POV-Ray : Newsgroups : povray.advanced-users : UV mapping without image file? Server Time
10 Oct 2025 17:03:42 EDT (-0400)
  UV mapping without image file? (Message 1 to 5 of 5)
Subject: UV mapping without image file?
Date: 28 Jul 2016 20:20:01
Message: <web.579aa111e98267af5e7df57c0@news.povray.org>
I have a simple procedural texture that I want to include in a layered texture
definition (agate with a simple color map).
Agate is 3D, and doesn't quite give me the sort of look I want - I think it
would look much better wrapped around the surface of my object.   A simple box
looks pretty close to what I want.
Is there a way to define a texture, and include that directly into a uv-mapped
texture definition without going through the whole rendering to a file and then
pulling the image back in for the uv-mapping?
As always, thanks.
Subject: Re: UV mapping without image file?
Date: 28 Jul 2016 22:19:04
Message: <579abd18$1@news.povray.org>
> As always, thanks.
Snip from docs;
3.4.7.1.12.2 Function Image
     image_map {
       function 10,10 {
         pigment { checker 1,0 scale .5  }
Some uses include creating heightfields from procedural textures or
wrapping a slice of a 3d texture or function around a cylinder or
extrude it along an axis.
Stephen S
Date: 29 Jul 2016 10:00:30
Message: <579b617e$1@news.povray.org>
Am 29.07.2016 um 02:19 schrieb Bald Eagle:
Absolutely. It's as simple as adding the `uv_mapping` keyword to the
object. POV-Ray will take the XY plane of whatever texture you choose,
image-based or otherwise.
Date: 29 Jul 2016 17:40:00
Message: <web.579bcca8fd3aae385e7df57c0@news.povray.org>
Very nice.   Thank you both, Stephen and clipka.
I'm unaccustomed to coding complex textures, and would to mix standard textures
with uv-mapped ones.  I would assume that may be possible as well, but I just
spent the whole day moving very heavy stuff in 90 F weather (32.2 C) and I
cannot brain.
How do I construct my texture statement to apply a standard procedural texture,
and then layer a uv-mapped texture over that?
Thanks
Date: 31 Jul 2016 09:28:41
Message: <579dfd09$1@news.povray.org>
Am 29.07.2016 um 23:37 schrieb Bald Eagle:
Unfortunately /that/ is currently not possible.
