POV-Ray : Newsgroups : povray.beta-test : 3.7b34: Don't know if this is legitimately a bug or just my own stupidity Server Time
28 Sep 2024 23:25:28 EDT (-0400)
  3.7b34: Don't know if this is legitimately a bug or just my own stupidity (Message 1 to 5 of 5)
Subject: 3.7b34: Don't know if this is legitimately a bug or just my own stupidity
Date: 3 Sep 2009 10:38:04
Message: <4a9fd4cc$1@news.povray.org>
The following is a minimal scene to reproduce this. It requires a
perfect storm of using a micronormal, blurring, and a high amount of
dispersion samples to cause POV-Ray to run away with allocating memory.
------ BEGIN POV CODE -------
#declare n1 = normal
     crackle .5
     scale 0.001
     accuracy 0.0001
#declare n2 = normal
     bumps 0
camera
     location <0, 0.2, -1>
     look_at <0.4, 0.3, 1>
     focal_point <0.4, 0.3-.0, 1>
     blur_samples 25
     confidence .9
     variance 0
     aperture .05
light_source
     <-10, 10,-5>, rgb 1.5
     area_light x*2,y*2,7,7 orient adaptive 2
sphere{ <0, 0, 0>, 0.5 pigment {color rgbf <0.85,1,.95,1>}
     interior
         ior 1.5
         fade_color rgb <0.0, 0.5, 0.0>
         fade_power 2
         fade_distance 10.5
         dispersion 1.1
         dispersion_samples 100
     normal {
         checker normal{n2} normal{n1}
         scale 0.1
         warp { spherical }
     translate z*1
------- END POV CODE ------
~Mike
Subject: Re: 3.7b34: Don't know if this is legitimately a bug or just my own stupidity
Date: 3 Sep 2009 11:08:37
Message: <4a9fdbf5$1@news.povray.org>
Runs OK in 3.6, I think this might actually be a bug.
~Mike
Date: 3 Sep 2009 11:47:10
Message: <4a9fe4fe$1@news.povray.org>
The memory consumption is alarming even without the dispersion, rising
as high as 1.6 GB for a 800x600 render on 8 threads.
The reason appears to be a humongous amount of crackle cache data: The
crackle pattern is only semi-procedural, requiring random values to be
computed and cached for subsequent queries, with a fixed amount of data
per unit-cube in crackle pattern coordinate space. Using crackle for
micronormals is therefore a bad idea: Scaled smaller than the density of
actual ray-object-intersections computed, it will eventually lead to a
separate crackle cache entry being created for each and every
intersection. Memory consumption will then grow with every additional
ray being traced, which is fatal with e.g. focal blur or dispersion that
create a huge amount of rays per pixel.
With bumps instead of crackle, memory requirements stay virtually at
idle level. Given that you can't make out the crackle structure at such
a scale anyway, that's the way to go. If you need a different
distribution of "slope probabilities" than the standard bumps pattern
(e.g. to simulate a basically polished surface with comparatively sparse
microsopic scratches), you may want to try bumps with a slope_map.
Subject: Re: 3.7b34: Don't know if this is legitimately a bug or just my ownstupidity
Date: 3 Sep 2009 12:07:05
Message: <4a9fe9a9$1@news.povray.org>
Oh, wow. I thought it was the dispersion + micronormal.
Makes sense...
Thanks for that. Honestly, I don't know why I was using crackle in this
scene in the first place.
(I've been going through old test scenes, doodles and such with 3.7 to
see how they render, etc...)
~Mike
Date: 4 Sep 2009 04:50:53
Message: <4aa0d4ed$1@news.povray.org>
"clipka" <ano### [at] anonymousorg> schreef in bericht
news:4a9fe4fe$1@news.povray.org...
> intersection. Memory consumption will then grow with every additional ray
Ah! It is good to be reminded of this. The crackle issue has come up earlier
already, but I confess that I almost forgot about it and so am often using
crackle in a micro normal. Thanks Christoph.
