POV-Ray : Newsgroups : povray.animations : Annimation Matrix Server Time
28 Jul 2024 20:32:27 EDT (-0400)
  Annimation Matrix (Message 1 to 4 of 4)
Subject: Annimation Matrix
Date: 1 May 1999 16:31:18
Message: <372b5686.0@news.povray.org>
I would like to use a Matrix of X,Y,Z positions to describe an irregular
object movement. Is this possible or what would be the preferred approach?
Subject: Re: Annimation Matrix
Date: 3 May 1999 09:00:46
Message: <372D90EC.C3F2F663@puzzlecraft.com>
I believe that ClockMod supports animating matrix values. I'm not absolutely
certain, you might check with Chris Colefax about this. ClockMod certainly
can handle irregular motions, but there might be something special about
handling raw matrices.
You might check out the BEND macro - it can handle all kinds of bending and
twisting. Used with ClockMod you can get some irregular organic animation
effects.
steve
Subject: Re: Animation Matrix
Date: 4 May 1999 02:02:50
Message: <372E7F04.6830C7D6@pacbell.net>
It might be easier to use an array of xyz positions to desribe an irregular
object movement.
#declare Trans_pts = 7;
#declare Trans_pts_array = array[Trans_pts]
	<-1.5, 1.667, -11.5>,
	<-3.5, 0.667,  -9.5>,
	<-1.5, 2.667,  -7.5>,
	<-1.5, 0.667,  -5.5>,
	<-3.5, 3.667,  -3.5>,
	<-3.5, 0.667,  -1.5>,
	<-1.5, 4.667,   0.5>
#declare N = 0;
#while ( N < Trans_pts )
	sphere { <0, 0,0> 1 translate Trans_pts_array[N]*clock }
	#declare N = N + 1;
  I'm not sure if the above example will actually move one object to several
locations or create multiple objects for each location but the idea has room
for exploration.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 22 Jun 1999 09:31:33
Message: <B395CD77-33AB3@147.109.83.18>
On Sun, 2 May 1999 5:26 AM, David Vincent-Jones
<mailto:geo### [at] galaxynetcom> wrote:
Yeah, I know it's old...
switch statement inside the translate, or if doing more than one
transformation, the transformations in a switch... section 4.2.6.3 of the
User Doc.
perhaps?
Have Fun
Martin
Owner/Operator - Tesseract Computing
<hypercube 'at' tesseract.com.au> or just reply.
Computer Systems Officer - Tourism Tasmania
<Martin.Crisp 'at' tourism.tas.gov.au>
I speak for me.
