POV-Ray : Newsgroups : povray.beta-test : Test 3.62 windows source archive Server Time
16 Jul 2026 12:45:01 EDT (-0400)
  Test 3.62 windows source archive (Message 1 to 10 of 10)
Subject: Test 3.62 windows source archive
Date: 19 Aug 2009 02:44:37
Message: <4a8b9f55@news.povray.org>
Folks,
I'd appreciate it if someone with VS2005 installed could take a stab at
building the project in http://www.povray.org/temp/povwin_s_3.62.zip.
The VS2005 project in that archive has been hand-converted from VS2008
format but not directly tested as I don't have a copy of that version of
VS handy at the moment.
Also anyone who wishes to do a test build with VS2008 is welcome to do so.
NB no instructions are (yet) included with the archive. However there's
nothing particularly different about building it vs prior versions (it
should be a case of just filling in the DISTRIBUTION_MESSAGE_2 macro and
hitting build).
thanks,
-- Chris
Subject: Re: Test 3.62 windows source archive
Date: 19 Aug 2009 06:32:16
Message: <op.uywnj1iz7bxctx@e6600>
Results so far:
- The 'libpng' subproject needs to have the include path to zlib added.
- The debug configuration creates a 'cmedit32d.dll' but the actual debug
executable looks for 'cmedit32.dll'. It does however use 'povcmax32d.dll'.
After overcoming those two obstacles, and copying 'povray.ini' to the
location where POV-Ray now expects to find it, I could run the demo render
without any noticeable issues with both debug and SSE2 configurations.
Tested with VS2005 and Boost 1.38.0.
FE
Date: 19 Aug 2009 16:37:08
Message: <4a8c6274@news.povray.org>
I tried it with C++ 2005 Express & Platform SDK. In this environment
it is hard to build the editor DLLs. Is it intentional that their build
is now enabled by default? Also, the project dependencies in the
solution properties were set so that povwin depended on the
cmedit and codemax project, causing the link to fail because
this implies a dependency of povcmax32(d).lib.
Furthermore, I added
   comctl32.lib gdi32.lib user32.lib kernel32.lib
   advapi32.lib shell32.lib
to the additional linker dependencies of povwin (I think the
normal version of Visual Studio links these by default but
having them in the project can't hurt).
After that (and fixing the zlib include for libpng) all
configurations compiled fine.
Finally, the project could define _CRT_SECURE_NO_DEPRECATE to suppress
the flood of deprecation warnings as use of the old style functions
would seem to be intentional anyway.
Sounds like a somewhat painful way of maintaining two project versions.
Note that Visual Studio 2005 and 2008 can coexist peacefully on the same
system. You could also install C++ Express 2005 just for editing the
project files - and some day the platform SDK to test the build ;)
Date: 19 Aug 2009 17:19:29
Message: <4a8c6c61$1@news.povray.org>
Come to think of it, in this scenario you probably already have a
platform sdk (or Windows SDK) which came with VS 2008 and you might
only need to point there.
Date: 19 Aug 2009 18:38:50
Message: <4a8c7efa@news.povray.org>
I'm travelling and only have my laptop, and don't really have room for
full parallel installs. I do have that setup at home.
If you would like to contribute a working VS2005 project with all the
listed problems fixed please feel free to email it to me and I'll
include it in the release (and probably re-import the VS2008 project
from it).
Also anyone who wants to write a 'how to build' readme is invited to do
so, sometimes it's better to get this done from the perspective of
someone who hasn't spent the past 15 years hacking on the source;)
thanks,
-- Chris
Date: 20 Aug 2009 15:47:01
Message: <4a8da835$1@news.povray.org>
> from it).
I sent you my adapted versions of the project files by mail.
Date: 23 Aug 2009 22:28:54
Message: <4a91fae6$1@news.povray.org>
>> from it).
Got it, thanks ... I've updated the source archive - please double-check
and if it's OK I can probably release it.
-- Chris
Date: 7 Sep 2009 19:20:30
Message: <4aa5953e$1@news.povray.org>
>>> from it).
Sorry for the delay I've been away for some time.
I just downloaded the updates source archive and it seems to include
the zlib include fix for libpng but *not* the modified dependencies
in povray.sln and and *not* the additional linker dependencies in
povwin.vcproj.
If you wish to reapply them it is probably best if you change
the settings directly on your side:
1. In project properties for povwin, select "All Configurations",
    and under Linker > Input set Additional Dependencies to:
comctl32.lib gdi32.lib user32.lib kernel32.lib advapi32.lib shell32.lib
2. In the solution properties, under
      Common Properties > Project Dependencies
    Select project povwin and uncheck the boxes next to
    the dependencies codemax and cmedit.
3. In the solution properties, under
      Configuration Properties > Configuration
    select "All Configurations" and uncheck the "build"
    boxes for codemax and cmedit.
Date: 13 Sep 2009 18:33:31
Message: <4aad733b@news.povray.org>
Thanks for the followup. I've updated the source, would you mind
checking it again?
regards,
-- Chris
Date: 14 Sep 2009 07:43:08
Message: <4AAE2D5A.4000803@chrfr.de>
> checking it again?
You had me confused with including an *older* version of povray.sln
compared to the previous archive but I think you replaced it with the
version I sent you earlier ;)
I tested 32-bit debug, release and release SSE2 in C++ Express 2005
and all three configurations built out of the box. I don't have
C++ Express 2008 so these files are untested.
I noticed belatedly that the build options are also specific to
the platform: only Win32 is currently modified. I don't see these
configurations in the GUI as I don't have a 64-bit Windows. I think
it is possible to build 64-bit binaries with c++ express after
installing the appropriate SKD, but I suppose the first user who
wants to do this will just have to figure it out on his own ;)
