POV-Ray : Newsgroups : povray.advanced-users : Tranformation matrix to change coordinate spaces Server Time
14 Mar 2026 02:38:25 EDT (-0400)
  Tranformation matrix to change coordinate spaces (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Tranformation matrix to change coordinate spaces
Date: 11 May 2001 11:08:12
Message: <3afc005c@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: First you need to calculate the inverse of
  Also note that not all matrices can be inverted (it's an analog case to
real numbers, where 0 has no inverse).
  This is why a scale<1,0,0> is not allowed in povray (it would generate
a non-invertable matrix).
Date: 11 May 2001 11:09:25
Message: <slrn9fo05b.m7q.ron.parker@fwi.com>
True, but if those really are basis vectors, the inverse should exist.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 11 May 2001 12:40:05
Message: <3AFC16E8.E0BEBDF2@erols.com>
Peter Popov wrote:
> This probably does not deserve being here but anyway...
> Can anyone (John? Please :) ) show me how to find a matrix that
> changes from one coordinate space (A0, Ax, Ay, Az) to another (A0',
> Ax', Ay', Az')? I found some info on the Net but I have problems
> finding the signs of the angles involved and it will probably be
> slower than some things I recall seeing here.
The advice that the others give is sound.  You need to calculate
the inversion of the first matrix, and then multiply this inversion
by the second matrix.
This is, by the way, the manner in which the Reorient() macro works.
If you happen to have this matrix:
matrix < vecx.x vecx.y, vecx.z,
         vecy.x vecy.y, vecy.z,
         vecz.x vecz.y, vecz.z,
         vecl.x vecl.y, vecl.z >
The following macro will invert it.  It cheats a bit, BTW,
in that it undoes the translation component (the vecl part),
and then undoes the rotation, scaling, and shearing that
is done by vecz, vecy, vecz.
#macro Inverse(vecx,vecy,vecz,vecl)
  #local vx=(vecx);
  #local vy=(vecy);
  #local vz=(vecz);
  #local det=vdot(vx,vcross(vy,vz));
  #if (det=0)
    #fatal "Invalid matrix supplied to macro.\n"
  #local ca=vx.x;  #local cb=vx.y;  #local cc=vx.z;
  #local cd=vy.x;  #local ce=vy.y;  #local cf=vy.z;
  #local cg=vz.x;  #local ch=vz.y;  #local ci=vz.z;
  translate -(vecl)
  matrix <
  (ce*ci-cf*ch)/det,(cc*ch-cb*ci)/det,(cb*cf-cc*ce)/det,
  (cf*cg-cd*ci)/det,(ca*ci-cc*cg)/det,(cc*cd-ca*cf)/det,
  (cd*ch-cg*ce)/det,(cb*cg-ca*ch)/det,(ca*ce-cb*cd)/det, 0,0,0>
If you want to understand this sort of thing better (useful
for things outside of POV-Ray, too!), go find "matrix inversion"
and "matrix multiplication" on the Web, and find a page that
makes sense to you.
Hope this helps,
John
ICQ: 46085459
Date: 11 May 2001 12:49:59
Message: <3afc1837@news.povray.org>
The Matrix Master has spoken. :)
  Nice stuff. It's good that at least someone knows about matrices because
it's one of the most unknown fields of math here (even I haven't studied
them enough to answer this kind of question).
Date: 11 May 2001 16:51:40
Message: <3afc50db@news.povray.org>
If you are using MegaPOV, it would be much easier to use:
transform {matrix <...> inverse}
This is even more useful, since you can specify any series of
transforms, and use declared transforms...however, it can't be used to
get the matrix, as your macro can be modified to do.
Or maybe it can...it should be possible by using vtransform() to
"scan" a matrix, using x, y, and z to get the first 3 columns, and
< 0, 0, 0> to get the fourth...right?
> makes sense to you.
www.google.com is very helpful here...For POV-specific pages, try the
links page on povray.org, but the ones I've found don't explain
inversion and stuff, just how to use the matrix transform.
This is a good POV-specific page: ;-)
http://enphilistor.users4.50megs.com/matrix.htm
Also:
http://davidf.faricy.net/povre.html
http://www.shipbrook.com/jeff/raytrace/matrix.html
http://www.cix.co.uk/~gbreed/matritut.htm
Christopher James Huff - chr### [at] maccom
Home Page: http://homepage.mac.com/chrishuff/
POV-Ray TAG e-mail: chr### [at] povrayorg
POV-Ray TAG web site: http://tag.povray.org/
Date: 11 May 2001 21:45:21
Message: <3AFC9483.2A370897@videotron.ca>
Watch it bud!  I studied matrices thoroughly in university - mechanical
engineering wiht a specialiation in finie elements analysis.
