POV-Ray : Newsgroups : povray.animations : Rotating text around center? Server Time
28 Jul 2024 18:14:45 EDT (-0400)
  Rotating text around center? (Message 1 to 10 of 10)
Subject: Rotating text around center?
Date: 18 Jun 1999 23:29:22
Message: <376b0e92@news.povray.org>
I am making an animation, and I am trying to rotate a single word around in
a circle.  The problem is that since text starts at the lower left corner(in
POVray, which is what I'm using) it rotates by its edge instead of by the
middle.  For example, it rotates more like the hand of a clock than a plane
propeller.  How can I get around this.  There must be some fancy thing I can
do with sin and cosine, etc...  If you wouldn't mind, please email me a copy
of your reply at rla### [at] mbhsedu.  Thanks a lot for any help!
Subject: Re: Rotating text around center?
Date: 18 Jun 1999 23:40:07
Message: <376B106A.7817@gvn.net>
Larkrill,
You need to translate your text to the left by half of the length of the
text.  This will center your text at 0,0.  All rotations rotate about
this point.
Brian Mason
bri### [at] gvnnet
http://www.gvn.net/~brian448/
Date: 19 Jun 1999 00:37:45
Message: <376b1e94.13274473@news.povray.org>
On Fri, 18 Jun 1999 20:37:14 -0700, Brian Mason <bri### [at] gvnnet>
>Larkrill,
>this point.
This is one area where POV could really do with some extra functions.
Charwidth, Charheight, Stringwidth and Stringheight would make some
things sooooo much easier!
In the short term, it's possible that some assistance may be found at
http://quark.gmi.edu/~redbeard/raytracing/POVRay-util.html
Bear in mind though that the "font.inc" file was written for POV 3.0,
and only works (correctly) with the font distributed with POV.
Cheers,
Cliff Bowman
Why not pay my 3D Dr Who site a visit at
http://www.geocities.com/Area51/Dimension/7855/
PS change ".duffnet" to ".net" if replying via e-mail
Date: 19 Jun 1999 10:13:56
Message: <376B9741.97DE5AD6@panama.phoenix.net>
If you're willing to try out the SuperPatch, then your problems are solved.
This is what you would write to center the text:
#declare String = text {ttf "yourfont.ttf", "yourstring", 2, 0}
object {String rotate whatever translate
-(min_extent(String)+max_extent(String))/2}
//or using my center() macro
#macro center(obj)
 translate -(min_extent(obj)+max_extent(obj))/2
#declare String = ...
object {String rotate whatever center(String)}
It's just that simple. Go out and get that patch today!
Anthony L. Bennett
http://welcome.to/TonyB
Graphics rendered
by the Dreamachine.
Date: 21 Jun 1999 17:25:29
Message: <jerry-2106991425330001@cerebus.acusd.edu>
In <376b1e94.13274473@news.povray.org>, who### [at] spamcitycom (Cliff Bowman) wrote:
Ron Parker's Object Bounds patch (which is part of the Superpatch, and is
also easy to add to 3.1) is a more general solution; it allows you to find
the minimum and maximum "bounds" of any object, which, for text objects,
ends up being what is needed to manipulate them. Now that I've started
using it, I can't use POV without it! I am desperately hoping it makes it
into POV 3.5.
Jerry
Date: 21 Jun 1999 17:47:17
Message: <376EB2A8.DA5459C2@spiritone.com>
Hmm... I sense a challenge..... You can create a custom macro to do this... here
is a start
#macro CirclingText(string,font,depth,arc,rad)
  #local length = strlen(string);
  #local last = length + 1;
  #local s = 1;
  #local r = arc/length;
  #while ( s < last )
     text { ttf   font,
            substr(string,s,1)      // the string to create
            depth,              // the extrusion depth
            0               // inter-character spacing
            pigment { rgb 1 }
            translate rad*y
            rotate r*(s-1)*-z}
     #local s = s + 1;
#end // macro
CirclingText ("Joshua","crystal.ttf",0.25,270,1)
This should give you a starting point.
Joshua
eng### [at] spiritonecom
Date: 21 Jun 1999 22:10:27
Message: <376EEFF3.C4A51F35@xs4all.nl>
Though it's not really what you asked, perhaps this can be of help:
http://www.xs4all.nl/~remcodek/zip/softtext.zip
It's a small utility I made (Windows only!) that makes a blob-object from any
text in any font you like which allows you to twist, rotate, stretch or do any
other sadistic thing you can think of to your textobject.
I'll post some examples in the appropriate binaries-groups.
Remco
Date: 22 Jun 1999 01:40:44
Message: <376f21dc@news.povray.org>
Jerry <jer### [at] acusdedu> wrote:
: it allows you to find the minimum and maximum "bounds" of any object
  I'm curious about how does it work.
  For example, how can it find the boundaries of a poly, a blob, a bicubic
patch or even a difference csg? What about infinite objects?
  Or is it just an approximation?
Date: 22 Jun 1999 15:15:42
Message: <jerry-2206991215430001@cerebus.acusd.edu>
In article <376f21dc@news.povray.org>, Nieminen Mika <war### [at] cctutfi> wrote:
Ask Ron, but  I believe that what it does is just return POV's
pre-calculated bounding box, which is used to determine whether or not a
ray *might* be hitting this object. My experience has been that it works
perfectly on text; I've never tried it on a plane, that would be
interesting...
Jerry
Date: 24 Jun 1999 13:47:55
Message: <37726a7f.143007749@news.povray.org>
>interesting...
Ouch! Still - since it works on text... should do nicely for me.
Actually, I already have it, although I'm concerned about possible
differences in results obtained by "straight" 3.1e as the 3.1e sources
aren't available yet (or weren't when last I checked).
All I really need is a big book called "POV-Ray and Superpatch for
idiots" <g>
Cheers,
Cliff Bowman
