POV-Ray : Newsgroups : povray.beta-test : Beta 37 changes to file gamma? Server Time
16 May 2026 00:36:29 EDT (-0400)
  Beta 37 changes to file gamma? (Message 21 to 30 of 30)
Subject: Re: Beta 37 changes to file gamma?
Date: 5 May 2010 07:51:11
Message: <4be15baf$1@news.povray.org>
Am 03.05.2010 20:25, schrieb JJ:
> I have the same problems with PovRay 3.7 beta 37.
> Previous beta version was OK for me : 3.7 beta 36. But for installation of beta
> 37 it was need to uninstall beta 36... Now all pictures are white...
> I tried with this ini seetings:
> ; Persistence Of Vision raytracer version 3.5 sample file.
> File_Gamma = 0.980
> Display_Gamma = 0.980
> Antialias=On
> Sampling_Method=1
> Antialias_Threshold=0.1
> Antialias_Depth=4
> Input_File_Name=name.pov
> Output_Alpha=off
> Output_File_Type=N   ;; S= bmp, T=uncompressed tga&   N png output
> +w800
> +h600
> ;+w3200
> ;+h2400
> Cyclic_Animation=off
> Pause_when_Done=on
Are you sure these are the same settings that you used with beta.36?
To be frank, I can't imagine you used PNG output when working with
beta.36 - because with PNG files, it doesn't matter what encoding gamma
(derived from File_Gamma) is used: They will only seem to match the
render preview if you set the proper Display_Gamma for your system
(provided the image viewer does a proper job).
Anyway, a beta.37a is just about to be released that will restore
beta.36 gamma behavior.
Date: 5 May 2010 08:50:00
Message: <web.4be168fc90dc9ef6cdadb0b0@news.povray.org>
> > File_Gamma = 0.980
> > Antialias=On
> > Sampling_Method=1
> > Antialias_Depth=4
> > Output_Alpha=off
> > +w800
> > +h600
> > ;+w3200
> > ;+h2400
> > Pause_when_Done=on
Hello Clipka and Alain,
If two povman have the same problem, may be they are a problem somewhere in the
beta 37?
I use this ini file:
> > File_Gamma = 0.980
> > Antialias=On
> > Sampling_Method=1
> > Antialias_Depth=4
> > Output_Alpha=off
> > +w800
> > +h600
> > ;+w3200
> > ;+h2400
> > Pause_when_Done=on
 With file gamma AND (so both) Display gamma values 0.98, 1.0, 2.0 and 2.2,  the
picture in the povray window and the picture in the file is not the same for
povray 3.7 beta 37 but it was OK with the previous version. My input files are
all the same, but with beta 37 the gamma is not the same. It's to much time ago
that I don't use v3.6. But finally, may be I will return back to v 3.6 because
the time need for rendering picture is the same with v3.7 beta 37 so why to use
full charge of the CPU for the same result and time consuming.
- So how to obtain the same gamma settings in the povray render windows and file
and which file format you recommand for povray 3.7 beta 37 windows XP, Vista and
7.
- If it is possible to find the previous version somewhere?
many thanks for your advices,
best regards,
JJ
Date: 5 May 2010 10:05:39
Message: <4be17b33$1@news.povray.org>
Am 05.05.2010 14:47, schrieb JJ:
> beta 37?
Believe me, one of the primary principles I go by when assessing alleged
software errors is that the software /is/ guilty unless evidence
/strongly/ indicates otherwise. So typically I'd try to reproduce the
error scenario as faithfully as possible, and see if the error does
occur or not. If it doesn't, next assumption is that I /misunderstood/
the error scenario, so I start toying around within different
interpretations of the description. If that still doesn't produce the
reported error, I go by the assumption that the error scenario was not
/described/ properly, so I toy around even more. Only if I run out of
ideas what might have gone wrong with the /communication/ about the
error (and believe me, I'm quite creative at that) - or if during the
process I find a scenario which plausibly fits the error description but
is definitely not a bug - do I find the software not guilty.
I did some tests here, and I did find that in the scenario you
described, beta.36 /does/ give the very same results as you report for
beta.37.
Also note that as of now, you are the /only/ person reporting this very
error; Quietman's problem was obviously of different nature, as the
proposed workaround did work for him.
So I do repeat: I cannot find anything like what you report in beta.37
(aside from the File_Gamma=1.0 issue seen by Quietman) that hadn't been
there in beta.36 as well.
I'm not saying you can't possibly see what you claim to be seeing - but
I do suspect that the File_Gamma=1.0 bug in beta.37 found by Quietman
motivated you to have a much closer look at Gamma than ever in beta.36,
and now you're surprised about 3.7 behavior that has been there for
quite a while already, and you just never encountered it before. To me,
the most plausible assumption is that you never tested with PNG output
file format in beta.36 and earlier.
