POV-Ray : Newsgroups : povray.animations : Adolescent’s_delight Server Time
3 May 2024 17:43:21 EDT (-0400)
  Adolescent’s_delight (Message 1 to 9 of 9)
Subject: Adolescent’s_delight
Date: 8 Jun 2012 07:38:57
Message: <4fd1e451$1@news.povray.org>
I mentioned in p.o.t (Re: Need to put a picture here) that I was making
an animation to reproduce something I read in a book many years ago. A
woman was wearing a dress to a party. The material became transparent in
random patches.
The latest WIP is here. (Partial nudity, if your eyes are quick enough)
http://youtu.be/_PpJHBg44rA
I am not happy with the pattern of transparency and after lots of
experimentation this is the best I can come up with. I would appreciate
it if anyone could point to a better method.
even incrementing it by 1/5000000000 per frame makes the output too
jerky. I feel that I am taking the wrong approach.
The code follows.
#declare Dress_Map_Pos1 = 0.3  ;
#declare Dress_Map_Pos2 = 0.7  ;
#declare Turb_x = 2.5 ;
#declare Turb_y = 1 ;
#declare Turb_z = 2.5 ;
#declare Turb = < Turb_x,Turb_y,Turb_z>      ;
#declare Lambda_Var = 3 ;        ;
#declare Phase_Var =  0.000   + (frame_number/(5000000000)) ;
#declare JessiDress_1_=
material{
       gradient < 0.000, 1.000, 0.000 >
       pigment_map {
   [Dress_Map_Pos1,
     uv_mapping
     image_map{
       jpeg "JessiSet2.jpg"
       interpolate 2
       map_type 0
       filter all 0.000
       transmit all 0.000
   [Dress_Map_Pos1 +.01,
     colour rgbft <1.000,0.000,0.000,0.000,1.000>
   [Dress_Map_Pos2 -0.01,
   [Dress_Map_Pos2,
     uv_mapping
     image_map{
       interpolate 2
       map_type 0
       filter all 0.000
       transmit all 0.000
       frequency 3.000
       phase Phase_Var
       scallop_wave
       noise_generator 3
       warp {
         turbulence <Turb_x,Turb_y,Turb_z>
         octaves 4
         lambda Lambda_Var
         omega 0.3
       warp {
         turbulence <Turb_x,0,Turb_z>
         octaves 4
         lambda Lambda_Var
         omega 0.3
Regards
Subject: Re: Adolescent’s_delight
Date: 10 Jun 2012 04:50:48
Message: <4fd45fe8$1@news.povray.org>
I changed the blend map pattern to marble, which gives a slightly better
pattern to the transparency, I think.
The biggest difference to the animation was adding uv_mapping to the
material{
   uv_mapping
Comments?
  http://youtu.be/jvZfbKGbUDs
Regards
Date: 10 Jun 2012 12:15:21
Message: <4fd4c819$1@news.povray.org>
> material{
> texture {
> uv_mapping
> pigment {
> Comments?
Looks beter, but somewhat lacking in realism.
Normaly, those transparency are at least somewhat dependent on the
vewing angle. The light's incidence angle also have an effect.
You should probably explore something using the aoi (angle of incidence)
pattern.
For that, you'll need to use version 3.7.
Date: 10 Jun 2012 21:30:59
Message: <4fd54a53@news.povray.org>
Other things that could have an effect
- curvature of fabric
- stretching / acceleration of fabrik
- distance from skin
all not so easy to get as pattern, but if the pattern were not
random but related to the movement the effect would probably
look more natural.
Date: 11 Jun 2012 05:11:24
Message: <4fd5b63c$1@news.povray.org>
Thanks, but I don't know about realism. It is suposed to be a SF fantasy
material.
> pattern.
Definitely something to think about.
And that can be arranged. :-)
Regards
Date: 11 Jun 2012 05:25:34
Message: <4fd5b98e@news.povray.org>
I agree with your points.
But I am just playing around just now and for simplicity will only
consider the curvature of the fabric.
> look more natural.
That would be changing the criteria. :-)
I will keep the randomness but try to make the transparency somewhat
dependant on the viewing angle. My first thoughts are nested texture
maps with the transparent lower ones using the aoi feature.
My tests with just aoi gave a too course pattern.
Thanks to both you and Alain.
Regards
Date: 14 Jun 2012 03:28:51
Message: <4fd992b3$1@news.povray.org>
Probably the final version with an aoi section between the transparent
and semi- transparent parts. I cannot tell if it is any better having
watched it and other versions too much.
http://youtu.be/xSoFrFC51Lg
Regards
Date: 17 Jun 2012 18:34:59
Message: <4fde5b93$1@news.povray.org>
Seems better to me ;)
Date: 19 Jun 2012 16:15:44
Message: <4fe0ddf0$1@news.povray.org>
On 17/06/2012 11:36 PM, Christian Froeschlin wrote:
> Stephen wrote:
>> I cannot tell if it is any better having watched it and other versions
>> too much.
Thanks, now to make the material in RL. ;-)
Regards
