POV-Ray : Newsgroups : povray.animations : How to render rigid bodies Server Time
30 Apr 2024 21:25:21 EDT (-0400)
  How to render rigid bodies (Message 1 to 10 of 11)
Subject: How to render rigid bodies
Date: 27 Aug 2014 05:20:01
Message: <web.53fda28e1f351ff145f6c5070@news.povray.org>
Hi all,
I already knew how to render static meshes, but need to render rigid bodies
using Pov-Ray 3.6.
I wrote a simulator which exported translations and rotations of all rigid
bodies at the end of each simulation step to disk, just don't know how to render
running rigid bodies. I googled it but couldn't find useful tutorials on this
subject, so any pointers?
Thanks.
Cheers,
Gfans
Subject: Re: How to render rigid bodies
Date: 27 Aug 2014 11:45:01
Message: <web.53fdfcf8abc43c4c2a2f6d020@news.povray.org>
"Gfans" <nomail@nomail> wrote:
> Hi all,
> using Pov-Ray 3.6.
> Thanks.
> Cheers,
> Gfans
I have no idea what a "running rigid body" could be. May be something is lost in
translation here. "rigid" means something like "stiff" and "body" can be a
corpse, but stiff corpses doesn't run (usually). Ok, that's a bit sarcastic, but
I hope you got my point. I - and I believe others - need more explanation of
what you really want to do. If you have a reference image please post it (if it
doesn't work here, use the binary-images section - but usually one can post
images to the animations section)
Best regards,
Michael
Date: 27 Aug 2014 12:36:13
Message: <53fe08fd@news.povray.org>
>> Hi all,
>> using Pov-Ray 3.6.
>> Thanks.
>> Cheers,
>> Gfans
   The term rigid body is usually used in physics simulations as to mean
a solid which doesn't deforms, just moves and bounces on other objects.
   I think he means that he does know hoe to render still images, but
not how to render animations. If so, I will point him to:
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.7#Making_Animations
jaime
Date: 27 Aug 2014 13:50:00
Message: <web.53fe1940abc43c4c2a2f6d020@news.povray.org>
> >> Hi all,
> >> using Pov-Ray 3.6.
> >> Thanks.
> >> Cheers,
> >> Gfans
> jaime
Thank you Jaime for the explanation. I assumed that "rigid body" is a fixed term
within a certain branch of computer sciences. But since we have so many branches
nowadays I simply could not put it. Now I think Gfans tries something similar to
your Bullet Physics and so you may be his best advisor. I do not like bullets,
since they are designed to kill people, but I really like your animations and I
really wonder how your animaton would look like using this cat from John (and
the boulders Christoph has proposed).But this is another story.
I could not do this job. My interest in CG is more the work of Przemyslaw
Prusinkiewicz, which I observe closely and hope to have an implemntation to
(Uber-)POV someday.
Best regards,
Michael
Date: 28 Aug 2014 03:30:00
Message: <web.53fed96fabc43c4cdcff94bd0@news.povray.org>
> >> Hi all,
> >> using Pov-Ray 3.6.
> >> Thanks.
> >> Cheers,
> >> Gfans
> jaime
Thanks, Jaime. That's exactly what I meant. Thank you for the link, I will take
a look at that, hope Povray 3.6 also support that feature, since I can only use
3.6 instead of 3.7. ^-^
Gfans
Date: 28 Aug 2014 03:30:01
Message: <web.53feda51abc43c4cdcff94bd0@news.povray.org>
"MichaelJF" <mi-### [at] t-onlinede> wrote:
> > >> Hi all,
> > >> using Pov-Ray 3.6.
render
> > >> Thanks.
> > >> Cheers,
> > >> Gfans
> > jaime
> (Uber-)POV someday.
> Best regards,
> Michael
Thank you, Michael. Just as you said, Jaime could be my best adviser. He already
gave me a link to animation.
Gfans
Date: 28 Aug 2014 03:52:04
Message: <53fedfa4$1@news.povray.org>
Am 28.08.2014 09:25, schrieb Gfans:
Why is that? Any technical reasons?
Date: 28 Aug 2014 05:25:00
Message: <web.53fef4e2abc43c4cdcff94bd0@news.povray.org>
I have a legacy code which modified the source code of povray 3.6, so it's best
to work with version 3.6 in my project.
BTW, do you by any chance know tutorials which gave step-by-step instructions on
how to render rigid bodies using POV-Ray?
Thanks.
Cheers,
Gfans
Date: 28 Aug 2014 12:18:48
Message: <53ff5668@news.povray.org>
Am 28.08.2014 11:22, schrieb Gfans:
Mind telling us what that modification does, so we might help you port
it to POV-Ray 3.7?
Date: 29 Aug 2014 12:04:31
Message: <5400a48f$1@news.povray.org>
   Well, I don't think the max speed of such a truck would allow to do
any interesting stunt... :)
> (Uber-)POV someday.
   Indeed the maths in nature always look very interesting... the ones
behind seashell patterns always amazed me.
jaime