That's not what I see here:
- I /do/ see outright /broken/ behavior in beta.37 with File_Gamma=1.0.
but not for 0.98 or 2.0 or 2.2.
- I also /do/ see gamma discrepancies between preview window and written
file for some other combinations of File_Gamma, assumed_gamma and output
file type, but I do see those very same effects with beta.36 as well.
So my conclusion is that yes, beta.37 does behave as you report, but
your memory of beta.36 behavior is not as accurate as you believe.
> 7.
I strongly recommend to:
(0) Do /not/ use assumed_gamma anymore.
(1) Set Display_Gamma to a value that does really fit your display
subsystem - so that you see in the preview window what POV-Ray expects
you to see.
(2) If your display subsystem gamma is significantly different from 2.2,
make sure that your image viewing program is aware of this fact - so
that you see in your image viewing software what that software expects
you to see (and what POV-Ray expects you to see there).
(3) Use File_Gamma=2.2 unless you want to generate height field data
(unless you are perfectly sure you will never want to view the images on
any other computer or share them via internet) - so that any person
(including you possibly) viewing the output images on any other computer
or with any other image viewing software have the best chance of seeing
what POV-Ray expects them to see in those images.
(4) Depending on what you intend to do with the image, use either
OpenEXR (because it's simply the best) or PNG (because it's one of the
two most common, and does increases the chance of being displayed
properly on other computers) as output format, or JPEG if you don't
intend to post-process it (because it's the other of the two most common).
(5) Design your scenes to look good with these settings right from the
start.
For /legacy/ scenes, make sure to use the "#version 3.6;" statement (or
whatever applies), /do/ use the "assumed_gamma" statement, and do /not/
use the "File_Gamma" setting. Also, do /not/ use PNG output, but rather
BMP or some such.
The POV-Ray dev team has no interest whatsoever in older betas being
circulated freely. You may want to test the brand-new beta.37a though,
which fixes the issue reported by Quietman; I also gave it some thorough
testing to verify that behavior is really identical to beta.36 again
regarding output gamma. (See http://www.povray.org/beta/)
Date: 5 May 2010 22:08:37
Message: <4be224a5$1@news.povray.org>
>>> File_Gamma = 0.980
>>> Antialias=On
>>> Sampling_Method=1
>>> Antialias_Depth=4
>>> Output_Alpha=off
>>> +w800
>>> +h600
>>> ;+w3200
>>> ;+h2400
>>> Pause_when_Done=on
> beta 37?
>>> File_Gamma = 0.980
>>> Antialias=On
>>> Sampling_Method=1
>>> Antialias_Depth=4
>>> Output_Alpha=off
>>> +w800
>>> +h600
>>> ;+w3200
>>> ;+h2400
>>> Pause_when_Done=on
> 7.
> best regards,
> JJ
My ini file DON'T contain ether File_Gamma nor Display_gamma and my
renders show and display correctly.
Maybe it's a problem that occurs only when you explicitely set those
parameters...
Date: 6 May 2010 01:56:11
Message: <4be259fb@news.povray.org>
On 29/04/2010 18:56, Thomas de Groot wrote:
> OK. Anyway, the choice was taken out of hands as beta 36 crashes when going
> automatically to the update site. I produced a mini-dump file, should I send
> it somewhere? Have others the same experience?
I'd like to get the mini-dump please - can you email it?
-- Chris
Date: 6 May 2010 03:40:51
Message: <4be27283$1@news.povray.org>
"Chris Cason" <del### [at] deletethistoopovrayorg> schreef in
bericht news:4be259fb@news.povray.org...
>> going
>> send
OK. I send an e-mail with the mini-dump file attached, to the address
indicated in the licence page. Subject name of mail will be "mini-dump of
crash version 3.7"
Date: 6 May 2010 05:05:44
Message: <4be28668@news.povray.org>
> of crash version 3.7"
Got it, thanks a lot, it enabled me to find the bug.
-- Chris
Date: 6 May 2010 09:52:20
Message: <4be2c994$1@news.povray.org>
bericht news:4be28668@news.povray.org...
Glad to have been of help  :-)
Date: 7 May 2010 09:00:41
Message: <4be40ef9$1@news.povray.org>
Am 27.04.2010 23:39, schrieb Quietman:
> The display seems ok but the output file is lighter, even with the
> default file type (BMP).
Any feedback on beta.37a behavior in this respect? Anyone still
experiencing gamma issues?
Date: 11 May 2010 12:45:01
Message: <web.4be9889290dc9ef6cdadb0b0@news.povray.org>
> To set both to the same thing, use the same value in the ini file.
> Set Display_Gamma to the gamma of your system. It sets the gamma for the
> preview.
> Set File_Gama to that same value or 2.2
> Maybe you have a problem with your viewer.
> Alain
Alain,
Thanks for your advices, it seems near to be OK with beta 37a now. Just need to
adjust a little bit.
Best,
JJ
