POV-Ray : Newsgroups : povray.beta-test : bug in texture_map Server Time
7 Mar 2026 12:46:04 EST (-0500)
  bug in texture_map (Message 1 to 10 of 17)
Subject: bug in texture_map
Date: 20 Sep 2001 10:10:49
Message: <3ba9f8e9$1@news.povray.org>
my machine is a PIII 450 MHz, 128 MB RAM and WinNT 4.0 Service Pack 5,
POV-Ray 3.5 Beta 2
The following code gives a parse error: Blend_Map too long
// Start of code //
#version 3.5;
camera {location <10, 10, -10> look_at <0.5, 0.5, 0.5>}
light_source {<10, 10,-10> color rgb 1}
plane {<0, 1, 0>, 0
       texture {cells
                texture_map
                        #declare i = 0;
                        #while (i <= 1)
                          #declare my_color = color rgb i
                          [i pigment{my_color}]
                          #declare i = i + 0.0078;
// End of code //
O.k. there are too many texture_map items.
Then I changed the #declare of "i" in the #while loop to:
#declare i = i + 0.0079;
Now there are no parsing errors but POV-Ray crashed immediately after the
render window appeared. After reloading POV-Ray and restarting the rendering
without any change on the scene file it renders fine. No problems. Very
strange! :-(
So long,
Bonsai
Subject: Re: bug in texture_map
Date: 20 Sep 2001 10:13:39
Message: <3ba9f993@news.povray.org>
Oh, this should have a semicolon at the end:
#declare my_color = color rgb i;
But the error is still there...
Bonsai
Date: 20 Sep 2001 11:41:10
Message: <3BAA0E55.36814667@b0n541.net>
Me again :-)
On an other machine (Athlon 1 GHz, 392 MB RAM, Win 98 SE, POV-Ray 3.5
Beta 2) POV-Ray tells me more about the problem:
A dialog box appears: Failed to allocate display bitmap
and in the render window I can read:
StretchDIBits () failed! (Windows error)
Hmm, maybe there is a problem with the editor and not with the
texture_map.
After restarting POV-Ray everything renders o.k.
Hope that helps...
So long,
Bonsai
Date: 21 Sep 2001 05:39:19
Message: <3bab0ac7@news.povray.org>
"Bonsai" <bon### [at] b0n541net> wrote in message
news:3BAA0E55.36814667@b0n541.net...
> texture_map.
No, it must be a bug.  Either that or Ron hasn't let us know (via Help docs)
that the cells pattern can't use above 128 entries in a blend (color) map.
Pretty bad crash you found there.  First time through it I didn't even get a
error dialog, although successive times did show me the usual kernel.exe
error.
The display failure kind of hints at something more to it but I didn't get
any such thing happening here so I don't know if it's related specifically
to that cells pattern crash or just a side effect.
Sure hope Ron Parker has some answers or it might be with us awhile.
Bob H.
Date: 21 Sep 2001 06:16:57
Message: <3bab1399@news.povray.org>
"Bob H." <omn### [at] msncom> schrieb im Newsbeitrag
news:3bab0ac7@news.povray.org...
docs)
I think it's related to the texture_map:
see 6.7.5.1  Texture Maps:
"There may be from 2 to 256 entries in the map."
The error also occurs after changing cells to leopard or an other pattern
type.
I was also able to reproduce the crash in POV-Ray 3.1g *but* only under my
Win98 SE environment. So it's not a new thing.
So long,
Bonsai
Date: 21 Sep 2001 07:00:28
Message: <3bab1dcc@news.povray.org>
news:3bab1399@news.povray.org...
> docs)
map.
> type.
Well... that's not good, is it...?  I can't recall a crash happening for a
texture map in a while loop and my last OS was Win98SE.
Bob H.
Date: 21 Sep 2001 10:10:27
Message: <slrn9qmiil.grj.ron.parker@fwi.com>
>error.
I am not responsible for the help docs, and I've never touched the cells
pattern, so I'm not sure why my name is being invoked here.
It's always been impossible to have more than 256 entries in a blend map;
I'm not sure where the 128 you mention comes from.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 21 Sep 2001 10:21:44
Message: <3bab4cf8@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> schrieb im Newsbeitrag
news:slr### [at] fwicom...
It may come from my example because I put in 2 blend map entries per loop.
That's why POV-Ray gives a parse error after 128 loops in this scene.
So long,
Bonsai
Date: 21 Sep 2001 12:27:34
Message: <3bab6a76@news.povray.org>
news:3bab4cf8@news.povray.org...
map;
Oh yeah, okay, I see that now.  I just through the number 0.0079 into the
calculator thinking 1/0.0079 (or 0.0078) would be around 128.  I ignored the
double entry.  It is of course still only just greater that 128 and 126
respectively.  So somethings wrong there when it crashes at >128.
Sorry Ron, I was sure you were the author of the cells pattern and I had no
idea you were not.  Just so everyone knows besides me know who did, that
would be John VanSickle.
Bob H.
Date: 21 Sep 2001 12:40:20
Message: <slrn9qmrbm.h0s.ron.parker@fwi.com>
I'm sure you got that notion because I am responsible for crackle solid and
all of the other changes to crackle in 3.5.  I'm not really upset, just
don't want anyone who is in a position to fix the problem to shy away because
they think I'll look at it.
That's not to say I *won't* look at it, just to say that if someone else
gets to it first I don't want to discourage them from fixing it instead.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
