POV-Ray : Newsgroups : povray.advanced-users : Format to Convert Server Time
29 Jun 2024 01:46:47 EDT (-0400)
  Format to Convert (Message 1 to 5 of 5)
Subject: Format to Convert
Date: 8 Jul 2014 12:10:01
Message: <web.53bc16a761a21688e9033540@news.povray.org>
There are 21 formats in which I can convert my file. Formats are
acad, dot, dxf, egg, euclid, euclid2, iges, jack, nff, nmg, obj, off, raw,
shell-rect, step, stl, tankill, var, voxel, vrml, x3d.
I am using BRL-CAD to make models and store it in .g file. I want to import this
BRL-CAD model into POV-ray.
Which formats should I choose from above 21 formats, so that I can first convert
my BRL-CAD model into that format and then convert it into .pov format to get
model with proper accuracy and with less damage to my model.
Subject: Re: Format to Convert
Date: 8 Jul 2014 13:05:00
Message: <web.53bc23f0c42b8566a6d78d040@news.povray.org>
I'm not quiet sure that I understand your request. But you can use obj and than
pass it through PoseRay to get a POV-Version
(https://sites.google.com/site/poseray/).
Best regards,
Michael
Date: 8 Jul 2014 20:56:02
Message: <53bc9322$1@news.povray.org>
Am 08.07.2014 18:04, schrieb bakom:
Probably the most widely used path to get 3D data from 3rd party
software into POV-Ray is via the mesh-based .obj format (and the most
widely used tool for that job is probably PoseRay).
However, a quick glance at the Internet suggests that BRL-CAD also uses
other model representations aside from the mesh format, and from the
quality point of view it would be desirable to import those directly
into POV-Ray without converting them to meshes first.
Unfortunately, the vast majority of tools that can convert to POV-Ray
format only support meshes; maybe one of the major reasons for this is
that an almost universally supported, simple file format with easily
accessible documentation - like .obj in the mesh world - doesn't seem to
exist in the CSG world; the most universal formats appear to be iges
(.igs) and step (.stp), but both have a much wider scope than just 3D
geometry, and documentation of the file formats seems hard to come by.
The BRL-CAD documentation mentions the possibility to write your own
exporter, which might be the best choice in this case. After all, the
POV-Ray format is quite easy to generate.
Date: 12 Jul 2014 22:35:00
Message: <web.53c1f032c42b856654473d7a0@news.povray.org>
You might want to look into Silo, which is a 3D modeling, retopology, yada yada
program that I just heard about. It sells for just over $100, supports input of
..dxf, .obj, .3ds, and outputs .pov format. I have not tried it, and I do not
know how far behind on version they are, whether they support mesh or true Pov,
but there it is.
Date: 13 Jul 2014 03:18:28
Message: <53c232c4$1@news.povray.org>
> but there it is.
Silo has just come out with version 2.3 ( http://nevercenter.com/silo/ )
which is a maintenance version. It truly is an excellent program for
those who want fast and easy modelling without strain to the brain :-)
Additional supported formats from those mentioned above are .fac, .rib,
.stl.
While supporting .pov output, I never use that as I prefer exporting as
.obj and convert to mesh2 in Poseray.
