POV-Ray : Newsgroups : povray.beta-test : Performance wrt number of threads Server Time
11 Oct 2025 10:58:34 EDT (-0400)
  Performance wrt number of threads (Message 1 to 10 of 12)
Subject: Performance wrt number of threads
Date: 4 May 2005 10:36:03
Message: <4278ddd3$1@news.povray.org>
I tried an experiment rendering a rather simple scene (a few primitives on a
plane with one light) using sse2 b3.  My machine has a P4.3GHz processor
with HT.
Threads  Time  % improvement
1        72.58      0
2        63.83     12
4        64.90     11
8        59.90     17
16       54.75     25
32       50.20     31
64       48.27     33
128      49.00     32
255      47.83     34
So it seems that for a simple scene I can get a 33% speed increase by using
64 or more threads (rather than 1 thread).  Is there any reason for this,
and due to memory transfer etc will it not be as noticeable for bigger
scenes?
BTW it's also pretty cool to watch the preview when using 255 threads :-)
Subject: Re: Performance wrt number of threads
Date: 4 May 2005 13:58:23
Message: <42790d3f@news.povray.org>
> 4        64.90     11
  That's odd. According to my tests using the default 4 threads gives
an increase in speed of approximately 20%. That 11% figure seems quite
low.
  Perhaps your scene was too specific or something?
Date: 4 May 2005 14:27:00
Message: <427913f4@news.povray.org>
There seems to indeed be a slight speedup when the number of threads
grows larger, even though I didn't get such a big speedup as you.
I tried rendering isocacti.pov (at 640x480 +a +am2) in my 3.4GHz P4:
With 4 threads it took 7m 33s, with 64 threads it took 7m 26s.
Not such a big speedup as yours, but something.
  My best guess is that this happens because of the way hyperthreading
works in the Pentium4.
  The Pentium4 emulates two cores, but in a limited way because it
really just has one core. The idea is that even though there is only
one core, this core is composed of several independent parts, namely
the ALU, the FPU and the SSE processing unit. The idea in hyperthreading
is that while one process uses one of those units, another process can
use another of those units at the same time, in parallel.
  The P4 emulates two cores and runs threads truely in parallel if they
are using different units in the core, but falls back to run the processes
in alternation if they are using the same unit.
  Since POV-Ray uses both integer math and floating point math, and also
some SSE math if you have the SSE optimized binary, running POV-Ray in
several threads will give a speed advantage because two threads will be
run truely in parallel if one of then is eg. making floating point
operations and the other is performing integer math.
  My guess is that when you increase the number of threads to a quite big
amount (like 64 or more), the chances of the CPU being able to run code
truely in parallel increase. The more threads, the more chances for
parallel execution of some of the routines.
Date: 4 May 2005 14:54:40
Message: <42791a70@news.povray.org>
By the way, I noticed that if you increase the number of threads
it takes longer for povray to stop rendering (when the stop button
is pressed). The more threads, the longer it takes.
  Is this normal and to be expected?
Date: 4 May 2005 15:32:18
Message: <42792342$1@news.povray.org>
We'll be making a change that hopefully will improve things there.
-- Chris
Date: 4 May 2005 15:47:09
Message: <427926bd$1@news.povray.org>
Stopping cleanly isn't trivial in a multithreaded C++ program as there is no
language support for threading.  It has to be done trowing an exception,
which in turn requires a specific point to do so.  That point is a call the
thread has to make every now and then.  It currently does it only once per
pixel in every thread,and the more threads you start the longer it takes,
especially when doing anti-aliasing.  We are going to look for a better
place (probably a test for each ray) and hopefully this will improve
response time.
	Thorsten
Date: 4 May 2005 18:49:43
Message: <42795187$1@news.povray.org>
no
the
> response time.
Might I suggest that during this time, the Stop button (and any equivalents
in the menus) be disabled? It would make it "feel" a lot more like POV-Ray
is trying to do what you say, since it's responding, at least in a small
way, to your click.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 4 May 2005 19:59:52
Message: <427961f7@news.povray.org>
> way, to your click.
  Actually that's exactly what povray does.
  However, perhaps there could be some more visible message somewhere
saying something like "waiting for threads to finish".
Date: 4 May 2005 20:23:43
Message: <4279678f@news.povray.org>
I do this, however it's only in response to the backend acknowledgement of
the stop request. If I disabled it before then, and the backend didn't stop
(this can happen), you wouldn't be able to try again.
-- Chris
Date: 4 May 2005 21:14:04
Message: <4279735c$1@news.povray.org>
stop
Oh. Generally this has only happened to me when a scene takes up a ton of
memory, and things are starting to thrash. This is when I start to click
Stop like crazy, until I eventually ctrl+alt+del the whole thing out of
frustration. =) (Not that that really speeds anything up.)
I like Warp's suggestion; maybe something in the status bar would be nice.
 - Slime
