POV-Ray : Newsgroups : povray.beta-test : Gamma in POV-Ray 3.6 vs. 3.7 Server Time
13 Mar 2026 00:42:50 EDT (-0400)
  Gamma in POV-Ray 3.6 vs. 3.7 (Message 46 to 55 of 75)
Subject: Re: Gamma in POV-Ray 3.6 vs. 3.7
Date: 13 Sep 2009 06:42:58
Message: <4aacccb2$1@news.povray.org>
MDenham schrieb:
> *goes off to figure out a good syntax for true spectral
> lighting and pigmenting, which is probably more in the realm of additions to
> 4.0 or later but would allow for "true" conversions both ways as well as other,
> odder effects*
Yeah, that would be something nice to have.
Including fluorescence, please :-)
Date: 13 Sep 2009 09:39:25
Message: <4aacf60d$1@news.povray.org>
MDenham wrote:
> Eh, negative luminance + positive Cr/Cb = <+,-,+> potentially (forgive the
> massively bastardized variation on standard color syntax ;-D) - and negatives
> on green are, from looking at normal "RGB vs. real coloring" gamut diagrams,
> probably the most common colors that exist but aren't displayable.  Also, the
> engine already handles "impossible" colors (components all negative,
> hypersaturated colors that extend outside the gamut in the opposite direction,
> &c.) so it's not like that's necessarily an issue other than the obvious "it'll
> look weird and may not behave entirely correctly".
Jpeg's YCbCr is a 1:1 adaption of the European standard tv signal
encoding (CCIR/ITU Rec. 601 IIRC) with the advantage that you can just
drop the CbCr part. This did make people happy who couldn't afford a
color tv. Sending a signal with negative Y would have made people quite
unhappy 'cause you just imploded their brand new tv set ;)
Seriously, jpeglib uses a strict range checking anyway (to avoid such
issues as the DCT compression might introduce some noise) and YCbCr is
just not *designed* to represent anything outside the gamut of a tv
monitor from this time. Thats not as bad as it sounds because, if I'm
not mistaken, this gamut was even defined wider than the currently
accepted sRGB gamut.
> Isn't the "formula" for CMYK->RGB essentially specific to an "ideal" ICC
> profile?
An "ideal" CMYK ICC profile is somehow meaningless and does not exist.
Therefor such a 'formula' cannot exist and this was from the very
beginning my point ;)
What we have is a bunch of numerous international standards within the
printing business and an ICC profile is used to make clear to what
standard the CMYK separation does refer, tells something about the
intended ink set, raster...  and *a lot* more things.
> odder effects*
This is of course also something I would like to have, but as I'm not so
patient I'll wait with such things until computing power evolves much
more...
-Ive
Date: 13 Sep 2009 17:09:34
Message: <4aad5f8e@news.povray.org>
Ive wrote:
> I do also remember that I have a format specification
> somewhere but as this might even be on some old 3.5" disk chances are
> not very good that I will ever find it again.
http://www.wotsit.org/list.asp?al=I
Date: 14 Sep 2009 11:43:07
Message: <4aae648b$1@news.povray.org>
Ive schrieb:
> To make life easier that's the libpng call for getting the
> sRGB chunk information. For the sole purpose of gamma correction you can
> safely ignore the value that is returned as sRGB_intent.
How about just checking for "png_inf->valid & PNG_INFO_sRGB"? Shouldn't
that do the same job?
Another thing: The sRGB spec speaks of aiming to achieve an overall
viewing gamma of 1.125; am I however correct in assuming that decoding
sRGB-encoded material according to the sRGB decoding function will
nonetheless reconstruct the /linear/ data?
Otherwise, if sRGB-encoded data was expected to already account for that
desired viewing gamma, for raytracing purposes it would theoretically
have to be compensated for, both when decoding and encoding.
Date: 14 Sep 2009 12:19:56
Message: <4aae6d2c$1@news.povray.org>
You are aware that you are breaking the poor mans idea of encapsulation
by directly accessing the fields from png_inf ;)
And it's by no means time critical, so why not just use the API call?
The sRGB viewing gamma of 1.125 is just another (poor mans) attempt of
taking the environment illumination of some typical pc user into
account. There are much more complicated attemps from the ICC and I
really think we do not need to care about this.
-Ive
Date: 14 Sep 2009 12:27:04
Message: <4aae6ed8$1@news.povray.org>
-Ive
Date: 14 Sep 2009 13:23:15
Message: <4aae7c03$1@news.povray.org>
Because POV-Ray currently uses the same construct to check for presence
of a gAMA chunk?
No other reason.
So, in other words, it is indeed just a recommendation for viewing
software? Something like, "guys, this encoding scheme makes sure you can
reconstruct the linear data - we suggest however you don't just
compensate for actual hardware gamma, but also for viewing environment;
if in doubt, we suggest trying to achieve those 1.125". Did I get that
right?
Date: 14 Sep 2009 13:39:31
Message: <4aae7fd2@news.povray.org>
Le_Forgeron wrote:
> color srgb <1.8,0.5,0.5,0.5>
Ugly. When I see four components, I already have my mind trained to expect
the first three are RGB and the fourth is transparency (which kind of
transparency depends on whether it's rgbf or rgbt).
Date: 14 Sep 2009 13:46:00
Message: <4aae8158@news.povray.org>
Warp wrote:
>   Of course if the user has not specified an assumed gamma for the input
> image either, then the default should probably be Display_gamma (ie. so
> that the image will look in POV-Ray the same it looks when viewed with
> some image viewing program).
Wouldn't this cause the scene to render differently on different computers,
in a way that cannot be easily corrected afterwards? (if the entire image
has wrong gamma, it can be corrected, but if a single texture image_map has
wrong gamma, you can't easily fix it by postprocessing the output image)
Date: 14 Sep 2009 13:57:50
Message: <4aae841e@news.povray.org>
That would be neat to have... But, how to implement? How would you
convert from an rgb-specified color to a spectrally specified color?
fluorescence would be quite fun to have. Impractical, but fun to play with.
At least with spectral colors and lights you could simulate metameric
failure.
~Mike
