POV-Ray : Newsgroups : povray.beta-test : Height field defects Server Time
10 Apr 2026 09:08:10 EDT (-0400)
  Height field defects (Message 1 to 10 of 11)
Subject: Height field defects
Date: 1 Feb 2004 03:00:09
Message: <401cb209$1@news.povray.org>
First off, let me thank the POV-Team for including my fix for height field
normals!
However, while checking out whether it got included or not, I noticed
another problem: along the right and upper edges of height fields, the
normals are undefined. I actually discovered this problem back when I was
working with the height field code before, but I guess it got overlooked. In
any case, the normals of the rightmost and topmost vertices of height fields
are not calculated, so seemingly random values from the allocated memory are
used instead. This scene demonstrates the problem:
  location <.8,1,-.5>
  look_at <.5,0,.5>
height_field
  function 32, 32 {pattern{bozo scale 1/3}}
  smooth
  scale <2,.5,2>/2
  pigment {rgb 1}
light_source {
  <.5,3.5,-.5>*0 + <-1,1,-1>*999
  rgb 1
Now, you will get different results than I did, because it's taking
uninitialized data from memory - it's actually different each time you
render. The areas to look at are the rightmost and uppermost parts of the
height field.
If I remember correctly, this problem can be fixed simply by replacing two
less-than signs with less-than-or-equal-to signs in the source code.
By the way: I noticed anti-aliasing was changed so that clipping occurs
after anti-aliasing. (You can see this effect on the edge of the height
field sometimes.) I'll be interested to see how this change turns out. =)
So... anyone care to render my scene and confirm the problem? Thanks =)
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: Height field defects
Date: 1 Feb 2004 03:28:21
Message: <Xns9482605C56C4Aseed7@news.povray.org>
in news:401cb209$1@news.povray.org Slime wrote:
> In
> fields are not calculated, so seemingly random values from the
> allocated memory are used instead.
I subtracted two consecutive renders of your scene, in the resulting image
is a white line where the left and bottom edges of the HF are. So bug
confirmed
Athlon 1800+ 1.5GB Win2000.
Ingo
Date: 1 Feb 2004 14:16:36
Message: <401d5094$1@news.povray.org>
> confirmed
The left and bottom? That's strange, I didn't have any problems with that
area.
The artifacts should be plainly visible - though as I said, you can't
necessarily see it immediately, since the uninitialized memory has to
already have been used for something else.
 - Slime
Date: 1 Feb 2004 14:24:37
Message: <401d5275$1@news.povray.org>
> > confirmed
> area.
After some thought, I suspect the white line you got in the difference was
caused by AA jittering, and not the bug I described.
 - Slime
Date: 1 Feb 2004 14:27:22
Message: <401d531a$1@news.povray.org>
I have posted two example images in povray.beta-test.binaries.
 - Slime
Date: 1 Feb 2004 15:06:51
Message: <Xns9482D6C9376DDseed7@news.povray.org>
> difference was caused by AA jittering, and not the bug I described.
Oops, that could be.
I don't get the artifacts as shown in the images you posted.
Ingo
Date: 1 Feb 2004 15:09:44
Message: <401d5d08$1@news.povray.org>
It seems like you might have to first increase the height field size (to
like 40x40 or 64x64 or whatever) and then reduce it again. Just keep
changing the size and rendering and re-rendering and eventually you'll get
it.
 - Slime
Date: 1 Feb 2004 15:11:16
Message: <6230f1-fad.ln1@triton.imagico.de>
That seems correct, the Megapov patch changed this together with the
Smoothing problem but this was not in 3.6.  Should be fixed in next beta.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 1 Feb 2004 16:08:10
Message: <401d6aba@news.povray.org>
I get the same kind of artefacts.
Fabien.
Date: 1 Feb 2004 17:03:48
Message: <401d77c3@news.povray.org>
Strange, I don't get those artifacts.
  However, what worries me the most is that this heightfield should
be smooth but isn't. The grid is clearly visible and shouldn't. There's
something wrong here.
  It looks better than when rendered with 3.5, but I still think the grid
should not be visible.
  Does anyone know what's going on here?
  Compare it to this:
  location <.8,1,-.5>
  look_at <.5,0,.5>
#include "shapes.inc"
object
{ HF_Square(function {pattern{bozo scale 1/3}}, no, no, 32, yes, "", 0, 1)
  scale <2,.5,2>/2
  pigment {rgb 1}
light_source {
  rgb 1
