POV-Ray : Newsgroups : povray.beta-test : POV-Ray 3.7 gamma - status Server Time
26 Apr 2026 01:46:28 EDT (-0400)
  POV-Ray 3.7 gamma - status (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: POV-Ray 3.7 gamma - status
Date: 16 Sep 2009 11:53:55
Message: <4ab10a13@news.povray.org>
Le 15/09/2009 23:12, Thorsten Froehlich nous fit lire :
> Warp wrote:
>>   Sounds good to me. One minor thing, though:
>> clipka <ano### [at] anonymousorg> wrote:
>>> - The assumed input file gamma (to be used for all input file formats
>>> lacking a proper definition or recommendation) can be set in the
>>> global_settings section as follows:
>>>      global_settings {
>>>          file_gamma GAMMA
>>   I think the keyword is a bit confusing because it doesn't make clear
>> whether it affects input files or output files. Could perhaps a more
>> unambiguous keyword be chosen, something like "input_gamma"?
> Globals are evil. I would instead recommend making this a bitmap only
> feature, not supplying a global setting.
>     Thorsten
OMHG... I'm agreeing with Thorsten.
That's a parallel univers, I will wake up soon.
More seriously, put it where it is needed: near the file picture!
That's a setting which is really tuned to the related file.
A global would have no more purpose than a global setting for text (you
can always justify the usage of a global text font setting... but nobody
ever came so far with such suggestion)
Date: 16 Sep 2009 13:08:41
Message: <4ab11b99$1@news.povray.org>
You didn't pay much of attention, did you? There /is/ an (optional)
per-file setting.
But I can well imagine that there are people out there who prefer to
/consistently/ work with files pre-corrected for some other gamma space
than sRGB for one reason or the other, hence the additional global
setting: To customize the default.
Maybe that's because the text{} statement /requires/ you to specify a
font, and there's no default that a user could possibly hope to customize.
You could just as well argue that there's not much purpose in a default
{ finish {...} } statement - after all, don't the finish settings belong
to the individual material?
Date: 17 Sep 2009 08:39:45
Message: <4ab22e11$1@news.povray.org>
clipka schrieb:
> - Image-format input files used immediately in certain language
> constructs obviously indicating that they are mere data containers (e.g.
> height fields) shall be exempt from the aforementioned conversion, and
> the raw encoded values used instead. (Note however that this does not
> apply to indirect use of input image files.)
It would OTOH be nice if POV-Ray would treat images the same way
everywhere (it does not in 3.6 either but that's a different story).
> - Non-paletted integer images are kept in "native" format without
> applying gamma adjustment, in order to save memory. Gamma correction is
> instead applied at render time, using a pre-computed lookup table in
> hope of gaining a bit of a speed advantage. (Lookup tables are shared
> between images with the same gamma curve of course.)
A dynamic caching scheme for converted values would be an alternative -
significantly more complex to implement of course.
As long as this is only about gamma correction this is probably
unnecessary but with color space conversions on-the-fly conversion might
be too expensive.
-- Christoph
Date: 17 Sep 2009 09:43:04
Message: <4ab23ce8@news.povray.org>
>> (e.g. height fields) shall be exempt from the aforementioned
>> conversion, and the raw encoded values used instead. (Note however
>> that this does not apply to indirect use of input image files.)
Well, I think there's some reason to both sides; with the per-file gamma
setting it becomes less of a problem at any rate.
>> is instead applied at render time, using a pre-computed lookup table
>> in hope of gaining a bit of a speed advantage. (Lookup tables are
>> shared between images with the same gamma curve of course.)
... and quite definitely more overhead than gain for an 8-bit/channel
image, and possibly so as well for a 16-bit/channel image (except for
images so small that it would become worthwhile to convert them to float
right away at load time). It might also be questionable whether it would
be faster than just recomputing the value.
> be too expensive.
For some "norm" color spaces, I think the per-color lookup table
approach might still be both possible and worthwhile - especially for
8-bit/channel images - if separate lookup tables are used for each color
channel, and each entry would store an RGB color instead of a scalar;
those would then be just added - sort of a shortcat halfway through the
matrix transformation found in various color space transformations.
