POV-Ray : Newsgroups : povray.animations : Moving Shadows and Reflections Server Time
29 Apr 2024 10:41:10 EDT (-0400)
  Moving Shadows and Reflections (Message 1 to 6 of 6)
Subject: Moving Shadows and Reflections
Date: 26 Jan 2012 13:00:00
Message: <web.4f2193887182d2cdd7ae32040@news.povray.org>
Hi everyone,
I just wanted to show you a video I created using Jaime's office scene obtained
from http://www.ignorancia.org/en/index.php?page=The_office . The video I
created is kept here at
http://www.doc.ic.ac.uk/~ahanda/output_with_shadows_and_reflections_moving.avi .
I had created this video by placing the camera (no
change anywhere else in the code!) at various different locations and obtained
the images. What you'd notice is that the shadows and reflections are moving. I
don't know whether it has to do with radiosity settings so that if I add more
rays it will remove this kind of thing because I certainly know that light
source is fixed. I have rendered this video using 2 passes:  radiosity saving in
one pass and using it the next pass as mentioned on his website. Can you tell me
if there's anything I can do to make sure I obtain stationary shadows and
reflections? The video being 333MB may take a while to download in case you need
few images you can also obtain them here at
www.doc.ic.ac.uk/~ahanda/POVRayimages.tgz . All you need to do is to play them
one by one to see what's happening!
Thanks,
Ankur
Subject: Re: Moving Shadows and Reflections
Date: 27 Jan 2012 10:43:53
Message: <4f22c639@news.povray.org>
   Well, what you are noticing is not really any shadow or reflection
movement... these are radiosity artifacts. What you call "shadows" are
really directly visible splotches, which are also visible on the
reflections. As these splotches are different for each frame, you see
them as "moving".
   Apart from the suggestions from Alain on a similar post from August, I
can't think on anything else. My experience with animation is almost
zero, so I never had to deal with this problem, but I'm guessing it has
no easy solution, or at least not a fast one as you want... ;)
Jaime
Date: 27 Jan 2012 14:24:11
Message: <4f22f9db$1@news.povray.org>
On 1/26/2012 11:57 AM, handos wrote:
> Hi everyone,
It looked so neat that I thought I'd try to render it myself, however
the t_black_plastic texture seems to be missing. I've got POV 3.7rc3
installed; could it be from a previous version of POV that was not
carried forward into 3.7?
Date: 27 Jan 2012 14:31:01
Message: <4f22fb75@news.povray.org>
   No, it's supposed to be declared in "i_textures.inc": do you have this
file? Perhaps the download got corrupted...
Jaime
Date: 27 Jan 2012 16:27:18
Message: <4f2316b6$1@news.povray.org>
I apologize, my mistake, POV could not find various images because they
were in the maps/ folder.
I have moved all the files in the maps/ folder to the same folder in
which office.pov exists and office.pov now renders correctly -- a very
nice image!
Sorry, I should have looked at the error message more closely.
Date: 22 Feb 2012 18:45:13
Message: <4f457e09$1@news.povray.org>
Am 27.01.2012 16:43, schrieb Jaime Vives Piqueres:
> them as "moving".
If you are using a static scene, radiosity artifacts should be
comparatively easy to get "static" by saving radiosity data and re-using
it from frame to frame. Beneficial side effect is a good deal of speedup
for the rendering, as radiosity has to be sampled only for areas that
hadn't been visible to the camera in previous frames.
You might also want to do a first low-fps low-resolution pass to gather
radiosity data, and then use that in the high-resolution render proper.