However, six years of work in a completely unrelated field - networking
- has made me forget most of it.
Francois Labreque | In the future, performance will be measured
    flabreque     | by the size of your pipe.
        @         |             - Dogbert, on networking
   videotron.ca   |
Date: 12 May 2001 07:41:28
Message: <3AFD226D.721FD4CB@erols.com>
First you would use vtransform on <0,0,0> to get the translation
component (call it, say vL); then you use vtransform on x, y and
z, separately, and subtract vL from the results of each.
> > makes sense to you.
Google is helpful no matter *what* you're looking for...
True.
John
ICQ: 46085459
Date: 12 May 2001 16:24:15
Message: <gd3rftk1taoovn2cbupeqc944f2hkg26pi@4ax.com>
I followed Rune's advice and was able to figure it out from there on
(after some transposing). I still don't understand John's inversion
macro. I know how to invert a matrix, but our Neo is doing some odd
stuff with the matrix there that I don't understand. Anyway, I will be
adding matrix multiplication and matrix transformations to the vector
class I am using, so I might as well use Rune's way.
Thanks for your help, guys!
Peter Popov ICQ : 15002700
Date: 6 Aug 2001 14:19:33
Message: <3B6EE0A3.31C9731C@hotmail.com>
>   #local vx=(vecx);
>   #local vy=(vecy);
>   #local vz=(vecz);
>   #if (det=0)
>   #end
>   translate -(vecl)
>   matrix <
> #end
Here's a shorter version of it:
#macro InvTransform(vX, vY, vZ, vL)
  #local Det = vdot(vX, vcross(vY, vZ));
  #if (Det = 0)
    #error "Macro InvTransform: Invalid matrix supplied.\n"
  #end // if
  #local vA = vcross(vY, vZ)/Det;
  #local vB = vcross(vZ, vX)/Det;
  #local vC = vcross(vX, vY)/Det;
  translate -vL
  matrix <
    vA.x, vB.x, vC.x,
    vA.y, vB.y, vC.y,
    vA.z, vB.z, vC.z,
    0,    0,    0
#end // macro InvTransform
For those of you that want to see an
example on how to use this macro;
see my example code below.
Best regards,
Tor Olav Kristensen
Email: tor### [at] hotmailcom
http://hjem.sol.no/t-o-k
http://www.crosswinds.net/~tok
// ===== 1 ======= 3 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7 =
// By Tor Olav Kristensen
#version 3.1;
#macro Transform(vX, vY, vZ, vL)
  #if (Det = 0)
    #error "Macro Transform: Invalid matrix supplied.\n"
  #end // if
  matrix <
    vX.x, vX.y, vX.z,
    vY.x, vY.y, vY.z,
    vZ.x, vZ.y, vZ.z,
    vL.x, vL.y, vL.z
#end // macro Transform
  #if (Det = 0)
  #end // if
  translate -vL
  matrix <
    vA.x, vB.x, vC.x,
    vA.y, vB.y, vC.y,
    vA.z, vB.z, vC.z,
    0,    0,    0
#declare vXX = <1, -0.3, 2>;
#declare vYY = <2, 1, 0>;
#declare vZZ = <0.3, 0, 1>;
#declare vLL = <0, -1.5, 0>;
#declare Box = box { -<1, 2, 3>, <1, 2, 3> }
object { Box pigment { color White } }
object {
  Box
  scale 1.00001 // scale 0.99999
  pigment { color Red }
  Transform(vXX, vYY, vZZ, vLL)
//  InvTransform(vXX, vYY, vZZ, vLL)
// Uncomment the InvTransform line above
// to see the Box transformed back.
background { color Blue /2 }
light_source { <2, 3, -1>*100 color White }
  location <1, 1, -2>*5
  look_at <0, 0, 0>
Date: 7 Aug 2001 14:14:54
Message: <3B7030D9.96271197@hotmail.com>
<snip>
Yup.  I had something like that lying around somewhere, but couldn't put
my mouse on the file, so I typed up what I did instead.
John
ICQ: 46085459