Of course for full-fledged device color profiles this wouldn't be
sufficient.
Date: 17 Sep 2009 12:24:27
Message: <4ab262bb$1@news.povray.org>
clipka wrote:
> - POV-Ray shall always operate in a linear RGB color space based on
> light intensity (as opposed to perceived brightness), to properly
> compute physical effects. (In the long run, this should also include a
> clear definition of the RGB primaries and white point, but at present
> this definition is limited to gamma issues.)
> - In General, all image-format input files sall be converted to
> POV-Ray's operating color space before any further processing. (In the
> long run, this should include full color profile handling; however, at
> present it is limited to gamma correction.)
So meanwhile you do agree with me that POV-Ray should have "in the long
run" a well defined RGB color space while I do remember a few months ago
we had some struggle about this issue ;)
> - For file formats with an official specification...
 > [SNIP (a lot)]
Sounds all very good to me.
> * Implementation
 > [SNIP]
I already wanted to ask you about this - as at some point it seemed to
me you intend to store all data in floating point format - but then I
did completely forget about it.
While I think it is a very good idea to use lut's for 8 bps I do believe
it should not be done for 16 bps as they are meant to apply things like
inverse gamma correction without *any* visual impact. But this is not an
important issue.
And BTW I've rewritten tiff.cpp from scratch and the most simple and
basic cases is already working: RGB data that is ordered interleaved
(and not in separate color planes) arranged in strips (and not tiles)
and uses unsigned 8 or 16 bit integers (not signed ones).
The nice thing is that full floating point HDR TIFF support for 16bit
(the same 'half' format as used by OpenEXR), 24bit (yes, such a thing
exists) and 32bit (the 'normal' float) is already working.
And I intend to implement TIFF *output* for 32bit floats as I think it
would be nice to have this feature available especially within an
already well defined image file format.
So sooner or later I need to know more details about your implementation
of the file gamma correction but most probably I will not finish the new
TIFF implementation befor the next beta is out...
-Ive
Date: 17 Sep 2009 15:12:14
Message: <4ab28a0e@news.povray.org>
Ah yes? Did we?
If you're thinking of statements from me like "what's the point in
having perfect ICC profile handling if POV-Ray gets the gamma wrong"
(about a workaround I had described for the gamma issues with POV-Ray,
involving an external tool that according to you doesn't do proper ICC
handling), and consider those an argument about ICC profiles, then yes,
in that case I guess we did :-)
> important issue.
Indeed it isn't: The framework has been set up now, and adjustments to
the handling should be quite easy. Including stuff like, checking for
the file size and depending on that choosing whether to convert directly
to float or use lookup.
Great to hear those things!
It's actually quite easy as far as the image reading code is concerned.
Nothing that would require a dramatic change in image reading code.
Date: 21 Sep 2009 02:10:20
Message: <4ab718cc$1@news.povray.org>
Could be.
One field where i consider performance to be possibly critical is use of
images in isosurfaces.  This leads to a real lot of image evaluations.
There however you nearly always use a linear gamma curve.  So a special
case for images where file_gamma is exactly 1.0 would be a good idea.
-- Christoph
Date: 21 Sep 2009 08:04:37
Message: <4ab76bd5@news.povray.org>
That's already implemented :-)
In case the effective decoding gamma curve happens to be neutral, the
file readers choose an image container that does not do gamma lookup at
all, and just does the standard "/255.0f" decoding instead.
Date: 25 Sep 2009 01:27:58
Message: <4abc54de@news.povray.org>
> important issue.
What if it's a lookup table that maps a 16-bit integer into a 32-bit float?
There wouldn't be any visual impact there...
Date: 25 Sep 2009 07:52:46
Message: <4abcaf0e$1@news.povray.org>
>> important issue.
I think what Ive means is that 16 bit per color channel should already
provide enough "headroom" to do the gamma correction in that format.
