POV-Ray : Newsgroups : povray.animations : Using variable camera angle based on a spline in animation Server Time
9 Jun 2026 18:28:24 EDT (-0400)
  Using variable camera angle based on a spline in animation (Message 1 to 5 of 5)
Subject: Using variable camera angle based on a spline in animation
Date: 18 Oct 2007 03:25:00
Message: <web.4717092ad763296647d3ae5e0@news.povray.org>
Hi!
Tried using this setting for camera angle, that varies a bit in the
animation:
#declare vinkel = spline {
   natural_spline
    0.00,   80,
    0.10,   70,
    0.30,   60,
    0.60,   75,
    0.75,   75,
    0.85,   75,
    1.00,   80
  location  kamera(clock)
  look_at   looks(clock)
  right     x*640/360
  angle vinkel(clock)
But POV-Ray warns about a "float expected but color or vector expression
found". Any ideas on how I could get the camera to accept these values
would be greatly appreciated!
//Rush
Subject: Re: Using variable camera angle based on a spline in animation
Date: 18 Oct 2007 03:58:04
Message: <4717120c@news.povray.org>
Try:
angle vinkel(clock).y
Charles
Date: 18 Oct 2007 04:30:02
Message: <web.47171946391d03747d3ae5e0@news.povray.org>
Charles C <nos### [at] nospamcom> wrote:
> Try:
> Charles
Yay! Rendering just fine! Thanks a lot! :D
(Umm.. What did we exactly do?)
Anyways, check out bin.anim soon! ;)
Date: 18 Oct 2007 15:15:55
Message: <4717b0eb@news.povray.org>
>> Try:
>> Charles
Wait, did you write this spline or did some spline editor you used write
this spline? I'm not sure what you know or don't know on splines so
sorry if I end up over-answering... :-)  Anyway a spline returns a 3D
vector.  You can specify which specific float value you want out of that
vector with .x or .y or .z which in this case solves the problem of the
incorrect type given for 'angle'.
Why .y and not .x or .z?  A spline takes in floats and vectors but
you're feeding it all floats. The second number on each line of your
spline would normally be a 3D vector, so I'm assuming that your spline
the way you have it would effectively expand to:
    natural_spline
     0.00,   <80,80,80>,
     0.10,   <70,70,70>,
     0.30,   <60,60,60>,
     0.60,   <75,75,75>,
     0.75,   <75,75,75>,
     0.85,   <75,75,75>,
     1.00,   <80,80,80>
That'd mean that .x .y and .z would all work just as well but maybe it's
easier (to me) in this case to think of the floats in the left column as
x-values and the values in the right column as y-values in a 2D graph...
     Something like that.
Will do!
Charles
Date: 19 Oct 2007 14:20:01
Message: <web.4718f4ef391d03747d3ae5e0@news.povray.org>
Ah, I see!
Well at least I think I see, and Im happy with that. =)
It was the "." that had me confused, or rather it's function. But if it
works, it works. And it did.
Link to animation posted at:
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.4718f31675c5d9a447d3ae5e0%40news.povray.org%3E/
Thanks again!
