POV-Ray : Newsgroups : povray.beta-test : Render Failed! Server Time
29 Mar 2026 17:11:47 EDT (-0400)
  Render Failed! (Message 1 to 6 of 6)
Subject: Render Failed!
Date: 16 Aug 2009 06:18:14
Message: <4a87dce6$1@news.povray.org>
While rendering a quite complex scene POV-Ray beta33 stopped after 15
hours (and 93% finished) and the only message on the message pane was
"Render failed!". Nothing else.
Hum. This is a bit laconic.
I've already done a lot of test renders with this scene before and it
never made any trouble.
Sorry to be not of much help here but I do not see how to narrow down
the problem, just thought I should mention it. The scene did use
radiosity, scattering media, meshes, hight fields and csg. System is
Windows XP SP3.
-Ive
Subject: Re: Render Failed!
Date: 16 Aug 2009 06:22:53
Message: <danf85hjrfrbhamfq42dd01sosg2o9f8q2@4ax.com>
As an aside when I was rendering with POV-Ray beta33, recently. My laptop just
shut down with no warning. I was able to finish the render using the +C command.
I hope that you get your image finished in tine ;)
Regards
Date: 16 Aug 2009 13:15:27
Message: <4a883eaf$1@news.povray.org>
Um... yes, I guess it is ;-)
Given the render time it may be a bit much to ask, but... is that
problem reproducible?
(If so, then it would probably make sense to send the scene to one of
the developers for further experimenting.)
 > The scene did use
> Windows XP SP3.
Can you give some indications about scene complexity (number of objects,
size of bitmaps used, and such)?
Date: 16 Aug 2009 14:46:30
Message: <4a885406@news.povray.org>
I'm not sure but I did various tests with one or more 'slow' features
disabled and it did work. I also did a low resolution render (about 120
x 80 pixel) with all features and it did also work. A test with MegaPOV
did indicate a peak memory usage of about 1.1 GB with 2 GB installed, no
other application was running and no tasks like virus scanners in the
background, output was OpenEXR and the display window was disabled
(display=off in povray.ini).
>  > The scene did use
>> Windows XP SP3.
Statistics with some additional output from my 'planting' macros but
without radiosity and scattering media:
Starting fern planting... 200 fern placed.
Starting small fern planting... 100 small fern placed.
Planting... 35 objects placed.
Planting... 50 objects placed.
Planting... 500 objects placed.
Starting grass patch generation... 34500 patches placed.
Starting grass patch generation... 14500 patches placed.
Starting grass patch generation... 3500 patches placed.
Parser Statistics
Finite Objects:        82110
Infinite Objects:         10
Light Sources:             3
Total:                 82123
Parser Time
   Parse Time:       0 hours  2 minutes 27 seconds (147.859 seconds)
               using 1 thread(s) with 123.078 CPU-seconds total
   Bounding Time:    0 hours  0 minutes  1 seconds (1.469 seconds)
               using 1 thread(s) with 1.437 CPU-seconds total
Render Options
   Quality:  9
   Bounding boxes.......On   Bounding threshold: 3
   Antialiasing.........On  (Method 2, Threshold 0.090, Depth 3, Jitter
1.00)
Render Statistics
Image Resolution 2000 x 1500
Pixels:          3191461   Samples:        16011510   Smpls/Pxl: 5.02
Rays:           40957111   Saved:             76351   Max Level: 12/12
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                             114150           59312     51.96
Cone/Cylinder                   676379          221786     32.79
CSG Intersection                163070           84873     52.05
Disc                            128547           23500     18.28
Height Field                 114715223        17405636     15.17
Height Field Box             114715223        59399814     51.78
Height Field Triangle         75183574        17410391     23.16
Height Field Block           723610295        46596909      6.44
Height Field Cell           1549371124        41385996      2.67
Mesh                        1176810291       316009500     26.85
Plane                        276541063         5934560      2.15
Sphere                          199824          129058     64.59
Torus                          2318550          460589     19.87
Torus Bound                    2318550          531269     22.91
Triangle                     326928313        35768833     10.94
Clipping Object                 204990           97990     47.80
Bounding Box              131905484104     36807818723     27.90
Function VM calls:         14626567
Crackle Cache Queries:         1001764
Crackle Cache Hits:             784251 ( 78 percent)
Roots tested:                531269   eliminated:               251024
Media Intervals:               3011   Media Samples:             84158
(27.95)
Shadow Ray Tests:         238103351   Succeeded:             204039135
Shadow Cache Hits:          2421133
Reflected Rays:             1085715
Refracted Rays:                1565
Transmitted Rays:          20666860
Render Time:
   Photon Time:      No photons
   Radiosity Time:   No radiosity
   Trace Time:       2 hours 58 minutes 49 seconds (10729.000 seconds)
               using 2 thread(s) with 20772.406 CPU-seconds total
POV-Ray finished
CPU time used: kernel 17.91 seconds, user 20897.13 seconds, total
20915.03 seconds.
Elapsed time 10884.88 seconds.
Render averaged 275.61 PPS (143.44 PPS CPU time) over 3000000 pixels.
Date: 16 Aug 2009 21:25:00
Message: <web.4a88b0891abbfe88d2e3fb180@news.povray.org>
If you have not already done it, you might try the start row and end row options
just around the 93% completion point as a way to take a 'shot in the dark' at
reproducing the problem without re-running the entire render.
On a *nix machine the additional command line flags would be +sr0.9 and +er0.95.
There are 'ini' forms of the options, but I don't recall them off the top of my
head.
Date: 16 Aug 2009 23:57:51
Message: <4a88d53f$1@news.povray.org>
> head.
On the Windows version (don't know about Mac) you can use CLI options in
the editor (there's a field next to the resolution selection box for them).
...Chambers
