POV-Ray : Newsgroups : povray.advanced-users : Help on dispersion value Server Time
14 Mar 2026 21:04:20 EDT (-0400)
  Help on dispersion value (Message 1 to 7 of 7)
Subject: Help on dispersion value
Date: 6 Apr 2008 21:10:00
Message: <web.47f970f5a63837b7c87d9e20@news.povray.org>
Hi there,
I'm trying to render the most realistic diamond there can be. To do so I need
realistic IOR value and dispersion value. At first I found them in consts.inc
shipped with POV-Ray, namely IOR value = 2.47 (or sth) and dispersion value =
1.035. Then I got across some scientific page about diamonds. As of 2003, the
most accurate value for diamond's IOR is 2.4175, and dispersion value of 0.044.
So my question is: how does 1.035 from POV-Ray relate to 0.044 from the web?
The 0.044 value is said to be "disspersion strength":
  Index of
  Colour    Refraction  Source Line    Wavelength
  Red       2.407       Solar  B-line   687   nm
  Yellow    2.417       Sodium D-line   589.3 nm
  Violet    2.452       Solar  G-line   431   nm
The difference between the indexes of refraction (2.452 - 2.407) is the
dispersion (0.044). (There is a small rounding error.)
http://www.folds.net/diamond_design/index.html#ed_note_04
I'd appreciate any help.
Best regards,
Opal
Subject: Re: Help on dispersion value
Date: 7 Apr 2008 12:16:52
Message: <47fa48f4@news.povray.org>
Opal nous apporta ses lumieres en ce 2008/04/06 21:05:
> Hi there,
>   Index of
The dispersion is not a difference but a quotiant.
> Best regards,
> Opal
The only value you need to compute is the dispersion.
The dispersion value is the quotiant of the violet ior divided by the red ior:
2.452/2.407 = 1.0186955
But, the value you have are not from the extreme ends of the visible spectrum.
The resulting dispersion is thus slightly smaller than the real dispersion value.
To render the most realistic diamond possible, you'll need to take into acount
the birefringeance of the diamond, whitch is not possible at present. You'd need
a syntaxe like:
ior{ior1, ior2, neutral_axis}
where
ior1 is tha base ior, sphericaly constant.
ior2 is the secondary ior perpendicular to the neutral_axis, not constant.
neutral_axis is the axis where the 2 iors have the same value.
Date: 7 Apr 2008 12:18:49
Message: <47fa4969$1@news.povray.org>
Forgot to mention that the dispersion is also variable in a birifringeant
material. You need 2 dispersions values, each associated with it's respective ior.
Monday is an awful way to spend 1/7 of your week.
Date: 7 Apr 2008 13:25:00
Message: <web.47fa5886348fa8a9c87d9e20@news.povray.org>
"To render the most realistic diamond possible, you'll need to take into acount
the birefringeance of the diamond, whitch is not possible at present."
Hmmm. Nevertheless, the statement is still true - the most realistic diamond
possible - and since simulating birefringent materials is impossible I can
cross out this option (for now).
BTW: Is birefringence (and trirefringence) planned in future versions of
POV-Ray? And isn't there any trick to achieve similar effect to birefringence?
Best regards,
Opal
Date: 8 Apr 2008 12:53:38
Message: <47fba312$1@news.povray.org>
Opal nous apporta ses lumieres en ce 2008/04/07 13:23:
> Best regards,
> Opal
Not to my knowlege.
It may be possible to fake it to a point using an averaged material. Need to
experiment.
The tree of liberty must be refreshed from time to time with the blood of
patriots and tyrants.
Thomas Jefferson
Date: 13 Apr 2008 17:00:01
Message: <48027451@news.povray.org>
Like Alain said, you can average two textures together. Each texture
would have a slightly different surface normal, but this is a hack and
will not be very accurate (to the eye, maybe...)
If you didn't know about this already, I'll tell you now of a useful
include file containing different ior, dispersion and birefringence
values for many different minerals:
http://www.seasoft.tecbox.com/Pov/NewIOR.html
The dispersion values are based on MegaPOV's implementation of said
effect, but they should also work with the official versions.
I hope this helps!
Sam
Date: 14 Apr 2008 16:45:00
Message: <web.4803c1f4348fa8a9c87d9e20@news.povray.org>
Wow!
The thing's great.
Thank's alot for that.
There's also a gem cutting library, but very basic.
I also work on a gem cutting library - more complex one - that would contain not
only modern cutting techniques, but also historical ones. Tho, these techniques
don't give yet same effect as real-life jewels. Everything would be put in
parameterized macros (not containing hundreds of single facets).
Thanks all for help, I really do appreciate it.
Regards
Opal
