POV-Ray : Newsgroups : povray.beta-test : Filling in T values in splines Server Time
25 Jul 2026 20:58:15 EDT (-0400)
  Filling in T values in splines (Message 10 to 19 of 39)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Filling in T values in splines
Date: 24 Feb 2002 07:26:16
Message: <3c78dbe8@news.povray.org>
Hey, it just occurred to me that this syntax could be extended with other
options. Imagine the following:
#declare Spline =
spline {
   Spline_Type(Cubic_Spline)
   Spline_Points(7)
   Spline_Speed(Constant)
   SCP( 0.0, <0,1,2>)
   SCP(   x, <1,5,0>)
   SCP(   x, <4,1,0>)
   SCP(   x, <0,2,1>)
   SCP(   x, <0,0,1>)
   SCP(   x, <6,5,4>)
   SCP( 2.0, <4,3,2>)
   Spline_End()
I think this is beginning to be interesting! I hope you agree that the
approach shown here would fit well in the official include files?
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 24 Feb 2002 07:27:55
Message: <3c78dc4b@news.povray.org>
Rune <run### [at] mobilixnetdk> wrote:
> #declare Spline =
> spline {
>    cubic_spline
>    Spline_Points(7)
>    SCP( 0.0, <0,1,2>)
>    SCP(   x, <1,5,0>)
>    SCP(   x, <4,1,0>)
>    SCP( 0.9, <0,2,1>)
>    SCP( 1.0, <0,0,1>)
>    SCP(   x, <6,5,4>)
>    SCP( 2.0, <4,3,2>)
>    Spline_End()
  That would be better than nothing.
  Of course there are two things that are a bit bothering: You have to
specify the number of points at the beginning (as always with arrays) and
you have to write extra text ('SCP(...)' and those x's), but I think those
are things that can't be helped currently.
  By the way, it could also be a good idea to add another macro:
#declare Spline =
  spline
  { cubic_spline
    Even_Spline_Points(array[5]{<1,2,3><4,5,6><7,8,9><10,11,12><13,14,15>})
or something similar.
Date: 24 Feb 2002 07:29:30
Message: <3c78dca9@news.povray.org>
  I don't understand the reason for this one.
Date: 24 Feb 2002 07:46:46
Message: <Xns91BF8C7EEDC76seed7@povray.org>
Us it as you want it.
// The macro allways expects one point
// before t=0 and one after t=1, also for linear splines.
// Use: #declare SPL=BuildSpline(ArrayIdentifiers, "string")
// where string is C|c|L|l|Q|q
#macro BuildSpline(Arr, SplType)
   #local Ds=dimension_size(Arr,1);
   #local Asc=asc(strupr(SplType));
   #if(Asc!=67 & Asc!=76 & Asc!=81)
      #local Asc=76;
      #debug "\nWrong spline type defined (C/c/L/l/Q/q), using default
linear_spline\n"
   spline {
      #switch (Asc)
         #case (67) //C  cubic_spline
            cubic_spline
         #break
         #case (76) //L  linear_spline
            linear_spline
         #break
         #case (81) //Q  Quadratic_spline
            quadratic_spline
         #break
      #local Add=1/((Ds-2)-1);
      #local J=0-Add;
      #local I=0;
      #while (I<Ds)
         J
         Arr[I]
         #local I=I+1;
         #local J=J+Add;
Date: 24 Feb 2002 08:35:58
Message: <3c78ec3d@news.povray.org>
I think that it would be better if the macro just created the points, not
the spline itself.
spline { cubic_spline MakeThePoints(whatever) }
Date: 24 Feb 2002 08:41:29
Message: <3c78ed89$1@news.povray.org>
More advanced macro options such as constant speed (I think that's the same
as you call even spline points) will need to know the spline type in order
to create optimal results. It also opens up the possibility of introducing
new spline types that the macros fakes using the existing spline types.
Rune
Date: 24 Feb 2002 09:43:59
Message: <3c78fc2f@news.povray.org>
Well, that's something.
> You have to specify the number of points at the beginning
Actually you can just make the number plenty large and then you don't have
to worry about changing it every time you add a new point. As the array will
be bigger it will require slightly more ressources, but nothing of
importance. The point is that you don't get an error and that it gives the
same result.
> and you have to write extra text ('SCP(...)' and those x's)
Yes...
> #declare Spline =
>   spline
>   { cubic_spline
Do you mean evenly distributed T values or evenly distributed points of the
spline. The first is very easy while the second is slightly more tricky, but
I intent to make support for both.
Rune
Date: 24 Feb 2002 10:03:31
Message: <chrishuff-C72E52.10032224022002@netplex.aussie.org>
In article <3c78ec3d@news.povray.org>, Warp <war### [at] tagpovrayorg>
> the spline itself.
And you should be able to set the beginning and end T values. That way,
you could paste the spline data into an existing spline.
Date: 24 Feb 2002 11:02:48
Message: <3c790ea8@news.povray.org>
> spline.
  I meant evenly distributed T values (ie. just interpolate them between
0 and 1).
  (Of course a more advanced option could make the macro to interpolate
the T values non-linearly.)
  As for evenly-distributed points along the spline, I think that the only
feasible way of doing that is to make a macro which returns points for the
given spline (in the same way as the Colefax include does). Of course this
will make it a bit slow (because it has to approximate by sampling points on
the spline).
Date: 24 Feb 2002 11:49:45
Message: <3c7919a9@news.povray.org>
> the macro to interpolate the T values non-linearly.)
I don't think I'll implement that. With both the T values and the points
being non-linearly interpolated, I'm not even able to figure out in my head
in what way the results would be different. And non-linearly interpolation
of strongly varying T values could cause the T values to go backwards at
times, which would mess up everything.
> I think that the only feasible way of doing that is
> to make a macro which returns points for the given
I've done that before and it's not that slow. However, a solution I'd like
to try is to return a new spline which has many more control points than the
original and where those control points are arranged to give constant speed.
This too is just an approximation, but it would be faster, as the
calculations would only need to be done once, and it could also be made
completely transparent to the user, who will call the spline like normal,
without the need for macros once the spline has been created.
Rune
