POV-Ray : Newsgroups : povray.animations : Tips for using mencoder (or other encoders)? Server Time
29 Jun 2024 07:34:56 EDT (-0400)
  Tips for using mencoder (or other encoders)? (Message 1 to 10 of 13)
Subject: Tips for using mencoder (or other encoders)?
Date: 3 Dec 2003 00:25:16
Message: <cjameshuff-800C65.00243803122003@netplex.aussie.org>
I've been trying to use mencoder under Linux to generate MPEG
animations, with only partial success. I can get a mostly-working
animation, but the image is squashed into a square on the left side, and
it won't play properly in Quicktime. And there's a huge number of
options, the documentation is mixed in with a bunch of other junk, and I
can't find any tutorials...any suggestions?
Alternatively, maybe someone can suggest another encoder...
http://tag.povray.org/
Subject: Re: Tips for using mencoder (or other encoders)?
Date: 3 Dec 2003 02:49:17
Message: <3fcd957d$1@news.povray.org>
 > I can't find any tutorials...any suggestions?
Have you looked at "Chapter 7. Encoding with MEncoder" in the documentation?
http://www.mplayerhq.hu/DOCS/HTML/en/mencoder.html
The first two subchapters are about encoding MPEG animations.
There is also a file with encoding tips:
http://www.mplayerhq.hu/DOCS/tech/encoding-tips.txt
Just my 2 eurocents,
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
"Hi. I'm a signature virus. Add me to your signature - help me spread!"
Date: 3 Dec 2003 12:58:29
Message: <3fce2444@news.povray.org>
If the image disortion is 1/4 black, it may be a 4-byte RBG versus
3-byte RGB problem, notably when encoding from non-YUV sources (i.e.
not jpeg). I once wrote a very dirty patch to make PNG -> MPEG encoding
work but it will not apply to recent versions.
Hard to tell more from your unspecific description "won't play properly".
Ah, and don't use too many fancy flags with MPEG1, a lot of them
need higher versions (mpeg4).
Just what came to my mind...
Wolfgang
Date: 3 Dec 2003 14:58:57
Message: <cjameshuff-3550D5.14582203122003@netplex.aussie.org>
In article <3fce2444@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
Great...I've been trying to encode from PNG.
Starts playing ok, except that the right 1/4 of the image is black and
the actual contents of the movie are squashed into a square on the left
side, and about 1/4 of the way into the movie it sometimes stops
playing. Playback is jerkier than it should be.
I don't even know any "fancy flags". I'm just trying to get something to
work. And the error messages are incredibly unhelpful...
Date: 3 Dec 2003 15:12:37
Message: <cjameshuff-176303.15120203122003@netplex.aussie.org>
In article <3fcd957d$1@news.povray.org>, Bonsai <bon### [at] b0n541net>
The command lines options they give don't work. They sometimes give
errors (something about parsing the command line...no more information
given), and sometimes just don't do anything (program starts, writes
some info to the screen, and quits without giving any reason). That
documentation seems to be out of date as well...I get a message that -mf
is deprecated, but no information about what to do instead.
I'm now trying with TGA format images, hopefully this will work...
Date: 3 Dec 2003 16:00:23
Message: <cjameshuff-E7AA82.15594803122003@netplex.aussie.org>
In article <cja### [at] netplexaussieorg>,
It did: http://home.earthlink.net/~cjameshuff/files/test.mpeg
(A test image from some patches I've been working on...can you guess
what I did?)
Date: 4 Dec 2003 01:38:24
Message: <taltsv8rnthtb66fh9jd2ftvhnbtp9nge0@4ax.com>
On Wed, 03 Dec 2003 15:59:48 -0500, Christopher James Huff
> can you guess what I did?
Like typical newbie you started from sphere over plane but I noticed
strange distortions in reflectivity and in checkered pattern ;-)
ABX
Date: 4 Dec 2003 08:37:22
Message: <cjameshuff-928220.08365004122003@netplex.aussie.org>
In article <taltsv8rnthtb66fh9jd2ftvhnbtp9nge0@4ax.com>,
No reflectivity. No normal either...just a pigment. And the pigment is
constant, it doesn't change with time. ;-)
Date: 4 Dec 2003 16:04:24
Message: <3fcfa157@news.povray.org>
Try encoding from multiple jpegs. If the problem persists, it is not
related to the mentioned colorspace convention bug. Otherwise it
probably is.
I'm sorry for not testing myself but I currently lack a recent version
and am just too busy with other things.
Reminds me of the color conv problem.
I had color disortion in addition to the 1/4 screen problem.
Maybe I can look into that at the weekend; stay tuned :)
Wolfgang
Date: 4 Dec 2003 20:02:20
Message: <cjameshuff-56DD04.20015004122003@netplex.aussie.org>
In article <3fcfa157@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
> probably is.
You're a bit behind...I successfully did it with TGA files. Which means
I'll have to convert to PNG if I want to archive an animation, and
convert back to TGA to make another movie...but I probably won't be
doing that kind of thing much anyway.
