POV-Ray : Newsgroups : povray.animations : CSG object animation URL and Camera tracking problem Server Time
6 Oct 2024 09:05:26 EDT (-0400)
  CSG object animation URL and Camera tracking problem (Message 1 to 5 of 5)
Subject: CSG object animation URL and Camera tracking problem
Date: 21 Jan 2003 16:38:14
Message: <3e2dbdc6$1@news.povray.org>
At:
http://suso.suso.org/visual/3d/neatobject7.mpg  (I discovered the 2MB
posting limit.
Isn't that a bit ridiculous)
  is an animation I made of the object shown on the website:
http://www.f-lohmueller.de/pov_tut/csg/povcsg4e.htm
Basically I just wanted to determine how the object was made without
reading his example code
and learn how to do morphing animations in pov-ray.  In the end, I
started doing stuff with
camera movement radiosity and so on.  But I am having trouble getting
the camera to track
to <0,0,0> as it moves.  Can anyone help me fix this problem?  Also
attached is my pov
and ini files.
Thanks,
Suso
Download 'us-ascii' (1 KB) Download 'us-ascii' (4 KB)
Subject: Re: CSG object animation URL and Camera tracking problem
Date: 21 Jan 2003 17:18:35
Message: <3e2dc73b@news.povray.org>
Suso Banderas <sus### [at] susoorg> wrote:
> But I am having trouble getting the camera to track
  Either you want something else, or there's something which I don't get.
  Have you tried simply defining the look_at vector as <0,0,0> in all
camera definitions?
Date: 21 Jan 2003 17:41:03
Message: <pan.2003.01.21.22.41.14.904450@suso.org>
> camera definitions?
Yes I have tried that.
For the camera move part, this is what I have:
        location <-1.25, 1.25, -2>
        translate <1.25*clock2, -1.25*clock2, 0.75*clock2>
        look_at <0*clock, 0*clock, 0*clock>
Originally I tried
        look_at <0, 0, 0>
 But then I read the part in the PovRay documentation that mentioned
that some coordinates might not be read repeatedly if they happen
before a translate, so I tried putting the look_at after the translate.
But that didn't head so I tried using a 0*clock method, thinking that
maybe it wouldn't read the look_at line again unless it had the word
clock in it.
  All, I'm trying to do is make the camera look at the same point as it
moves through space.  A simple camera track.
Thanks for your help.
Date: 21 Jan 2003 18:20:03
Message: <3e2dd5a2@news.povray.org>
>     camera {
  Instead of translating the camera, add the translation vector to the
location vector.
  And by the way, 0*clock = 0.
Date: 22 Jan 2003 10:52:22
Message: <pan.2003.01.22.15.52.33.621502@suso.org>
> location vector.
  Cool, that worked:
        location <-1.25, 1.25, -2> + <1.25*clock2, -1.25*clock2, 0>
        look_at <0, 0, 0>
  you can check out the fixed version here:
  http://suso.suso.org/visual/3d/neatobject9.mpg
  Yes, I know that.  What I was thinking when I did that is that
perhaps povray wasn't seeing the translate line unless I put a clock
variable there, so it wouldn't hurt anything to put one there since I
wanted the camera to look at 0,0,0 anyways.
thanks for your help
