POV-Ray : Newsgroups : povray.beta-test : FYI: radiosity changes integrated Server Time
27 Jul 2026 02:41:21 EDT (-0400)
  FYI: radiosity changes integrated (Message 13 to 22 of 22)
Subject: Re: FYI: radiosity changes integrated
Date: 11 Jan 2009 08:20:00
Message: <web.4969f15ebea0b42d85703a360@news.povray.org>
"clipka" <nomail@nomail> wrote:
> Chris Cason <del### [at] deletethistoopovrayorg> wrote:
> > Just an FYI to the folks who are interested: Christoph's radiosity fixes
> > have been integrated and see to work very well. A hearty 'thanks' to him
> > for this! I intend to do a release in the next day or two that incorporates
> > the new code.
> You're welcome! It's all just pure selfishness anyway :)
Well, be sure to thank your selfishness for me! :-P
Date: 14 Jan 2009 11:11:23
Message: <496e0eab@news.povray.org>
I've got some 32-bit EXE's of the radiosity changes up at:
  http://www.povray.org/temp/pvengine-beta30-rad1.zip
No installer, sorry, there's a story behind that, will tell you later.
-- Chris
Date: 15 Jan 2009 22:08:20
Message: <496ffa24$1@news.povray.org>
Has anyone used these EXE's ?
-- Chris
Date: 16 Jan 2009 04:45:01
Message: <web.4970568fbea0b42d5d471dea0@news.povray.org>
> -- Chris
After a long time many greetings to all of you!
Special Thanks to Chris and clipka for the effort providing "new" radiosity!
The shading looks much more smooth, so better compared to Beta29/30.
Also indirect lighting in dimmed regions shows better contrast. Very good!
But rendertime seems to be many times over (~10x ) with Beta30rad1 (considering
clipka's setting hint about nearest_count and low_error_factor)...
.....at least for my actual rendering:
W4500 H3000
QuadCore @2.66GHz
Vista64(!),
but also for
Core2Duo @2.4GHz
on XP32
When running rendering is done I'll post some comparing details in p.b.i...
In gratitude
TomAust
Date: 16 Jan 2009 06:15:00
Message: <web.49706c04bea0b42dec981ffe0@news.povray.org>
> -- Chris
Yes, still rendering ;-)
34h and counting, I may have used exaggerated settings.
Date: 16 Jan 2009 14:15:17
Message: <4970dcc5$1@news.povray.org>
I have posted some test results to p.b-t.b. The cornell.pov scene renders
about 3 times faster with the beta than with 3.6 on my system but I can't
seem to get a good quality render using a more complex scene without
increasing the render time several fold.
Mike
"Chris Cason" <del### [at] deletethistoopovrayorg> wrote in
message news:496ffa24$1@news.povray.org...
> -- Chris
Date: 17 Jan 2009 04:15:01
Message: <web.4971a0b6bea0b42d4c2eec1b0@news.povray.org>
I suggest a test for those with a very fast processor (pure radiosity scene):
Img: http://www.irtc.org/ftp/pub/stills/2002-08-31/golonls2.jpg
Source: http://www.irtc.org/ftp/pub/stills/2002-08-31/golonls2.zip
- radiosity abstract:
 radiosity {
   pretrace_start 0.08
   pretrace_end 0.01
   count 500
   nearest_count 10 -----> change to 1?
   error_bound 0.02
   recursion_limit 1 ----> good
   low_error_factor 0.2
   gray_threshold 0.0
   minimum_reuse 0.015
   brightness 1
   adc_bailout 0.01/2
Date: 17 Jan 2009 14:00:01
Message: <web.49722a2fbea0b42d488e7f280@news.povray.org>
The radiosity settings where some what random in nature, something to give a
long render.
