Using this code I can create a 2D representation of a sinewave in
the x/y plane:
#declare i=0;
#while (i<90)
sphere {0,1 pigment {rgb <1,0,0>}finish {ambient 1.0}
translate <i,10*sin(i*pi/30),0>}
#declare i = i + 1;
Is it possible to extend (not extrude) the sine wave pattern into the
z plane as well ?
The final result if I can describe it correctly would be alternating
mounds and valleys.
Anyone ?
Ken Tyler - 1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
>z plane as well ?
>mounds and valleys.
>Anyone ?
Try:
#declare X=-50;
#while (X<50)
#declare Z=-50;
#while (Z<50)
sphere { <X,5*sin((X+Z)/30),Z>,1 }
#declare Z=Z+1;
#end;
#declare X=X+1;
Unchecked!!!
Peter Popov
ICQ: 15002700
Peter Popov wrote:
> Try:
> #declare X=-50;
> #while (X<50)
> #declare Z=-50;
> #while (Z<50)
> #declare Z=Z+1;
> #end;
> #declare X=X+1;
> #end
> Unchecked!!!
Thanks Peter but this gives an extruded sine. Maybe it's my explaination.
I'll try to make a csg example and post it later in pbi.
No, Ken, your explanation is perfectly clear and I have even seen the
thing animated realtime (on a 486 DX40) but my math is wrong.
POV finished rendering (maybe I should post the result? Haven't posted
a pic in a #while...) so I will check my formula and post a bit later
(half an hour?)
Peter Popov
ICQ: 15002700
I think this:
#declare X=-50;
#while (X<50)
#declare Z=-50;
#while (Z<50)
sphere { <X,5*(sin(X/30) +sin(Z/30)),Z>,1 }
#declare Z=Z+1;
#end;
#declare X=X+1;
will do what you want.
On Wed, 13 Oct 1999 03:19:37 +0300, Peter Popov <pet### [at] usanet>
>(half an hour?)
Here you go:
#declare X=-100;
#while (X<100)
#declare Z=-100;
#while (Z<100)
#declare Y=5*sin(X/10)+5*sin(Z/6);
sphere { <X,Y,Z>, 2 pigment { blue 1 green (10+Y)/20 } }
#declare Z=Z+2;
#declare X=X+2;
light_source { 1000*y color rgb 1 }
camera
{ location <20,60,-80> up y right x sky <3,10,0> look_at -35*z }
Render a swuare image. Enjoy the dive :)
Peter Popov
ICQ: 15002700
Note: I did not test this code, I actually made an isosurface with this
function:
function {y - 5*(sin(x/3) + sin(z/3))}
and a threshold of 0. Of course, this requires the Superpatch.
This has been tested:
union {
#declare X=-50;
#while (X<50)
#declare Z=-50;
#while (Z<50)
sphere { <X,5*(sin(X/5) +sin(Z/5)),Z>,1 pigment {color Yellow}}
#declare Z=Z+1;
#declare X=X+1;
scale 0.1
> function:
> union {
> #declare X=-50;
> #while (X<50)
> #declare Z=-50;
> #while (Z<50)
> #declare Z=Z+1;
> #end
> #declare X=X+1;
> #end
> scale 0.1
Worked great. Thanks Chris.
> >(half an hour?)
> Here you go:
> #declare X=-100;
> #while (X<100)
> #declare Z=-100;
> #while (Z<100)
> #declare Z=Z+2;
> #end
> #declare X=X+2;
> #end
> camera
> Peter Popov
> ICQ: 15002700
Worked great. Thanks Peter.
Swuare image ? :)
> the x/y plane:
> #declare i=0;
> #while (i<90)
> #declare i = i + 1;
> #end
> z plane as well ?
> mounds and valleys.
> Anyone ?
If I remember right Spider did a lot of this last year.
There must still be something somewhere in the b.i.-group.
Remco
