POV-Ray : Newsgroups : povray.beta-test : Camera transform bug Server Time
26 Jul 2026 12:27:16 EDT (-0400)
  Camera transform bug (Message 1 to 8 of 8)
Subject: Camera transform bug
Date: 9 Sep 2001 06:41:00
Message: <3b9b473c@news.povray.org>
According to section 6.3.4  Transform Identifiers of the documentation,
transformations can be invoked with or without brackets. However, when used
in cameras it doesn't work with brackets:
#declare T = transform {scale 2 translate 2*z}
sphere {0, 1 transform  T  }
sphere {0, 1 transform {T} }
camera {location 0 transform  T  }
camera {location 0 transform {T} }
I'm using POV-Ray 3.5 beta 1
on a P150, 16MB RAM
Windows 95  4.00.450 B  IE 5 5.00.2919.6307
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated June 26)
Subject: Re: Camera transform bug
Date: 11 Sep 2001 14:19:02
Message: <slrn9pslco.mdt.ron.parker@fwi.com>
Likewise light_source, light_group, bounded_by, clipped_by, and blob.
Should be easy to fix, though.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 11 Sep 2001 14:29:27
Message: <slrn9psm09.mh1.ron.parker@fwi.com>
And, it's fixed.  Thanks for pointing it out, Rune.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 11 Sep 2001 15:41:12
Message: <3b9e68d8@news.povray.org>
Thanks for fixing it.
How about the other camera transform bug?
Transformations that involve translations (including translations done using
matrices) are handled incorrectly.
Rune
Date: 11 Sep 2001 15:45:24
Message: <slrn9psqem.mi0.ron.parker@fwi.com>
I haven't looked too closely at that one yet.  It might be a precision thing.
Date: 11 Sep 2001 15:53:55
Message: <slrn9psqum.mi0.ron.parker@fwi.com>
Okay, you're right.  It's not a precision thing.  It might be more
interesting to fix.  The problem is that those transformations are
applied to four vectors: location, direction, up, and right.  Of
those four vectors, only one is world-relative and should be
translated (though scale and rotate and presumably shear should apply
to all of them.)
That should be relatively easy to fix as well.
Date: 11 Sep 2001 16:27:47
Message: <slrn9pssu5.mla.ron.parker@fwi.com>
>to all of them.)
Okay, that one's fixed too.  Thanks for pointing it out.
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 11 Sep 2001 16:36:00
Message: <3b9e75b0@news.povray.org>
Thanks!
Rune
