POV-Ray : Newsgroups : povray.beta-test : Gamma tutorial for the 3.7 documentation? Server Time
29 Mar 2026 02:13:46 EDT (-0400)
  Gamma tutorial for the 3.7 documentation? (Message 6 to 15 of 35)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Gamma tutorial for the 3.7 documentation?
Date: 6 Sep 2009 18:18:58
Message: <4aa43552$1@news.povray.org>
Warp schrieb:
>> Likewise, how to pre-gamma-correct color values from
>> other programs (such as color pickers).
>   About that... I wonder if POV-Ray should offer some kind of function to
> do that, for convenience. In the same way as eg. degrees() and radians()
> exist for convenience, even though they don't really save a whole lot of
> work compared to if they didn't exist.
I think that definitely yes, POV-Ray should have such a feature. It is
perfectly possible to roll your own macro to do that, but if POV-Ray is
going the full way for proper gamma handling, it should - I'd even say
/must/ - provide some standard procedure to do it, if only to make a
clear statement along the lines of "yes, /this/ is the right way to deal
with it". And I'd go as far as to say that it should work without having
to include a particular file, so it should be a built-in language
contruct, not just a macro.
Date: 7 Sep 2009 04:35:45
Message: <4aa4c5e1$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4aa43552$1@news.povray.org...
> /must/ - provide some standard procedure to do it, if only to make a clear
> statement along the lines of "yes, /this/ is the right way to deal with
> it". And I'd go as far as to say that it should work without having to
> include a particular file, so it should be a built-in language contruct,
> not just a macro.
Sven Littkovski's neat little "POV-Ray Color Picker" (2006; version 2.0) is
a good example of such a picker. I use it quite a lot and I recommend it
warmly. Built into POV-Ray would be a nice addition.
Date: 7 Sep 2009 06:52:29
Message: <4aa4e5ed$1@news.povray.org>
>> not just a macro.
Well, I wasn't thinking about a built-in color picker, but a built-in
language syntax for gamma conversion.
Of course having its own built-in color picker would be a neat feature
(and I do second this idea), but for instance on Unix systems, where
POV-Ray does not come with an "IDE", a feature built into the SDL to
perform gamma conversion math would still be required.
Date: 7 Sep 2009 08:07:58
Message: <4aa4f79e@news.povray.org>
Are you aware that this tool (like most others) will not apply the
required inverse gamma correction and will result in the usual washed
out colors similar to jpeg image maps when used with 3.7 or
assumed_gamma 1.0 ?
And to mention it again: wrong gamma correction does not only give wrong
brightness intensities, it changes also the hue.
-Ive
Date: 7 Sep 2009 08:14:30
Message: <4aa4f926$1@news.povray.org>
"Ive" <"ive### [at] lilysoftorg"> schreef in bericht
news:4aa4f79e@news.povray.org...
>> is a good example of such a picker. I use it quite a lot and I recommend
>> it warmly. Built into POV-Ray would be a nice addition.
> required inverse gamma correction and will result in the usual washed out
> colors similar to jpeg image maps when used with 3.7 or assumed_gamma 1.0
Ah... yes...? I had not really/consciously thought of that... This means
that picking a color from a RGB/HSL color chart in any paint application
will show this problem?
Date: 7 Sep 2009 08:30:40
Message: <4aa4fcf0@news.povray.org>
Yes. Unless it does not explicit state that the working color space is a
linear one like e.g. scRGB (note the 'c'). You can use the histogram
window of IC and move the mouse across the viewing window to get the
color value of images in scRGB that could be used directly within
POV-Ray. Press CTRL + left mouse button to 'lock' any value. This makes
it easier when you move the mouse to the POV editor for writing the
value down ;)
Should I add the possibility to copy the color value directly to the
clipboard?
-Ive
Date: 8 Sep 2009 03:34:52
Message: <4aa6091c$1@news.povray.org>
news:4aa4fcf0@news.povray.org...
> window of IC and move the mouse across the viewing window to get the color
> value of images in scRGB that could be used directly within POV-Ray. Press
> CTRL + left mouse button to 'lock' any value. This makes it easier when
> you move the mouse to the POV editor for writing the value down ;)
I had not yet found that in IC (shame on me)
> clipboard?
Yes, that would be excellent.
Date: 8 Sep 2009 03:42:03
Message: <4aa60acb$1@news.povray.org>
By the way, there is a "palette" option in IC, but it is greyed out. How can
we use it? That would be the correct color picker...
Date: 8 Sep 2009 03:56:43
Message: <4aa60e3b$1@news.povray.org>
I guess that's for GIF files and such, so maybe not what you seem to
expect ;-)
Date: 8 Sep 2009 08:11:11
Message: <4aa649df$1@news.povray.org>
news:4aa60e3b$1@news.povray.org...
> expect ;-)
Oh pity.... I had high hopes..... :-)
I would like a *correct* palette as a color picker...
