POV-Ray : Newsgroups : povray.animations : Animation Control (time frames I Guess) Server Time
28 Sep 2024 22:12:33 EDT (-0400)
  Animation Control (time frames I Guess) (Message 1 to 10 of 15)
Subject: Animation Control (time frames I Guess)
Date: 13 Sep 2003 23:14:20
Message: <Xns93F5EBFDF15EFPOVMIKA@204.213.191.226>
Hi again!
During an animation sequence, if an object is to:
    	do something for 2 seconds
    	stay idle for 3 seconds
    	do something for 3 seconds
What method or methods have any of you used in your code for
this type of control?
Assuming:
    	+kff???
    	+ki0 (default)
    	+kf1 (default)
    	And that we encode the final animation at 25 fps.
Would one use something like this to figure out where in time
we are?
#declare T = frame_number / 25 ;
#if ( T<2 | ( T>5 & T<8 ) )
    	do something
This seems obvious but maybe there are other proven
techniques one could use.
Thanks
Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Subject: Re: Animation Control (time frames I Guess)
Date: 14 Sep 2003 03:46:00
Message: <3f641cb8$1@news.povray.org>
"Marc Champagne" <marcch.AT.videotron.DOT.ca> wrote in message
> Assuming:
>     +kff???
>     +ki0 (default)
>     +kf1 (default)
> we are?
>     do something
> #end
Seems okay to me. There's #range, used in #switch directive, that I might
use for this kind of purpose too. Goes like so:
#switch (T)
#range (0,2)
/* do first thing */
#break
#range (5,8)
/* do second thing */
#break
Except this wouldn't prevent the exact values 2, 5 and 8 from being taken
into account; unlike your #if directive method, which I'd say is perfectly
fine in that particular example. You just don't need the parenthesis around
T>5&T<8 for it to work right, I believe.
Bob H.
Date: 14 Sep 2003 07:09:09
Message: <Xns93F6485B1CEA6POVMIKA@204.213.191.226>
"Hughes, B." <omn### [at] charternet> wrote in
news:3f641cb8$1@news.povray.org:
>> message news:Xns### [at] 204213191226...
>> Assuming:
>>     +kff???
>>     +ki0 (default)
>>     +kf1 (default)
>> time we are?
>>     do something
>> #end
> directive, that I might use for this kind of purpose too.
> Goes like so:
> #switch (T)
> #range (0,2)
> #break
> #range (5,8)
> #break
> #end
> from being taken into account;
For (#range) the docs say:
  If Low_Value <= Switch_Value and Switch_Value<=High_Value
  then the condition is true.
I havn't tried #range directive yet, maybe there is a bug
that i'm not aware of?
> perfectly fine in that particular example. You just don't
> need the parenthesis around T>5&T<8 for it to work right, I
> believe.
The parenthesis just makes things absolutely "clear", I never
liked relying on precedence.
Thanks
Marc Champagne
Montreal, CANADA
Date: 14 Sep 2003 12:42:37
Message: <3f649a7d$1@news.povray.org>
If you're basing your animation off of the frame_number, then the usage of
the clock is useless. In addition, if you later decide you want to render
with 30fps, you have to change the *scene*, rather than just the command
line parameters.
I would suggest having the clock go from 0 to 5, and render 25*5 = 125
frames (0 through 124). Then, in the code, you can just use
#if ( clock<2 | ( clock>5 & clock<8 ) )
This way, the clock is always measured in seconds, and if you ever decide
that you want a different number of frames per second, all you do is change
the number of frames.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 14 Sep 2003 12:55:44
Message: <Xns93F6831E96581POVMIKA@204.213.191.226>
"Slime" <fak### [at] emailaddress> wrote in
news:3f649a7d$1@news.povray.org:
> then the usage of the clock is useless. In addition, if you
> later decide you want to render with 30fps, you have to
> change the *scene*, rather than just the command line
> parameters.
> 25*5 = 125 frames (0 through 124). Then, in the code, you
> can just use
> you ever decide that you want a different number of frames
> per second, all you do is change the number of frames.
