POV-Ray : Newsgroups : povray.animations : Ghost effect... suggestions? Server Time
6 Oct 2024 11:15:25 EDT (-0400)
  Ghost effect... suggestions? (Message 1 to 5 of 5)
Subject: Ghost effect... suggestions?
Date: 21 Jul 2002 23:22:01
Message: <3D3B7A43.5070507@yahoo.com>
Ok, so I want to make a transitional animation that fades from one scene
into another retaining a common object (like a sphere).  Specifically I
want an apple held in a human hand to become the Earth as seen from
orbit.  How to make the hand slowly fade away, ghost like?
For that matter what is the best way to make any simple object (in a
simple scene) fade away?  I've thought about using .png based image maps
and going with a variation in alpha transparency but there must be
(hopefully) an easier way?
Thanks in advance
Subject: Re: Ghost effect... suggestions?
Date: 21 Jul 2002 23:31:21
Message: <3d3b7c89@news.povray.org>
"October" <ext### [at] yahoocom> wrote in message
news:3D3### [at] yahoocom...
Change the transparency value of the object
rgbt<1,1,1,0> ---> rgbt<1,1,1,1>
make sure you don't have light fading on for the object.
-tgq
Date: 22 Jul 2002 01:52:24
Message: <3D3B9D82.5010506@yahoo.com>
> -tgq
Thanks for the reply!
Ok, I get the drift of rgbt now (it's been awhile) but am still a bit
lost on "don't have light fading on for the object".  Would you please
elaborate?
Thanks again
Date: 22 Jul 2002 07:03:29
Message: <3D3BE602.6434EC60@onwijs.com>
> Thanks in advance
You probably can do this in POV with transparency but there may
be some 'interference' problems with the two images. I guess
post-processing would be much easier and faster.
Remco
Date: 22 Jul 2002 07:52:27
Message: <3d3bf1fb$1@news.povray.org>
> elaborate?
In the 'interior' block you can specify 'fade_power' and 'fade_distance'.
If these are enabled they may interfere with the effect you want.  But these
shouldn't be used for opaque objects anyways as they wouldn't have any
effect.  What they do is fade the light as it passes through a transparent
or partially transparent object.
-tgq
