POV-Ray : Newsgroups : povray.animations : Train Server Time
26 Sep 2024 19:31:57 EDT (-0400)
  Train (Message 1 to 10 of 12)
Subject: Train
Date: 17 Jul 2008 16:30:00
Message: <web.487fab279da7cba75f60ef1e0@news.povray.org>
How can I make an animation of a train that follows curves and elevation? Is
there anyway to lay track on it, either?
Thanks.
Subject: Re: Train
Date: 17 Jul 2008 16:55:01
Message: <web.487fb128729c1011210497120@news.povray.org>
> Thanks.
You can use a spline to build the tracks and have the train follow the a spline
using the spline_trans() macro.  You would define a spline, then write your own
macro to use it to determine where the objects for the tracks and ties should
go.
  If the changes in elevation are not too great and the curve is gentle, you may
be able to use the same spline for the train's motion and the tracks.
-Reactor
Subject: Re: Train
Date: 17 Jul 2008 23:54:35
Message: <488030DD.8010109@joplin.com>
> Thanks.
Splines are the way to go like 'Reactor' said.
I would also say start first with the height field. I have a series of
programs for making them.(written for win98) One of witch uses contour
lines to make a height field, One to manipulate height fields and One to
place things on them.
They are here:
  http://leroywhetstone.s5.com
Subject: Re: Train
Date: 18 Jul 2008 00:06:17
Message: <4880339D.5060506@joplin.com>
OH! If you do use any of those programs let me know how they worked for you.
Subject: Re: Train
Date: 18 Jul 2008 03:55:00
Message: <web.48804bad729c10115f60ef1e0@news.povray.org>
> > Thanks.
> They are here:
Is the height field just for the landscape? Splines can go up and down, too, so
I assume that I should use that. This is a subway, so I think that there
wouldn't be height fields, right?
Subject: Re: Train
Date: 18 Jul 2008 12:50:06
Message: <4880E69F.3020706@joplin.com>
Yea! Your right! When I thought of a train I though of wide open spaces
with smoke blowing as it clumb up a mountain.
But if your doing a subway Splines are better!
I used a 'sphere sweep' for a tunnel in my animation 'Free Knight Out'
     http://www.irtc.org/anims/2002-07-15.html
Have Fun!
Subject: Re: Train
Date: 19 Jul 2008 04:20:00
Message: <web.4881a293729c10115f60ef1e0@news.povray.org>
> Thanks.
Is there an easy method for regulating the spacing? In other words...
I always use 1 foot scales for my coordinates for ease in designing and
visualizing, and I need to accelerate the train and keep it going at a smooth
speed. This would necessitate the float for each vector in the spline to be how
many feet from the end of the track. Is there a way to follow the spline by
length along the spline on the clock value? I'm thinking that I just label all
key points as 1, 2, 3, ..., then use a small program to determine the distances
between the key points (make small subdivisions and Pythagorean theorem, add it
up), then output it to a file, change the 1, 2, 3 to the feet? Or is there a
macro for this or some feature all ready?
Subject: Re: Train
Date: 19 Jul 2008 04:45:00
Message: <web.4881a898729c10115f60ef1e0@news.povray.org>
> Thanks.
Right now mostly doing station design work but playing with the splines.
I coded this and got a tunnel:
#declare Train_Path = spline {
 cubic_spline
 -2, <0, 0, -10>,
 -1, <0, 0, -5>,
 0, <0, 0, 0>,
 250, <0, 0, 250>,
 300, <30, 0, 290>,
 350, <60, 0, 330>,
 600, <60, 0, 580>,
 601, <60, 0, 590>,
 602, <60, 0, 600>
#declare Counter = 0;
#while(Counter <= 600)
 object { Tunnel Spline_Trans(Train_Path, Counter, y, 0.1, 0) }
 #declare Counter = Counter + 0.0625;
But it's a very sad tunnel:
http://www.flickr.com/photos/helveticafanatic/2681282339/
What is wrong? Do I need more keypoints or something?
In tunnel planning, though, I should draw it on graph paper and find the key
points, right?
Subject: Re: Train
Date: 19 Jul 2008 06:07:27
Message: <4881bcdf@news.povray.org>
"HelveticaFanatic" <nomail@nomail> wrote in message
news:web.4881a293729c10115f60ef1e0@news.povray.org...
>> Is
>> Thanks.
> smooth
> be how
> by
> all
> distances
> add it
> a
The 'vlength' function calculates the length of a vector, so you can
subtract the coordinates of one position from the coordinates of another,
then use vlength to find the distance between them (in POV-Ray units).  It's
generally best to avoid writing to files if you can because there's usually
a performance penalty to pay.
The following example is a complete test scene file. Although it doesn't
contain a camera or objects it writes debug messages into the message
stream. Note that the second test on the #while loop is just to avoid
infinite loops in case you set DistanceTravelled to a length that takes you
off the end of the spline. In your animation you would define
DistanceTravelled based on the clock and your acceleration profile. The very
short #while loop ends when SplineIndex holds the value you seek. You can
increase the accuracy as necessary by reducing the value of Increment.
#declare YourSpline = spline {
    cubic_spline
    -.25, <0,0,-1>
    0.00, <2,0,0>
    1.00, <1,0,2>
    1.25, <0,0,1>
#declare SplineEnd = 1;
#declare DistanceTravelled = 20;
#declare Increment = 0.1;
#declare CumulativeDistance = 0;
#declare SplineIndex = 0;
// Loop through the spline for the required distance
#while (CumulativeDistance < DistanceTravelled & SplineIndex < SplineEnd)
CumulativeDistance+vlength(YourSpline(SplineIndex+Increment)-YourSpline(SplineIndex));
  #declare SplineIndex  = SplineIndex  + Increment;
  // Write some messages to the message stream
  #debug concat("SplineIndex: ",str(SplineIndex,3,3),"\n")
  #debug concat("CumulativeDistance: ",str(CumulativeDistance,3,3),"\n")
  #debug concat("Position Vector:
",vstr(3,YourSpline(SplineIndex),",",3,3),"\n\n")
Chris B.
Subject: Re: Train
Date: 19 Jul 2008 06:11:44
Message: <4881bde0@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:4881bcdf@news.povray.org...
>>> elevation? Is
>>> Thanks.
>> smooth
>> be how
>> by
>> label all
>> distances
>> add it
>> there a
> It's generally best to avoid writing to files if you can because there's
> usually a performance penalty to pay.
> you off the end of the spline. In your animation you would define
> very short #while loop ends when SplineIndex holds the value you seek. You
> can increase the accuracy as necessary by reducing the value of Increment.
>    cubic_spline
>    -.25, <0,0,-1>
>    0.00, <2,0,0>
>    1.00, <1,0,2>
>    1.25, <0,0,1>
I meant to say:
    cubic_spline
    -.25, <0,0,-1>
    0.00, <20,0,0>
    1.00, <1,0,20>
    1.25, <0,0,1>
The other example illustrates the scenario where the distance is greater
than the length of the spline :-)
Chris B.
