POV-Ray : Newsgroups : povray.beta-test : Parser Statistics anomaly Server Time
15 May 2026 17:33:47 EDT (-0400)
  Parser Statistics anomaly (Message 1 to 10 of 18)
Subject: Parser Statistics anomaly
Date: 6 Dec 2012 10:53:18
Message: <50c0bf6e$1@news.povray.org>
Simple scene:
#version 3.7;
camera{ location <0,2,-10> look_at <0,0,0> right
x*image_width/image_height direction z*1 }
light_source{ <0,5,-10>,1 rotate y*45 }
global_settings {
	assumed_gamma 1.0
#declare SkyDome =
sphere{0, 1 hollow
   	pigment { srgb 1 }
		finish {
			ambient 0
			diffuse 0.6
object { SkyDome rotate x*0 rotate y*0	scale 5000}
noticed an oddity with the infinite/finite object count reporting ...
play with scale of the SkyDome object ... as is it's calling the object
Infinite?
Subject: Re: Parser Statistics anomaly
Date: 6 Dec 2012 11:33:15
Message: <50c0c8cb$1@news.povray.org>
Le 06/12/2012 16:53, James Holsenback nous fit lire :
> Simple scene:
> #version 3.7;
> global_settings {
>     assumed_gamma 1.0
> #declare SkyDome =
> sphere{0, 1 hollow
>     texture {
>       pigment { srgb 1 }
>         finish {
>             ambient 0
>             diffuse 0.6
> Infinite?
an object is considered infinite when it is big enough... or rather its
bounding (box) is big enough. How is big computed ? It's a volume. Above
2.0e+10, it's big.
So, a cylinder/cone along an axis could be 10 000 000 long and be finite.
The same on a diagonal of face (49 999 988 518 489 square-unit for the
same length, if I do not fail the computation of the projected length on
the axis) is infinite. Just because the bounding box get promoted to a
big empty box.
your skydome:
radius = 5000, so diameter 10000, in a box that's a volume of 10^12.
Which is bigger than the 2.0e+10.
Date: 6 Dec 2012 11:39:41
Message: <50c0ca4d$1@news.povray.org>
>> Simple scene:
>> #version 3.7;
>> global_settings {
>>      assumed_gamma 1.0
>> #declare SkyDome =
>> sphere{0, 1 hollow
>>      texture {
>>        pigment { srgb 1 }
>>          finish {
>>              ambient 0
>>              diffuse 0.6
>> Infinite?
play around with the scaling and see when it starts to call it finite ;-)
Date: 6 Dec 2012 13:16:00
Message: <50c0e0e0$1@news.povray.org>
Le 06/12/2012 17:39, James Holsenback nous fit lire :
I don't play... I cheat & I looked at the code.
In parse.cpp, BOUNDS_VOLUME is an inline function from bbox.h which
compute the volume of the bounding box (simple product of height, width
& depth).
INFINITE_VOLUME is the limit to set the infinite flag.
The value of INFINITE_VOLUME is BOUND_HUGE. (parse.cpp)
The value of BOUND_HUGE is 2.0e+10 (configbackend.h)
So, the sphere is to become finite when the box (true cube) is to have a
volume of 2.0e+10 or less. That's for a side of 2714.4176 (cubic root of
2.0e+10), so for a radius of 1357.2088
Date: 6 Dec 2012 13:30:18
Message: <50c0e43a@news.povray.org>
What exactly is the advantage of this?
Date: 6 Dec 2012 13:48:17
Message: <50c0e871$1@news.povray.org>
> & depth).
Yes ... obviously the program is catching something, I guess I'm
challenging /what/ it's catching. Again I'm encouraging you to /play/
around with the scaling in my example and note /when/ it starts calling
the object finite ;-)
Date: 6 Dec 2012 15:44:07
Message: <50c10397$1@news.povray.org>
Am 06.12.2012 19:48, schrieb James Holsenback:
>> & depth).
So, what are the results of /your/ playing around that makes you think
we should bother to try it as well?
Date: 6 Dec 2012 15:46:22
Message: <50c1041e@news.povray.org>
Am 06.12.2012 19:30, schrieb Warp:
If an object is virtually everywhere, testing against its bounding box
is wasted computing time.
Date: 6 Dec 2012 16:16:54
Message: <50c10b46$1@news.povray.org>
>>> & depth).
LOL ... starting with the simple scene it does not report finite until
scale is set to 1000
Date: 7 Dec 2012 00:20:33
Message: <50c17ca1$1@news.povray.org>
Am 06.12.2012 22:16, schrieb James Holsenback:
 From the math, the threshold should be between 1357 and 1358 if the
sphere is just transformed and/or rotated. (If a rotation is applied via
an arbitrary matrix, the threshold might be as low as 783 to 784 in
extreme cases.)
An infinite object is not excluded from bounding /per se/, but does not
benefit from /hierarchical/ bounding.
(Fun fact: Spheres have such a simple math that they skip bounding box
testing entirely, so they only benefit from hierarchical bounding at all.)