global_settings {
  adc_bailout       0.003
  ambient_light     rgb <1.000,1.000,1.000>
  assumed_gamma     2.200
  irid_wavelength   rgb <0.250,0.180,0.140>
  max_trace_level   15
  number_of_waves   10
  noise_generator   3
  charset           ascii
  radiosity  {
    count            950
    recursion_limit  4
    nearest_count    20
    adc_bailout      0.010
    brightness       1.000
    error_bound      1.080
    gray_threshold   0.000
    low_error_factor 0.125
    minimum_reuse    0.000
    always_sample    1
    pretrace_end     0.001
    pretrace_start   0.080
    normal           1
    media            0
A partial message pane output:
Parser Statistics
Finite Objects:            8
Infinite Objects:          0
Light Sources:             0
Total:                     8
Parser Time
  Parse Time:       0 hours  0 minutes  0 seconds (0.000 seconds)
              using 1 thread(s) with 0.000 CPU-seconds total
  Bounding Time:    0 hours  0 minutes  0 seconds (0.000 seconds)
Warning: Scene contained deprecated 'assumed_gamma'. Output gamma has been
adjusted to match legacy 'assumed_gamma' due to language version being set to
3.61 or lower. However, future versions of POV-Ray will not support backward
compatibility with 'assumed_gamma'. It is strongly recommended you update your
scene file by removing 'assumed_gamma' and add suitable 'Display_Gamma' and
'File_Gamma' options to your INI file or command-line instead. See the
documentation for details.
Render Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Antialiasing.........On  (Method 1, Threshold 0.300, Depth 3, Jitter 1.00)
Rendering stopped by GUI extension
Render Statistics
Image Resolution 640 x 480
Pixels:           487991   Samples:           16650   Smpls/Pxl: 0.03
Rays:          255902538   Saved:                 0   Max Level: 640/480
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                          200894103       163730488     81.50
Cone/Cylinder                 89127307        12357493     13.86
Bounding Box                2808677478      1104323087     39.32
Reflected Rays:            21455955
Radiosity samples calculated:           845891 (0.52 %)
Radiosity samples reused:            161480379
Radiosity (final) calculated:              609 (0.08 %)
Radiosity (final) reused:               776949
  Pass     Depth 0    Depth 1    Depth 2    Depth 3           Total
  1            140       3294       4375        434            8243
  2            539       4253       7819        273           12884
  3           2107       7599      32260        730           42696
  4           5638      11817      80982        691           99128
  5+         22502      36400     591111      32318          682331
  Final        609          -          -          -             609
  Total      31535      63363     716547      34446          845891
Render Time:
  Photon Time:      No photons
  Radiosity Time:  35 hours 45 minutes 35 seconds (128735.938 seconds)
              using 12 thread(s) with 356422.745 CPU-seconds total
  Trace Time:       0 hours 29 minutes  7 seconds (1747.218 seconds)
              using 2 thread(s) with 3488.937 CPU-seconds total
POV-Ray finished
CPU time used: kernel 11.13 seconds, user 359913.86 seconds, total 359924.98
seconds.
Elapsed time 185766.48 seconds, CPU vs elapsed time ratio 1.94.
Bottom right lists:
99 ppm
2d 03h 36m 06s
A difference between 3.61 and 3.7b30rad1 will be posted in a binary group.
3.7b30rad1 was slightly brighter.
Complete files available.
Stephen S
Date: 17 Jan 2009 15:41:16
Message: <4972426c$1@news.povray.org>
With all that CSG this scene is really slow without radiosity but it gave me
an idea. A few years ago I created a patch that allows the definition of
arbitrary points in an area light which could be used to create things like
light domes. I completely abadoned it but I am currently rendering this
scene with it to see how it might compare in terms of rendering speed and
quality for a scene with a recursion limit of only 1. I will post the result
in p.b.i when done since it is getting off-topic for this group.
"Carlo C." <nomail@nomail> wrote in message
news:web.4971a0b6bea0b42d4c2eec1b0@news.povray.org...
> scene):
> radiosity {
>   pretrace_start 0.08
>   pretrace_end 0.01
>   count 500
>   error_bound 0.02
>   gray_threshold 0.0
>   minimum_reuse 0.015
>   brightness 1
>   adc_bailout 0.01/2
Date: 18 Jan 2009 14:48:01
Message: <49738771$1@news.povray.org>
I've also done some tests. Results are in p.b-t.binaries.
-Ive
