POV-Ray : Newsgroups : povray.beta-test.binaries : Light or Normal Problem Server Time
18 May 2024 18:32:49 EDT (-0400)
  Light or Normal Problem (Message 1 to 5 of 5)
Subject: Light or Normal Problem
Date: 24 Feb 2004 04:22:04
Message: <403b17bc@news.povray.org>
Hi!
I think this is a known bug by now (I think the normal bug should be known
by now).
Actually I was just looking for a version of pov-ray I can run under a linux
shell script or from Java under Linux, but I got this tty problem (even with
the -D option). I CANNOT COMPILE MYSELF so I was looking for a replacement.
3.6 works from a Linux shell script, but the renders look quite different.
It would be the best for me if the POV team would provide a Linux 3.5 binary
that works from a shell script or Java (i.e. a console version without X).
By now I had no luck getting such a version :( And I think I am not the only
one who would need one.
Regards & HTH
Bernhard
Download 'povray_light_or_normal_problem_3_6.png' (305 KB) Download 'test.pov.txt' (54 KB)
Preview of image 'povray_light_or_normal_problem_3_6.png'
Subject: Re: Light or Normal Problem
Date: 24 Feb 2004 05:22:04
Message: <n6lrg1-cqn.ln1@triton.imagico.de>
berni wrote:
> Hi!
> by now).
What bug are you talking about?  There is a confirmed problem with some
patterns looking different - the difference in your scene might be due
to this - if you think there is an additional problem you should post a
minimal scene that does *not* use any critical pattern.
Let me see if i understand this right - you ask the POV-Team to compile
you a 3.5 version because you are not able to compile one yourself?
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 24 Feb 2004 05:44:42
Message: <403b2b1a$1@news.povray.org>
binary
X).
only
Exactly. But this is a bug in 3.5 which is fixed in 3.6 (tty problem), so
everyone downloading the 3.5 binaries from pov-ray who wants to use it in a
script (CGI, webmin, Java, etc.) will experience this problem. So this would
be more efficient - if 3.6 final is not ready anytime soon. Unfortunately
compiling is not trivial for me (of course I can go and install linux
somewhere or spend $$$ for my own server and go through the troubles of
compiling sources - but my time and money resources are rather limited).
Doesn't this make sense to you?
Regards
Bernhard
Date: 24 Feb 2004 06:10:05
Message: <eunrg1-u74.ln1@triton.imagico.de>
No, you say you can install and run the linux version but don't have
access to a linux machine to compile it...
Apart from that POV-Ray 3.5 has been around for a long time now - do you
expect that the POV-Team makes a bugfix release now that 3.6 is already
in beta?  The 3.6 beta is quite stable (the normal problem is just a
lack of backwards compatibility - not a real bug).  Although i can't
speak for the Team the official statement most likely would be: use the
beta or work around the problem by compiling your own version.
Date: 24 Feb 2004 06:47:59
Message: <403b39ef@news.povray.org>
Sorry for answering your rhetorical question. I should have known that you
are not trying to help me.
Peace, Sorry for getting Off-Topic & Kudos to the makers of POV-Ray
Bernhard
