There seems to indeed be a slight speedup when the number of threads
grows larger, even though I didn't get such a big speedup as you.
I tried rendering isocacti.pov (at 640x480 +a +am2) in my 3.4GHz P4:
With 4 threads it took 7m 33s, with 64 threads it took 7m 26s.
Not such a big speedup as yours, but something.
My best guess is that this happens because of the way hyperthreading
works in the Pentium4.
The Pentium4 emulates two cores, but in a limited way because it
really just has one core. The idea is that even though there is only
one core, this core is composed of several independent parts, namely
the ALU, the FPU and the SSE processing unit. The idea in hyperthreading
is that while one process uses one of those units, another process can
use another of those units at the same time, in parallel.
The P4 emulates two cores and runs threads truely in parallel if they
are using different units in the core, but falls back to run the processes
in alternation if they are using the same unit.
Since POV-Ray uses both integer math and floating point math, and also
some SSE math if you have the SSE optimized binary, running POV-Ray in
several threads will give a speed advantage because two threads will be
run truely in parallel if one of then is eg. making floating point
operations and the other is performing integer math.
My guess is that when you increase the number of threads to a quite big
amount (like 64 or more), the chances of the CPU being able to run code
truely in parallel increase. The more threads, the more chances for
parallel execution of some of the routines.
By the way, I noticed that if you increase the number of threads
it takes longer for povray to stop rendering (when the stop button
is pressed). The more threads, the longer it takes.
Is this normal and to be expected?
We'll be making a change that hopefully will improve things there.
-- Chris
Stopping cleanly isn't trivial in a multithreaded C++ program as there is no
language support for threading. It has to be done trowing an exception,
which in turn requires a specific point to do so. That point is a call the
thread has to make every now and then. It currently does it only once per
pixel in every thread,and the more threads you start the longer it takes,
especially when doing anti-aliasing. We are going to look for a better
place (probably a test for each ray) and hopefully this will improve
response time.
Thorsten
no
the
> response time.
Might I suggest that during this time, the Stop button (and any equivalents
in the menus) be disabled? It would make it "feel" a lot more like POV-Ray
is trying to do what you say, since it's responding, at least in a small
way, to your click.
- Slime
[ http://www.slimeland.com/ ]
> way, to your click.
Actually that's exactly what povray does.
However, perhaps there could be some more visible message somewhere
saying something like "waiting for threads to finish".
I do this, however it's only in response to the backend acknowledgement of
the stop request. If I disabled it before then, and the backend didn't stop
(this can happen), you wouldn't be able to try again.
-- Chris
stop
Oh. Generally this has only happened to me when a scene takes up a ton of
memory, and things are starting to thrash. This is when I start to click
Stop like crazy, until I eventually ctrl+alt+del the whole thing out of
frustration. =) (Not that that really speeds anything up.)
I like Warp's suggestion; maybe something in the status bar would be nice.
- Slime
It's supposed to say 'stopping' in the status panel at the top right. However
you'll also see the stop button grayed out if it's like that, and given we've
been hearing that's not happening it's probably the message isn't getting
acted on. see how the next beta behaves.
-- Chris
Yes, I noticed that it says "stopping", but I thought that it's not
informative enough... Well, I suppose it doesn't matter all that much.
