POV-Ray : Newsgroups : povray.animations : Need help Rotating Server Time
28 Sep 2024 20:16:30 EDT (-0400)
  Need help Rotating (Message 1 to 8 of 8)
Subject: Need help Rotating
Date: 28 Jan 2006 15:45:01
Message: <web.43dbd7781a56a32b984f60a80@news.povray.org>
Hello, and Thanks ahead of time for any help!!
I'm a chemist and use Povray to render my molecules and it works great.
I've also made short animations of molecules spinning in space, no problem.
 Now I have hard one that I need help with.  I made a simple structure and
I manage to define it into pieces. I want piece 1 to remain stationary, but
I want piece 2 to rotate 180 degrees about and axis.  Sounds easy, but I
can't define this axis, whenever I rotate the molecule, it always uses the
origin (where my wanted rotating piece 2 is no where near) and a second
point that I can define. This generates images of bonds breaking and atoms
flying off.  Can anyone help??  The povray guides keep talking of vectors
and I want to define a vector (<X, Y, Z>, <x, y, z>) as my axis to rotate
around.
Thanks again,
Charlie R.
Univ of NV, Reno
Subject: Re: Need help Rotating
Date: 28 Jan 2006 16:39:55
Message: <43dbe4ab$1@news.povray.org>
"Charlie" <crr### [at] hotmailcom> wrote in message
news:web.43dbd7781a56a32b984f60a80@news.povray.org...
> problem.
> but
> around.
> Thanks again,
> Charlie R.
> Univ of NV, Reno
In transforms.inc there's an Axis_Rotate_Trans macro.
You should be able to translate your object (the piece you want to rotate)
to the origin, rotate it around the axis of your choice then translate it
back.
Chris B.
Date: 29 Jan 2006 02:40:01
Message: <web.43dc7088fd2cbf889926319c0@news.povray.org>
So if I understand this right you've got 2 points in space, call them C and
D, and you want to use the vector from C to D as the axis of rotation of
your molecule-portion...  It sounds like all you need to do is subtract C
from D and then that gets you an appropriete single <X,Y,Z> vector you can
use to use (along with the origin as you mentioned). (Either have the
moving portion built relative to the origin or translate it temporarily to
the origin by translating -C.)  Then after rotating, translate the
molecule-portion over to location C.
not sure if this helps
Charles
> around.
> Thanks again,
> Charlie R.
> Univ of NV, Reno
Date: 30 Jan 2006 11:12:42
Message: <43de3afa$1@news.povray.org>
A trick I use is to always build things I want to animate aound the origin.
The actual point of ratation being at <0,0,0> , and then translate the
object into position.  So I execute the rotation before the translation.
e.g.
box
    <-1,-1,-1>,<1,1,1>
    rotate <0, clock, clock/2>      // this would be where you apply your
rotation varaiable
    translate <10,1000,9>           // translate into position
Date: 10 Feb 2006 22:48:12
Message: <43ed5e7c@news.povray.org>
I was trained in chemistry (uh, metallurgical engineering) and am a complete
whiz at doing complex things with povray.  Is there like an easy 2nd
master's thesis that's doable by solving a complex problem 'with' povray?
Always wondered that.   Or is it like being a whiz at word processing and
thinking therefore you could get an easy law degree.
Date: 3 Jun 2006 13:50:00
Message: <web.4481c5a0fd2cbf883a0196460@news.povray.org>
"Greg M. Johnson" <p t e r a n d o n @ the### [at] startswithYcom>
I'm trying to make a human and this rotating thing also seems a little
dificulte to grasp. I understand that all things should first be rotated
around <0,0,0> this is is fine but...
If you have an object say an arm that is attached to something fixed then as
I understand it you should first rotate the arm, then translate it. Then
rotate the fore arm about the <0,0,0> ,or zero point, translate that, but
then rotate and translate it again as I did with the arm...
Now if I have a upper arm, lower arm, a palm, upper fingers, lower fingers,
and finger tips, that is 6 nested objects then is not the code going to
look somthing like this...
FingerTips...
rotate FingersTips
translate FingersTips
rotate LowerFingers
translate LowerFingers
rotate UpperFingers
translate UpperFingers
rotate Palm
translate Palm
rotate ForeArm
translate ForeArm
rotate UpperArm
translate UpperArm
LowerFingers...
rotate LowerFingers
rotate UpperFingers
rotate Palm
translate Palm
rotate ForeArm
translate ForeArm
rotate UpperArm
translate UpperArm
UpperFingers...
rotate UpperFingers
rotate Palm
translate Palm
rotate ForeArm
translate ForeArm
rotate UpperArm
translate UpperArm
Palm...
rotate Palm
translate Palm
rotate ForeArm
translate ForeArm
rotate UpperArm
translate UpperArm
ForeArm...
rotate ForeArm
translate ForeArm
rotate UpperArm
translate UpperArm
UpperArm...
rotate UpperArm
translate UpperArm
Now as I read the sudo code that I have just written 2 things stand out in
my (small) mind.
1) This code looks S**t. So am I missing the point, as I carn't believe that
those great POV team guys would have intended this.
2) How do I use that rotate about an arbarty axis thingy in the inc files.
Or again, am I missing the point.
Sorry for any spelling mistakes I a god at spellliing.
Date: 3 Jun 2006 15:10:00
Message: <web.4481ddd7fd2cbf88c451256c0@news.povray.org>
Try something like this.
union{
  UpperArm
  union{
    ForeArm
    union{
      Palm
      union{
        UpperFingers
        union{
          LowerFingers
          union{
            FingerTips
            rotate FingersTips
          rotate LowerFingers
        rotate UpperFingers
      rotate Palm
      translate Palm
    rotate ForeArm
    translate ForeArm
  rotate UpperArm
  translate UpperArm
-tgq
Date: 3 Jun 2006 15:51:05
Message: <4481e829@news.povray.org>
"Divine Wind" <div### [at] hotmailcouk> wrote in message
news:web.4481c5a0fd2cbf883a0196460@news.povray.org...
> as
> fingers,
> FingerTips...
> ... snip ...
> my (small) mind.
> that
When I was doing a human, that's one of the things that I also found to be a
bit tricky. There are quite a few approaches you could potentially use. I
settled on one that is quite complex, but it enables me to specify a pose by
simply defining the rotation of each body part relative to the next. I have
a set of macros to do the rest. It also means I can 'fix' the location of
any single body part I wish and it calculates the positions and rotations of
the rest of the body parts relative to that one fixed part.
Essentially I use a series of arrays to hold the body part definitions and
joint definitions along with arrays to hold the relative joint rotations.
Once the pose is set in the joint rotations array I call a macro to
calculate the absolute rotations and translations necessary to rotate and
position each body part, calculating out from a fixed body part that I
define using a control variable. Once this information is calculated I can
work out the shape of things such as clothing that are dependant upon the
body part positions and rotations. The clothing is then added into the
object arrays before calling a macro to build a single object from all of
the bits.
An alpha copy of the SDL that I wrote is available at
http://www.geocities.com/povperson/ along with documentation that outlines
all of the macros and control variables.
In the file povperson.inc there is a macro called ppResolvePose that does
the main part of the calculation.
You can reuse any of those macros or use them for ideas on creating your own
if you wish.
You could also just use the body parts you have created to define a figure
in the right format for povperson, then you get all of the added extras for
free (e.g. the walking animation, hair, the ability to 'morph' between poses
etc.)
Chris B.
