![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
There are 21 formats in which I can convert my file. Formats are
acad, dot, dxf, egg, euclid, euclid2, iges, jack, nff, nmg, obj, off, raw,
shell-rect, step, stl, tankill, var, voxel, vrml, x3d.
I am using BRL-CAD to make models and store it in .g file. I want to import this
BRL-CAD model into POV-ray.
Which formats should I choose from above 21 formats, so that I can first convert
my BRL-CAD model into that format and then convert it into .pov format to get
model with proper accuracy and with less damage to my model.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm not quiet sure that I understand your request. But you can use obj and than
pass it through PoseRay to get a POV-Version
(https://sites.google.com/site/poseray/).
Best regards,
Michael
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 08.07.2014 18:04, schrieb bakom:
Probably the most widely used path to get 3D data from 3rd party
software into POV-Ray is via the mesh-based .obj format (and the most
widely used tool for that job is probably PoseRay).
However, a quick glance at the Internet suggests that BRL-CAD also uses
other model representations aside from the mesh format, and from the
quality point of view it would be desirable to import those directly
into POV-Ray without converting them to meshes first.
Unfortunately, the vast majority of tools that can convert to POV-Ray
format only support meshes; maybe one of the major reasons for this is
that an almost universally supported, simple file format with easily
accessible documentation - like .obj in the mesh world - doesn't seem to
exist in the CSG world; the most universal formats appear to be iges
(.igs) and step (.stp), but both have a much wider scope than just 3D
geometry, and documentation of the file formats seems hard to come by.
The BRL-CAD documentation mentions the possibility to write your own
exporter, which might be the best choice in this case. After all, the
POV-Ray format is quite easy to generate.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You might want to look into Silo, which is a 3D modeling, retopology, yada yada
program that I just heard about. It sells for just over $100, supports input of
..dxf, .obj, .3ds, and outputs .pov format. I have not tried it, and I do not
know how far behind on version they are, whether they support mesh or true Pov,
but there it is.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> but there it is.
Silo has just come out with version 2.3 ( http://nevercenter.com/silo/ )
which is a maintenance version. It truly is an excellent program for
those who want fast and easy modelling without strain to the brain :-)
Additional supported formats from those mentioned above are .fac, .rib,
.stl.
While supporting .pov output, I never use that as I prefer exporting as
.obj and convert to mesh2 in Poseray.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
