POV-Ray : Newsgroups : povray.beta-test : Specular Transparent Image-Map Problem with 3.5 RC 6 Server Time
25 Jul 2026 05:28:54 EDT (-0400)
  Specular Transparent Image-Map Problem with 3.5 RC 6 (Message 11 to 18 of 18)
Subject: Re: Specular Transparent Image-Map Problem with 3.5 RC 6
Date: 19 Jun 2002 13:27:16
Message: <3d10bef4@news.povray.org>
Richard Borsheim <rbo### [at] shawca> wrote:
> This is standard practice when modelling for games. Certainly Direct3D
> supports it and correctly renders it (in my experience). It is an incredibly
> effective technique (as long as you don't look too closely :-) )
  Then how would you render clear glass (with highlights) with such engine?
> For example
> the holes punched through the side of the wheel supports in this image
> (http://www.amabilis.com/gallery/Alex%20Grigny%20de%20Castro%20-%20Sojourner
> %20-%20Large.jpg) would not be renderable with POVRay.
  Why not? There have been several mentions about image_pattern in this
thread. You can use it to get that effect.
Date: 19 Jun 2002 13:46:10
Message: <3d10c362$1@news.povray.org>
> Maybe you understand all this now, but the problem you were describing
> seemed to show that you did not before.
I think that I knew that (or should have), but didn't apply it to this
particular case. My thinking was "100% translucency=Non-existence".
> You didn't say whether or not a finish were being used, so
> that would be good to know, however you did say "specular image_maps".
That
> must mean you do have a finish set up.
I did have a finish set up. It works fine if there is no specular set.
> Anyway, back to the item in question. Fact is, I think all you can do is
> like Nathan suggested already. To map out the image via a texture not
> pigment. For POV-Ray that would be the way to go about that punch-through
as
> you called it. The technique you told of isn't something I know about but
I
> get the idea.
I think I understand, but I don't think this could be applied in this
particular case since the POVRay file is "generated" and that would require
some steps that would be akward.
The solution/work-around is to only use punch-through modelling on objects
that don't require specularity/reflection etc.
> Hope you don't take all the 'not a bug' stuff the wrong way. For instance,
> Warp was pointing out the obvious. Some people expect highlights on clear
> objects if specular or phong is specified in a finish, others don't.
> Likewise, to see reflections if reflection is set, or not. Reflection
> behaves this way too.
I completely understand the "not a bug" stuff. I'm a developer myself and
know the "feature vs. bug" issue well. I did try to phrase it politely (but
obviously failed). I guess I'll have to post a request for a new feature:
"100% translucency = non-existence". Though, I suppose not many "real"
POVRay users will be interested in such a feature.
> Well, have I beat this into the ground enough?  :-)
Yup. Good job! Thanks.
BTW anyone know why if you use atmosphere you need to have something behind
the atmosphere or the "visible light" is not visible? Should I post that
somewhere else?
Richard
PS Here is something rendered with POVRay and created with my program (3D
Canvas) that I thought was particularly nice:
http://www.train-sim.com/dcforum/User_files/3ccaa5291beb7bb4.jpg
Date: 19 Jun 2002 13:59:38
Message: <3d10c68a@news.povray.org>
incredibly
engine?
You probably wouldn't, but it would depend on the engine. You might use a
high level of translucency (say 99%) for glass and have a special case for
100% translucent which means don't render it. I just did a little test with
the engine I use and it just makes the highlight proportional to the
translucency which of course makes it impossible to create glass (without
faking it)
> > For example
I read the posts in the wrong order. See my other post.
Richard
Date: 19 Jun 2002 14:14:23
Message: <Xns9232CE74F455Aseed7@povray.org>
> behind the atmosphere or the "visible light" is not visible? Should I
> post that somewhere else?
In the doc, section "6.9.1 Atmospheric Media", in the note.
Ingo
Date: 19 Jun 2002 23:29:25
Message: <3d114c15$1@news.povray.org>
"Richard Borsheim" <rbo### [at] shawca> wrote...
FYI, it probably won't ever get added.  It's generally not good practice to
have a "trigger value" like that.
The more likely feature to be added in the future is a "finish map" which
will allow the finish to be directly controlled by a pattern.  Until then, a
"texture map" (already mentioned) is the way you can achieve this result.
It would look something like this:
  image_pattern {
    <your image file>
    use_alpha // so that it uses the alpha (transparancy) channel
  texture_map {
    [0.0 texture {<your image texture with highlight>} ]
    [1.0 texture {<clear, no-highlight texture>} ]
-Nathan
Date: 20 Jun 2002 17:19:26
Message: <3d1246de$1@news.povray.org>
You know what I want? Aside from a finish_map, but that would solve this
problem?
I want the ability to specify a "transparency_map" for the entire texture,
separate from the pigment, normal, or finish. Something that tells how much
whatever's underneath shows through.
This would be a slightly easier way of mapping textures, only it would have
more advantages. For instance, right now, transparency can only be specified
in the pigment - but what if you have an image_map for your pigment, and
want to change the transparency? At the moment, I believe you'd have to
average the pigment with a transparent one. But with a transparency{} block
of some sort, you could do it more easily.
It would just be nice to have a way to influence the transparency of the
entire texture all at once.
 - Slime
[ http://www.slimeland.com/ ]
Date: 20 Jun 2002 20:21:11
Message: <3d127177@news.povray.org>
  Does this suffice?
#macro TextureWithTransparency(OriginalTexture, TransparencyFunction)
  texture
  { function { TransparencyFunction(x,y,z) }
    texture_map
    { [0 OriginalTexture]
      [1 pigment { rgbt 1 }]
// Example:
#declare MyTexture =
  texture
  { pigment
    { granite color_map { [0 rgb <.5,.3,.1>][1 rgb <1,.6,.3>] }
#declare Transparency = function { pattern { bozo scale .25 } }
camera { location <1,2,-5> look_at 0 angle 35 }
light_source { <100,200,-50>, 1 }
plane { y, -1 pigment { checker rgb 1, rgb .5 } }
sphere
{ 0,1
  TextureWithTransparency(MyTexture, Transparency)
Date: 23 Jun 2002 22:19:26
Message: <3d1681ae@news.povray.org>
Hmm. Actually, that's not bad.
 - Slime
