POV-Ray : Newsgroups : povray.beta-test : Known bugs 9 Mar 2002 Server Time
27 Apr 2026 13:11:19 EDT (-0400)
  Known bugs 9 Mar 2002 (Message 12 to 21 of 21)
Subject: Re: Known bugs 9 Mar 2002
Date: 11 Mar 2002 08:10:09
Message: <q2bp8ukdjb371iqb67jgobdhd2v5dino5i@4ax.com>
On Mon, 11 Mar 2002 13:53:26 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> > I can't find my last week report in any category. What is the current status
> > of http://news.povray.org/uoj68uk5m391emvphovqfbg5vl0en7h2q6%404ax.com ?
> That it will be added to the next posting of the list :-)
I will check this for sure :-)
> The category it will be in (officially confirmed / not confirmed) depends on
> your ability to provide a shorter example.
After moment in apropriate thread.
ABX
Date: 11 Mar 2002 08:23:31
Message: <dnbp8uo01hlr0k9g61krnpj0jca7ohksvb@4ax.com>
>  This just looked so similar to
> Still a first function initialisation error?
> http://news.povray.org/3C612786.9000004@reading.ac.uk
> that I wasn't sure at all if it was a different problem.
>  Any ideas?
They can be related somehow however second refer to _parsing_ error while my
_crash_ appear at time of evaluating. I have updated my thread with shorter
example.
ABX
Date: 11 Mar 2002 08:30:06
Message: <3C8CB1B7.80F863DA@engineer.com>
Thorsten Froehlich wrote:
> > Slow render time after several runs
> > http://news.povray.org/3bd40c6d$1@news.povray.org
Still there.
> A possibly related report:
> radiosity problem
> http://news.povray.org/3c49968f@news.povray.org
Gone.
beta 12 Win98SE 1G Athlon
_____________
Kari Kivisalo
Date: 11 Mar 2002 10:13:58
Message: <chrishuff-8671B6.10135411032002@netplex.aussie.org>
In article <3c8ca968@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
> > The list is missing the report I gave that shadowless lights don't
> > illuminate scattering media.
>   I think it was pretty unclear whether it is a bug or just a design
> decision.
>   If you can convince me that it's a bug, I can add it.
I think it is part of the "shadowless lights == fill lights" logic that
was the reason for making them highlightless as well. When using them
for fill lighting, you don't really want them illuminating media.
Personally, I would prefer "object_shadows", "media_shadows",
"specular", "phong", "illuminates_media", and "illuminates_objects"
on|off flags, but it is probably much too late to change now.
Date: 13 Mar 2002 07:08:40
Message: <3c8f4148@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3c8a4d2e@news.povray.org...
<snip>
I can't see any mention of the problem of objects disappearing with orthographic
unless -UV is used.
Date: 13 Mar 2002 08:26:41
Message: <3c8f5391@news.povray.org>
In article <3c8f4148@news.povray.org> , "Tom Melly" <tom### [at] tomandlucouk>
> orthographic unless -UV is used.
Because a long time ago it was explained that this isn't a problem but a user
error which is only visible when using vista buffers.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 13 Mar 2002 08:47:22
Message: <nvku8u8a5cmcg9c2m11hmhn3sepa4o6403@4ax.com>
On Wed, 13 Mar 2002 14:26:36 +0100, "Thorsten Froehlich" <tho### [at] trfde>
But I have reached exactly opposite effect.
Look, I used simple camera specification:
  camera{orthographic}
What this means ? According to defaults in documentation:
  direction   : <0,0,1>
  3d lower corner of projection : <-.665,-.5,1>
  3d upper corner of projection : <.665,.5,1>
Then I put sphere_sweeps with all nodes in <0,0,0><1,1,1> range
So they are all between location of camera and projection plane.
Warp said : "with orthographic camera the rays
don't start from the camera location but from the projection plane".
So in this case my sphere_sweeps shoud be invisible. But they are visible when
number of instances is lower then 3 or when -UV is applied.
Perhaps it is another bug not related to this user error, is it ?
My source (I hope not long to much) were posted at:
http://news.povray.org/r6hk7usts1qgik8fiohe5r4gvb937hnj9e%404ax.com
ABX
Date: 13 Mar 2002 09:16:30
Message: <3c8f5f3e@news.povray.org>
Vista buffers of course use the bounding box of an object, not its impossible
to determine real position when eliminating too close objects.  This is how
vista buffers work and thus if you don't want them to work, you have to turn
them off.  Or, place your object far enough in front of the camera as the
distance doesn't make a visible difference for an orthographic camera...
    Thorsten
e-mail: tho### [at] trfde
Date: 13 Mar 2002 10:04:51
Message: <3c8f6a93$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c8f5391@news.povray.org...
Must have missed that - can you point me to the thread? (ortho cameras confuse
the hell out of me).
F-ups set...
Date: 16 Mar 2002 06:52:39
Message: <3C93322D.CAE0D688@gmx.de>
> * Bicubic patch bug (job000202)
>   (Bicubic patch triangles disappear in some circumstances.)
>   Reported in:
> http://news.povray.org/3c23b26c@news.povray.org
I'd say this has to do with the typical floating point precision
problems. Solving polynomials for bicubic patches on very
small scales might be something the floats in POV cannot
handle, and thus they "leak" information needed for the
triangles.
I'm not big algorithm guy, and have no information on the
algorithms for bicubic-patches, but perhaps this could be
solved somehow by internally scaling the patch large enough
to be handled (like "normalizing" the patch to a certain size),
calculating the patch, and then scaling it back again could
fix the problem, but, as said, I've no idea if that is possible
or not.
>   Bugs with no official confirmation:
> * Crash with empty scene
>   (Not properly confirmed. Most people report no problems.)
>   Reported in:
> Crash with no objects in scene
> http://news.povray.org/3bd985b0@news.povray.org
> POV-Crash on empty scenes
> http://news.povray.org/3C19B9EA.D2E16FBC@gmx.de
I've experienced the problem and it was gone in just this new
beta 13, using a 1.4 GHZ Athlon, Win98 and 512 MB RAM.
Tim Nikias
