POV-Ray : Newsgroups : povray.beta-test.binaries : Mesh not smooth with 64bit 3.7beta32 Server Time
16 May 2024 02:48:44 EDT (-0400)
  Mesh not smooth with 64bit 3.7beta32 (Message 1 to 5 of 5)
Subject: Mesh not smooth with 64bit 3.7beta32
Date: 15 Apr 2009 02:56:59
Message: <49e5853b$1@news.povray.org>
Originally reported in p.Beta-test with reference to a mesh2 (downloaded
car model)
 > I've found that my 64bit (winXP) beta32 is failing to render a mesh2
 > smoothly - I get flat triangles not smoothed triangles.
 > I've tried the same scene with 3.6.1 (32 and 64 bit) and with a 32bit
 > beta32 and I get a nice smooth mesh with all 3 versions.
here's the output for the demo chessmesh scene rendered on 32 bit 3.61
(set assumed gamma to 1) and 64bit 3.7 beta 64
Download '3_6_1_chesmsh.jpg' (5 KB) Download '3_7beta32_64bit_chesmsh.jpg' (6 KB)
Preview of image '3_6_1_chesmsh.jpg'
Preview of image '3_7beta32_64bit_chesmsh.jpg'
Subject: Re: Mesh not smooth with 64bit 3.7beta32
Date: 15 Apr 2009 13:51:00
Message: <49e61e84@news.povray.org>
Le 15.04.2009 08:57, Verm nous fit lire :
> car model)
My output on my 64bit (Linux, source compiled) beta 32 with minors patches (for
isosurface, path 3.7/3.6 of shell script and crash avoidance for trace on fractal;
delta
attached for patch) seems fine. (attached jpeg)
Might be an issue related to XP/64 (compiler ?). At least, no problem with gcc 4.3.2
on
ubuntu/amd64.
Only my 0.02€... if it can helps
$ file /usr/local/bin/povray
/usr/local/bin/povray: ELF 64-bit LSB executable, x86-64, version 1 (SYSV), for
GNU/Linux
2.6.8, dynamically linked (uses shared libs), stripped
Download 'chesmsh.jpg' (21 KB) Download 'beta32.dif.txt' (5 KB)
Preview of image 'chesmsh.jpg'
Date: 15 Apr 2009 15:55:00
Message: <web.49e63b141359c511255d1edc0@news.povray.org>
Uh... I wouldn't actually call those triangles *flat*...
    ... I'd call them outright *f*cked up* :P
Date: 15 Apr 2009 17:10:00
Message: <web.49e64c661359c511255d1edc0@news.povray.org>
on
> ubuntu/amd64.
No problem with an Intel icpc build on a Debian AMD64 Linux either.
IIRC there had been some report on a similar issue: Messed-up meshes looking
similarly mangled. Though in that case it was a Linux issue, caused by a distro
POV package and resolved by installing a "proper" release.
Date: 17 Apr 2009 19:00:01
Message: <web.49e9094b1359c511addfbead0@news.povray.org>
> car model)
It looks a bit like vertex ordering has been changed, or normals computed
assuming a different order. I had similar results when I was starting to play
with triangles in OpenGL, where I had to supply normals and vertex data. I hope
that provides a relevant clue for coders :o)