A lot more practical this way!
Thanks for the tip
Marc Champagne
Montreal, CANADA
Date: 14 Sep 2003 18:56:34
Message: <3f64f222$1@news.povray.org>
I, for one, would use Chris Colefax's autoclck.mcr and clockmod.inc:
 #declare CLCK = (From (0, 0)  To (.250, 1)  To (.625, 1)  To (1, 0)  ) ;
or whatever. The values are totally negotiable based on whatever clock range
you use.
Extremely useful, and the movement over any range of frames does not have to
be linear (accelerate, decelerate, Bounce, Wave, etc.)
d.
> Hi again!
> Assuming:
>     +kff???
>     +ki0 (default)
>     +kf1 (default)
> we are?
>     do something
> #end
> Thanks
> Marc Champagne
> Montreal, CANADA
Date: 14 Sep 2003 19:06:25
Message: <3f64f471@news.povray.org>
I've always done it the same way:
#declare Animation_Time = [Seconds];
#declare Animation_FPS = 25;
These are two basic parameters all my newer Include-
Files making use of animation-capabilities use. I've even
included a small script inside my LSSM which derives
the amount of frames from POV-Internal-Data. Based
on FPS, it can then calculate the amount of seconds.
And then, I either set my animations with values from
0 to 1 (beginning to end of animation) or with values
from 0 to clock*Animation_Time (beginning to end
of animation in seconds).
Now, thats not much for HOW to actually set things
up, but sticking to a certain, obvious style, makes
things easier in the long run. In this case, someone
else can easily set the LSSM and my Particle-System
into one scene, without having to mix different kinds
of timing systems. Also, I like to think in seconds,
rather than animation time. Its easier to visualize.
Most of the time, I do use
#if (clock*Animation_Time < 3)
#else
or something alike.To have a handy value for any range,
I simply subtract the time when something begins, and
divide it resulting value by the timespan until the next
event occurs.
E.g: Animate from 3rd sec to 5th sec:
#if (clock*Animation_Time>=3 & clock*Animation_Time<=5)
 #declare LocalClock=(clock*Animation_Time-3)/2;
LocalClock will then run from 0 to 1 during those 2 seconds,
and things can be animated very easily with values from 0 to
1 IMHO.
Tim
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> Hi again!
> Assuming:
>     +kff???
>     +ki0 (default)
>     +kf1 (default)
> we are?
>     do something
> #end
> Thanks
> Marc Champagne
> Montreal, CANADA
Version: 6.0.515 / Virus Database: 313 - Release Date: 02.09.2003
Date: 14 Sep 2003 19:45:24
Message: <Xns93F6C8938DB25POVMIKA@204.213.191.226>
"Dennis Miller" <dhm### [at] comcastnet> wrote in
news:3f64f222$1@news.povray.org:
> clockmod.inc:
>  To (1, 0)  ) ;
> whatever clock range you use.
> does not have to be linear (accelerate, decelerate, Bounce,
> Wave, etc.)
Eh hum..well a couple of hours ago I discouvered Chris's
macros & includes and have been fiddling with it, very
interesting in dead.
Looks very promising, this kinda stuff should be built in to
POV :)
Thanks
Marc Champagne
Montreal, CANADA
Date: 14 Sep 2003 19:48:52
Message: <Xns93F6C92A3B518POVMIKA@204.213.191.226>
"Tim Nikias v2.0" <no_lights (@) digitaltwilight.de> wrote in
news:3f64f471@news.povray.org:
> #else
> #end
> event occurs.
> #end
> seconds, and things can be animated very easily with values
> from 0 to 1 IMHO.
I like this LocalClock idea!
I managed to find Chris Colefax's animation macros and
managing object in time is pretty simplified.
Thanks
Marc Champagne
Montreal, CANADA
Date: 14 Sep 2003 21:19:42
Message: <3f6513ae$1@news.povray.org>
> in dead
"indeed" =)
 - Slime
