POV-Ray : Newsgroups : povray.animations : interlaced movies from povray animations Server Time
27 Sep 2024 20:17:58 EDT (-0400)
  interlaced movies from povray animations (Message 1 to 7 of 7)
Subject: interlaced movies from povray animations
Date: 30 Dec 2003 15:47:04
Message: <3ff1e448$1@news.povray.org>
Hello folks,
I am creating a logo that I am going to mix with DV-PAL footage. What
are the guidelines that I have to follow so that I get interlaced
footage from a povray animation?
Thanks in advance
Fidel.
Subject: Re: interlaced movies from povray animations
Date: 30 Dec 2003 16:20:01
Message: <web.3ff1ebbb9373012e40d56c170@news.povray.org>
Perhaps someone else may come along and answer your question more
intelligently, but  you should remember that the output of povray is merely
a stack of bitmaps (BMP, TGA, PNG, etc.)  It's really up to you to figure
out how to turn these bitmaps into "footage" and I'm afraid I cannot help
you with your specific system.
Greg M. Johnson
Date: 30 Dec 2003 17:57:25
Message: <3ff202d5@news.povray.org>
> Greg M. Johnson
Hi Greg, I have generated a dv-pal file and transfered to my camera, but
the colours are too bright. It looks a bi weird.
I know that povray has something called field-rendering, but I don't
really know how to use it.
It would be nice if someone could guide me.
Thanks in advance
Fidel.
Date: 30 Dec 2003 22:50:01
Message: <web.3ff246e89373012e3a5fb9ba0@news.povray.org>
With all due respect, and as far as I can see (and I'm not omniscient), you
are completely mistaken as to what POV-Ray is.  When we "render," it's
taking line of code like
sphere{z+clock*x, 0.1 pigment{red 1} finish{ambient 1}}
and turning it into a single bitmap.  There's also a way to do animations,
but the output of povray is then a stack of individual bitmaps, and you
have to use totally independent software to turn the stack of bitmaps into
a movie.
Greg M. Johnson
Date: 31 Dec 2003 07:44:18
Message: <3ff2c4a2$1@news.povray.org>
In article <3ff1e448$1@news.povray.org> , Fidel Viegas <non### [at] nodomaincom>
wrote:
> Hello folks,
Take a look at
Newsgroups: povray.animations
Subject: interlaced - which fields first?
Date: Fri, 8 Nov 2002 14:44:16 -0500
Message-ID: <3dcc141b$1@news.povray.org>
Xref: news.povray.org povray.animations:2309
maybe information in that thread is already sufficient.
In short, all you need is a program that can process the "interlaced" format
as output by POV-Ray.  Alternatively, especially if you only plan to have a
static image, you can just render it non-interlaced or depending on other
needs only render with 25 non-interlaced full frames per second, which will
be easier to set up.
    Thorsten
e-mail: tho### [at] trfde
Date: 1 Jan 2004 16:53:04
Message: <3ff496c0$1@news.povray.org>
> wrote:
>>Hello folks,
> Take a look at
> From: "Dennis Miller" <dhm### [at] attbicom>
>     Thorsten
Hi Thorsten,
Thanks a lot for the reply.
I have managed to sort it out with Final Cut Pro. Now what I was
actually looking for you can find it here:
http://www.povray.org/documentation/view/127/
Once again, thanks a lot for the reply.
All the best
Fidel.
Date: 1 Jan 2004 16:57:53
Message: <3ff497e1@news.povray.org>
omniscient), you
> a movie.
> Greg M. Johnson
Hi Greg,
maybe you didn't understand my question. I know what povray is and what
it does.
I am using povray on a Mac. Although I can generate movie files from
povray scripts, I do generate a .tga sequence because I can put it
together with another utility.
I had never generated movies to play on my TV, so hence my question.
There was once a debate about field rendering support on povray. That is
  why I asked.
Anyway, I managed to sort it out with Final Cut Pro.
What I was looking for can be found here:
All the best
Fidel.
