POV-Ray : Newsgroups : povray.animations : Animation Problem Server Time
27 Sep 2024 20:23:34 EDT (-0400)
  Animation Problem (Message 1 to 10 of 11)
Subject: Animation Problem
Date: 10 May 2004 19:30:01
Message: <web.40a00fcf121ad5822a75c0910@news.povray.org>
I'm learning about animation from the tutorial. I rendered the file
"clockdemo.pov." The frames render (about 20), but I can't figure out how
to play it back. Any ideas? (Tutorial didn't tell me that.)
Subject: Re: Animation Problem
Date: 10 May 2004 19:58:39
Message: <40a0172f$1@news.povray.org>
"CFM" <nomail@nomail> wrote in message
news:web.40a00fcf121ad5822a75c0910@news.povray.org...
: I'm learning about animation from the tutorial. I rendered the file
: "clockdemo.pov." The frames render (about 20), but I can't figure out how
: to play it back. Any ideas? (Tutorial didn't tell me that.)
You have to join the individual images together in
a single movie file (AVI, MPG, etc).
Here's some info to help get you started
http://home.pacbell.net/tylereng/links.htm
=Bob=
Date: 11 May 2004 14:40:00
Message: <web.40a11d7fd02b718c3e06d4f80@news.povray.org>
> =Bob=
OK, I went to Wire Frame University and clicked on the Ray Tracing with POV
link. The page told me to create a new directory known as c:povray2lab1
directory.  I don't know how to do that. I never learned that. And is the
text editor screen the window where I write the POV programming language?
Date: 11 May 2004 16:35:00
Message: <web.40a1384ed02b718cd090f22d0@news.povray.org>
Also, I can't get POV to read from the lab1 subdirectory in the POV-ray for
Windows v3.5 directory. Instead, the program reads from the scenes folder.
How do I direct the program to read from another folder/directory?
Date: 11 May 2004 17:20:00
Message: <web.40a14369d02b718cd090f22d0@news.povray.org>
BTW, since I'm required to download certain animation software such as
animtxt.zip, povtick2.zip, dta204.zip, and playflc.zip, is it possible I
can use winzip without having to pay for it? My evaluation period of 30
days ran out some time ago.
Also, the dta204.zip link is broken. What's the site for that so I can
download it?
Date: 11 May 2004 18:59:24
Message: <vlm2a0p1duah369rer9c4jjoeojbvqklce@4ax.com>
>download it?
You can use Winzip for as long as you like. Just press "Use Evaluation
Version" Button every time you use it. Since you are using Winzip It
might be better if you used something like TMPGEnc to make your
animations,
http://www.tmpgenc.net/e_main2.html
Or VideoMach
http://gromada.com/VideoMach_dl.html
dta204 is a DOS program If I Remember Correctly so a windows program
might be easier to use if you are just starting out.
If you want to create a directory, In windows Explorer or My computer
go where you want the directory. In the Menu bar Click File > New >
Folder
Then Name it what you want.
It might be better if when starting with POV-Ray to post in
Povray.newusers
It might be better to start with still images before moving onto
animations. Just to get the feel for Pov-Ray.
BTW Welcome :-}
Regards
Date: 11 May 2004 22:35:01
Message: <web.40a18d28d02b718cd4d6dcd70@news.povray.org>
Thanks for the welcome.
BTW, I still cannot figure out how to get POV to read files besides the
"scenes" folder. How do I get the POV program to read from other folders or
directories?
Date: 12 May 2004 06:08:42
Message: <9st3a0dduobrkv45snl5t31p2tnt1fmf1j@4ax.com>
You're welcome
>directories?
You need to change the settings in povray.ini so that Pov-Ray knows
where to find your files.
Go to Tools > Edit Master POVRAY.INI
And edit the ini file to include the directories you keep your files
in e.g.
Library_Path=H:\Graphics\Moray For Windows V3_5\Maps
Library_Path=H:\Graphics\Moray For Windows V3_5\Maps\Planets
There is a very good manual that comes with Pov-Ray. It is advisable
to read it, from end to end. I know it is tempting to just get "stuck
in" but it is well worth the time. Another point, in the newusers
group people are much more tolerant and very helpful. In the more
advanced groups you tend to get answers like RTFM. Guess what that
means :-}
In case you don't know, It is traditional for your first post to be a
variation of a reflective sphere on a checkered plane
Regards
Date: 12 May 2004 11:01:15
Message: <40a23c3b@news.povray.org>
This style of shareware is usually dubbed "nagware".  However from:
http://www.winzip.com/elicense.htm you can read:
"This is not free software. [....] If you use this software after the
21-day evaluation period, a license fee of $29 is required."
If $29 is too much for a one-time fee (in the past a license has granted
perpetually free upgrades) you can get one of the various free versions
(WIZ, InfoZip and others come to mind, but I use WinZIP and GNU Zip).
Date: 12 May 2004 13:00:01
Message: <web.40a257a1d02b718c1a36c3040@news.povray.org>
> You're welcome
> >directories?
> in e.g.
> Library_Path=H:GraphicsMoray For Windows V3_5Maps
> Library_Path=H:GraphicsMoray For Windows V3_5MapsPlanets
> means :-}
> Regards
>         Stephen
OK, I'll go to newusers. Before I go, I must tell you that I was afraid
you'd say to go to tools > edit master POVRAY.ini. I can't access that. I
get a window that says, "Could not run program."
