POV-Ray : Newsgroups : povray.beta-test : Changes to some patterns? Server Time
10 Apr 2026 09:09:14 EDT (-0400)
  Changes to some patterns? (Message 1 to 7 of 7)
Subject: Changes to some patterns?
Date: 5 Feb 2004 15:23:12
Message: <4022a630$1@news.povray.org>
Running through some of the sample scenes, there seems to be some scenes
which render differently. It looks like there was a change to one of the
patterns. (?)
Subject: Re: Changes to some patterns?
Date: 5 Feb 2004 20:24:28
Message: <4022ED21.6C9E5181@pacbell.net>
> patterns. (?)
Could you please be a little more specific as to which scenes you feel are
rendering differently?
Ken Tyler - POV-Ray Technical Assistance Group
Date: 5 Feb 2004 21:00:33
Message: <4022f541$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:4022ED21.6C9E5181@pacbell.net...
arches.pov would be one.
I noticed glasschess.pov looks slightly different as well, but this could be
caused by changes in the way refraction is handled when two surfaces meet.
There are others, but I can't think offhand. I know some of the scenes that
use glass in certain contexts (wineglass, lamppost, grenadine), look
different. I've posted on p.bt.b a rendering of Arches under both versions
of the raytracer.
Date: 6 Feb 2004 22:23:59
Message: <40245AA7.BF476149@pacbell.net>
> of the raytracer.
There is definitely a difference between the two versions.  As far as I
know there really shouldn't be that much change in the normal patterns
to cause that big of a difference.
Ken Tyler
Date: 7 Feb 2004 00:28:45
Message: <4024778d$1@news.povray.org>
news:40245AA7.BF476149@pacbell.net...
Oh wow... there's got to be a bug in the code. I tried arches.pov with a
number_of_waves setting (for the global_settings) to see how it would vary
the pattern and it was all over the place in how it rendered each time. For
example, first instance I used a value of 5 for that and it lost reflection.
Then began at 1 and rendered each time incrementing the value up by 1. When
it got to 5 again it had reflection but no wave patterns. Other numbers
either gave unpredictable results too.
Bob H.
http://www.3digitaleyes.com
Date: 8 Feb 2004 06:56:05
Message: <402623d5$1@news.povray.org>
"Hughes, B." <omn### [at] charternet> wrote in message
news:4024778d$1@news.povray.org...
For
reflection.
Having checked it more since then I found that setting a number_of_waves
value, rendering, then rerendering a second time without making a change,
there'd be an expected water surface. Not the same as in version 3.5, but at
least the pattern looking more like it should instead of lacking any texture
(or reflection) or just having a rather featureless flat surface.
Plus there are occasional errors, i.e. "The POV-Ray rendering core threw an
unhandled exception", when larger numbers are used but not the same each
time (55, 100, etc.)
POV for Windows, WinXP
Bob H.
Date: 16 Feb 2004 20:51:03
Message: <cjameshuff-435481.20513516022004@news.povray.org>
In article <4022f541$1@news.povray.org>,
I seem to remember that in an earlier version, there was a coincident
surfaces problem on the board squares. I thought it was fixed in 3.5
though, so if you're seeing differences between 3.5 and 3.6...
> of the raytracer.
That's got to be wrong...probably something's not getting initialized
right.
http://tag.povray.org/
