gamma 1
  radiosity {} //force isosurface calculations from all directions
light_source { <-3.3125, 7.6250, -5.7374>, rgb 1 }
camera
{ location <0.0000, 1.0000, -5.6713>
  look_at <-0.7969, 1.2000, -0.0598>
  angle 10.7447
#include "functions.inc"
#if (Naked)
  isosurface
  { function { f_sphere (x, 0, z, (2660 - 40*y) / 9) }
    contained_by { box { <-80, 31, -24>, <-128, 56, 24> } }
    max_gradient MG
    pigment { rgb <1, 0.75, 0> }
    scale 1/128
    rotate -35 * x
    translate y
#else
  #declare Test = isosurface
    max_gradient MG
    scale 1/128
    rotate -35 * x
    translate y
  object { Test }
[/code]
On the command line, try:
  declare=MG=1 declare=Naked=1
and
  declare=MG=1 declare=Naked=0
To lose the warning, I had to declare the isosurface.  Just wrapping the naked
isosurface in an object{} generated a warning.
Date: 24 Jun 2013 03:04:30
Message: <51c7ef7e$1@news.povray.org>
It is an isosurface not wrapped into an object by #declare or #local. I
can indeed confirm too that this is the true cause.
My suggestion (my 2 cents) would be to leave things as they are now, but
to explain the behaviour in the Docs. If a user wants to test the
max_gradient value he can write an #if #else switch like Bill did below.
Good spotting by the way by those who found the answer.
Date: 24 Jun 2013 03:08:20
Message: <51c7f064$1@news.povray.org>
Le 23/06/2013 21:44, Warp nous fit lire :
From my understanding, the function is already shared (in the mginfo
sub-structure) (indeed, mginfo currently store the max_gradient and more
data too), so, if it come from the same declaration of function, it make
sense to report the warning only once. That won't solve the tricky
non-thread-safe issue on max_gradient, but would restore a behaviour
similar to 3.6.1: for each copies of the same isosurface (but
transformation & friends), display the warning only once (but at least
once).
