POV-Ray : Newsgroups : povray.animations : trouble with rune (particule system) and a sphere Server Time: 6 Sep 2008 16:54:27 GMT
  trouble with rune (particule system) and a sphere (Message 1 to 6 of 6)
Subject: trouble with rune (particule system) and a sphere
Date: 25 Sep 2007 11:20:00
Message: <web.46f8ee5e8d5b23a3be9c7f8d0@news.povray.org>
Hi everyone!
I have some trouble with a particule systeme called "rune".
So, I want to do a kind of power ball by putting a particule system in a
sphere. I wrote in the particule parameters that the sphere will have to
block the particules themselves, like that the particules shouldn't go out
of the sphere, but it's not working. I thought that it was because the
system was already un the sphere so it couldn't detect the collision, so i
changed the sphere by a difference of 2 sphere, like that the particule
emitter is not in the sphere really, but in the hole inside the sphere...
but it doesn't work neither, the particules a still going through the
sphere :(, so i wonder what's wrong, and what i can do...
if anyone has an idea...
thk a lot
J-E
Subject: Re: trouble with rune (particule system) and a sphere
Date: 25 Sep 2007 11:50:00
Message: <web.46f8f52ff5ab9856c4e49fa40@news.povray.org>
"chtisaxo" <chtisaxo [at] gmailcom> wrote:
> Hi everyone!
> thk a lot
> J-E
Actually, Rune is the guy who wrote the particle system. His site is:
http://runevision.com/3d/
I used it a few years ago to make an animation of a bagatelle board so it
should work for what you want. I wonder since your particles are inside the
sphere to start with you should use the Inverse keyword in the sphere.
[Joke] Don’t use Hollow unless you want to wind up Warp. [/Joke]
Date: 25 Sep 2007 12:05:00
Message: <web.46f8f952f5ab9856be9c7f8d0@news.povray.org>
if you want i can put the source i'm trying to render:
light_source {<-500,500,150> color rgb 1.3 }
camera {location <0,0,-5> look_at <0,0,0>}
// sphere which stop particules
#declare bloqueur =
sphere {
  <0,0,0>, 2
 clipped_by{sphere {<0,0,0>,1.8 inverse}}
   // Include particle system include file
   #include "particle.inc"
// Clock settings
   #declare particle_start  = -1;
   #declare particle_end    = 1.0;
   #declare particle_cyclic = on;
   #declare particle_steps  = 20;
// General particle settings
   #declare particle_frequency = 10;
   #declare particle_life      = 1.5;
   #declare particle_lifeturb  = 0.0;
   #declare particle_seed      = 120;
   //#declare particle_maxnumber = 50;
// Environment settings
   #declare particle_drag      = 0.0;
   #declare particle_transfer  = 0.0;
   #macro particle_gravity  (Clock,Point) 0*y #end
   #macro particle_wind     (Clock,Point) <0,0,0> #end
// Emitter settings
   #macro particle_emitter  (Clock) <0,0,0>  #end
   #macro particle_emitting (Clock) on      #end
   #macro particle_emitvect (Clock) <5,0,0> #end
   #macro particle_emitturb (Clock) 0     #end
 #macro particle_emitobj(Clock) sphere{<0,0,0>,1} #end
   #macro particle_emitobjn (Clock) 1.2 #end
// Collision settings
#declare particle_blockobj =bloqueur;
#declare particle_bounce = 0.5;
#declare particle_bounceturb = 0.5;
#declare particle_friction = 0.0;
#declare particle_bounceoffset = 0.1;
// Particle element macro (optional)
   #include "glow.inc"
// These settings are constant in this example, so they can
// be #declared outside of the particle_element macro.
   #declare glow_color     = <2,2,0.5>/0.8;
   #declare glow_colorturb = <0.3,0.3,0.3>;
   #declare glow_size      = 0.3;
   #declare glow_samples   = 5;
   #macro particle_element ()
//    Do things with the particle data here. Available data:
//    p_id,        p_random,    p_location,  p_direction, p_life,
//    p_age,       p_birth,     p_state,     p_rotate
      glow_element()
// Call particle system
   particle_system ("partsys")
so here it is.. i putted this inverse keyword, but it's still not working...
thx anyway for this very fast answer!
i hope you will be able to help me ;)
J-E
Date: 25 Sep 2007 12:20:33
Message: <46f8fd11@news.povray.org>
Clipped_by is not really the same as difference. Try to use instead:
#declare bloqueur =
difference {
   sphere {<0,0,0>,2.0}
   sphere {<0,0,0>,1.8}
I hope that helps.
Rune
Date: 25 Sep 2007 12:35:01
Message: <web.46f9005df5ab9856c4e49fa40@news.povray.org>
> #declare bloqueur =
> sphere {
>   <0,0,0>, 2
[snip]
> J-E
Hi, It has been a long time since I used Rune’s system and I can’t remember
all the settings but try the small change below. Note that the inverse is
not in the clipped_by sphere.
#declare bloqueur =
sphere {
  <0,0,0>, 2
 clipped_by{sphere {<0,0,0>,1.8 }}
inverse
When using someone else’s include files it is a good idea to start simple
then incorporate it in your scene
Date: 25 Sep 2007 16:40:00
Message: <web.46f938f9f5ab9856be9c7f8d0@news.povray.org>
ok, rune's solution is working quiet well,it's exactly what i wanted to do.
thanks a lot Stephen, to answer also, you were very efficent, thx to both
of you!
Copyright 2003-2008 Persistence of Vision Raytracer Pty. Ltd.
