POV-Ray : Newsgroups : povray.animations : Calculating pixel rates Server Time
18 May 2024 14:26:45 EDT (-0400)
  Calculating pixel rates (Message 1 to 8 of 8)
Subject: Calculating pixel rates
Date: 26 Feb 2009 13:05:01
Message: <web.49a6d95313ccb5bde1acfc5e0@news.povray.org>
Hello again.
I have a question regarding the calculation of pixel rates. My understanding is
that my clock values are equal divisions of my final frame value, so with that
in mind if I have a 720 or 1920 pixel wide image rendering and I want to move
my object one pixel/frame, then all I would need to do is make my final frame
equal to the pixel width and use my clock value as my one pixel/frame motion
value.
                 translate <clock,0,0>
BUT, what if I am not exactly <0,0,0> in my camera position, and view? How can I
calculate how much my clock is moving an object? Are there any other ways to do
this?
Subject: Re: Calculating pixel rates
Date: 26 Feb 2009 16:15:01
Message: <web.49a7062176dd3071919973e90@news.povray.org>
"RC" <nomail@nomail> wrote:
> My understanding is
Yes, that is right.
> so with that
> value.
Actually this is the wrong math already. It only holds true if your camera
happens to be 1.0 POV units away from the object's trajectory with an opening
angle of 90 degrees - or a suitable other distance if the opening angle is
different.
> this?
Simple advice: Try to get away from pixel-based thinking. It's almost never the
natural units to work with in POV, and it's incompatible with changes of the
image resolution.
As for the math: With the most common camera settings
    perspective
    location  MyCameraLocation
    up        y
    direction z
    look_at   MyObjectLocation
    angle     MyCameraAngle
you can convert from POV units and vice versa using the following formulae (see
diagram in section 3.3.1.1 "Placing the Camera" of POV's online help):
  (1) tan(MyCameraAngle/2) * unitDistance = 0.5
  or  unitDistance = 0.5 / tan(MyCameraAngle/2)
  (2) pixels / image_width = size / (distance/unitDistance)
  or  pixels = image_width * size / (distance/unitDistance)
  or  size = (pixels/image_width) * (distance/unitDistance)
Formula (1) describes the distance at which 1 POV unit will appear to be equal
to the image width, while (2) describes the relation between size in pixels and
size in POV units.
Date: 26 Feb 2009 16:25:00
Message: <web.49a7082c76dd3071e1acfc5e0@news.povray.org>
> > My understanding is
> Yes, that is right.
> > so with that
> > value.
> different.
> > this?
> image resolution.
>   camera {
>     perspective
>     up        y
>     direction z
>     angle     MyCameraAngle
> size in POV units.
This is helpful thanks. I hate to admit it but so far to get this to work, I've
made marks with a dry erase marker on my LCDs to determine how far my objects
are moving between frames in front of a grid pattern. Ya, not so accurate...
Date: 26 Feb 2009 16:49:37
Message: <gg3eq4l5qf5qcukd2nlbdpr3k2grfcppqf@4ax.com>
Christoph is right but you might consider using an orthographic camera if it
suits you annimation. See the help 3.3.1.2.2  Orthographic projection.
Regards
Date: 26 Feb 2009 16:54:44
Message: <sk3eq4t4pk07k6j3k6i7evaich8qh6cppk@4ax.com>
Oh! It might be an idea to use frame_number instead of the clock variable. I
find that it is easier in animations. You can do arithmetic with the variables
initial_frame and final_frame as well. See 3.2.1.3.5  Built-in Constants
Regards
Date: 26 Feb 2009 16:55:01
Message: <web.49a70f5576dd3071919973e90@news.povray.org>
.... but definitely inventive :)
Date: 27 Feb 2009 14:40:00
Message: <web.49a840c876dd3071e1acfc5e0@news.povray.org>
Ok, I think I got this working, but my object looks slightly squashed.
  location  <0, 0, -10>
  direction z
  up y
  look_at   <0.0, 0.0,  0.0>
The render window looks right, but the output looks stretched?
Date: 27 Feb 2009 18:35:00
Message: <web.49a877b276dd3071e1acfc5e0@news.povray.org>
> camera {
>   direction z
>   up y
Wow, ignore that last comment. Its always good to have your display set to 1:1.
Time for the weekend...
