POV-Ray : Newsgroups : povray.animations : Rune's particle system Server Time: 16 May 2008 07:13:18 GMT
  Rune's particle system (Message 1 to 3 of 3)
Subject: Rune's particle system
Date: 13 Aug 2007 16:05:00
Message: <web.46c08074d1e099862ac159e90@news.povray.org>
Hi, I'm using rune's particle system
http://runevision.com/3d/include/particles/
to simulate fire and smoke effect. However I'm scratching my head on how to
simulate fire and smoke together (smoke appearing on top of the fire). I'm
trying to achieve the effect demonstrated in the Blow Up demo scene(without
the explosion though) in the website, but I have a hard time understanding
the explosion code..
In short I just need normal fire which generates smoke, any suggestions?
Thank you ^^
Subject: Re: Rune's particle system
Date: 16 Aug 2007 16:27:51
Message: <46c47b07@news.povray.org>
> how to simulate fire and smoke together (smoke appearing on top of
> the fire). I'm trying to achieve the effect demonstrated in the Blow
> Up demo scene(without the explosion though) in the website, but I
> have a hard time understanding the explosion code..
> suggestions?
If you want the effect from the Blow Up demo scene, but without the
explosion, just set ShowCloud in the top of the scene file to false. You
should be able to track what this variable turns off and which settings you
don't need anymore if you want to clean up the code afterwards.
Rune
Date: 20 Aug 2007 08:05:01
Message: <web.46c94a3070bc93dec4cf38c50@news.povray.org>
> Rune
Thanks. I kind of got it working but I noticed that the explosion fire is
using a different algorithm as it does not act as a light source itself but
rather it needs an external light source.
One more question, is it possible to change the fire particles -> smoke
particles after a certain time? For example when it begins the emitter is
emitting fire particles as described in the fire.inc but after 1 second the
fire particles changes to smoke particles as described in smoke.inc
Thank you! ^_^
Copyright 1991-2004 POV-Team™
